0 Replies Latest reply on Sep 1, 2017 7:26 AM by josuelion
    Direct Inks
    josuelion
      Good morning people.
      Thank you for your time.
      I will be brief for your comfort when reading this text.
      Using direct inks, two in this example, one on top of the other using opacity of 100%
      The ink on the top should cut the color to the lower ink and when importing the illustrator this should be respected. This is not being respected
      Since illustrator overlaps the ink as if it were overprinted and gives the same effect as if it had set the opacity in photoshop to 0%
      What I look for is to apply an automatic overlap with a trap and cut the two inks where the colors meet without the need to cut the ink down manually.
