5 Replies Latest reply on Jan 17, 2018 11:18 PM by danielc33727021
    Flash Pro CS6 crashes from Command-C or Edit > Copy
    kv74063367 Level 1
      Hello, my Flash Professional CS6 keeps crashing when I use the Copy command!  It crashes when I copy a vector or shape.  If I restart the program, I can paste what I had copied that caused the crash, but it crashes again next time I use Copy.  It doesn't always crash, and sometimes I can copy many times in a row, but it usually crashes the first time I Copy, each time I start Flash.  It wont crash if what I'm copying is text.  I'm on Mac Sierra, and this does not happen if I start the computer in safe mode.  I've tried reinstalling Flash and cleaning out any purgeable memory including caches and PRAM and stuff.  The problem is easily repeatable.  Any advice would be awesome please, thanks for reading!
        • 1. Re: Flash Pro CS6 crashes from Command-C or Edit > Copy
          Owners of old programs simply have problems with Mac El Capitan/Sierra... none of which is Adobe's fault... Adobe did not change your old program to make it stop working... Apple changed their operating system and THAT is why your old programs won't work, not because of anything Adobe did... Also... every time Apple issues an update, there is the risk that an old program that HAS been working will STOP working... bottom line, old programs require a matching old operating system
          https://forums.adobe.com/thread/2301916 includes a link to install the old Java runtime that is required
          • 2. Re: Flash Pro CS6 crashes from Command-C or Edit > Copy
            Colin Holgate MVP & Adobe Community Professional
            I'll differ to what John said! I'm already running High Sierra, and CS6 continues to work ok.
            You could try reseting preferences, hold down Shift+Command+Option as you open CS6. If you have a Creative Cloud subscription you could reinstall CS6. Make sure your CS6 is up to date:
            Adobe - Adobe Flash - Downloads
            If you have your serial number you could do a new install from this page:
            Download Adobe Creative Suite 6 applications
            Here's the direct link to the old Java runtime John mentioned, though usually old programs don't even run if this is needed and is missing:
            Download Java for OS X 2015-001
            Does the crash happen when you copy anything at all? If it's just certain things, can you post an example somewhere for me to try in CS6, and also in Animate?
            • 3. Re: Flash Pro CS6 crashes from Command-C or Edit > Copy
              kv74063367 Level 1
              Thank you very much.  I "solved" it, but this might come back to bite me later: Go to ~/Library/Caches/ and find the Adobe folder.  Delete all the Adobe folder's contents.  (Now the problem is fixed next time I open flash, but not two times in a row)  Last, set the permissions for the Adobe folder to Read Only for my account.  This stops the crashes.
              If this causes further problems, then I'll try to track down the specific problematic files within ~/Library/Caches/Adobe and only make them empty and read-only.
              • 4. Re: Flash Pro CS6 crashes from Command-C or Edit > Copy
                That seems odd. That folder is read/write for me, and No Access for everyone. Also, neither Animate or Flash Pro seem to be using that folder.
                • 5. Re: Flash Pro CS6 crashes from Command-C or Edit > Copy
                  danielc33727021
                  I am having the same issue in regards to Adobe Flash CS6 crashing every time I try to copy something.  If I use Cmd - C or Right Click - Copy, the result is still the same.  The program crashes and I have to restart the application.  I have already uninstalled and RE-installed the Suite several times and nothing has changed.  I have deleted the system preferences as well, with no change.  Any ideas would be greatly appreciated.
                  Here is the error log:
                  Process:           Adobe Flash CS6 [16088]
                  Path:              /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
                  Identifier:        com.adobe.flash
                  Version:           12.0.0.481 (12.0.0)
                  Code Type:         X86 (Native)
                  Parent Process:    ??? [1]
                  Responsible:       Adobe Flash CS6 [16088]
                  User ID:           501
                  Date/Time:         2018-01-18 01:07:58.196 -0600
                  OS Version:        Mac OS X 10.13.2 (17C205)
                  Report Version:    12
                  Anonymous UUID:    80CB0877-7D5A-6F21-8493-CAE70DBE9D4C
                  Sleep/Wake UUID:   8AC31BA4-613A-4134-8EE1-88D4DB000412
                  Time Awake Since Boot: 23000 seconds
                  Time Since Wake:   10000 seconds
                  System Integrity Protection: enabled
                  Crashed Thread:    0  Dispatch queue: com.apple.main-thread
                  Exception Type:    EXC_CRASH (SIGABRT)
                  Exception Codes:   0x0000000000000000, 0x0000000000000000
                  Exception Note:    EXC_CORPSE_NOTIFY
                  Application Specific Information:
                  terminating with uncaught exception of type CAIOutOfMemoryFault: std::exception
                  abort() called
                  Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                  0   libsystem_kernel.dylib   0xa76f6eae __pthread_kill + 10
                  1   libsystem_pthread.dylib  0xa78284c7 pthread_kill + 363
                  2   libsystem_c.dylib        0xa7646afe abort + 133
                  3   libc++abi.dylib          0xa5ad3ea7 abort_message + 134
                  4   libc++abi.dylib          0xa5ad406a default_terminate_handler() + 250
                  5   libc++abi.dylib          0xa5aed657 std::__terminate(void (*)()) + 14
                  6   libc++abi.dylib          0xa5aed0c1 __cxa_throw + 116
                  7   com.adobe.AILib          0x04242fc4 operator new[](unsigned long) + 116
                  8   com.adobe.flash          0x0085f844 SimpleStreamNS::ISimpleStream::~ISimpleStream() + 860
                  9   com.adobe.flash          0x0085f8ec SimpleStreamNS::ISimpleStream::~ISimpleStream() + 1028
                  10  com.adobe.flash          0x0119380d boost::exception_detail::clone_impl<boost::exception_detail::bad_alloc_>::rethrow() const + 95647
                  11  com.adobe.flash          0x011920ff boost::exception_detail::clone_impl<boost::exception_detail::bad_alloc_>::rethrow() const + 89745
                  12  com.adobe.flash          0x01192352 boost::exception_detail::clone_impl<boost::exception_detail::bad_alloc_>::rethrow() const + 90340
                  13  com.adobe.flash          0x00e0990e SimpleStreamNS::OFilterStream::OutputData(char const*) + 790
                  14  com.adobe.flash          0x003161a5 vc::BasicOperation::~BasicOperation() + 17105
                  15  com.adobe.flash          0x00316729 vc::BasicOperation::~BasicOperation() + 18517
                  16  com.adobe.flash          0x00f95347 CMiniFrameWnd::~CMiniFrameWnd() + 863
                  17  com.adobe.flash          0x00fc3fa4 CPropertyPage::GetRuntimeClass() const + 9792
                  18  com.adobe.flash          0x00f71b21 CButtonImplBase::~CButtonImplBase() + 8129
                  19  com.adobe.flash          0x00fd933a TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 17124
                  20  com.adobe.flash          0x00fda65e TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 22024
                  21  com.adobe.flash          0x00fd5bc6 TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 2928
                  22  com.adobe.flash          0x001feb01 CArray<CTimer*, CTimer*>::~CArray() + 11005
                  23  com.adobe.flash          0x0117277c CList<MMUI::DocumentFrame*, MMUI::DocumentFrame*>::RemoveAt(__POSITION*) + 3866
                  24  com.adobe.flash          0x00fda65e TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 22024
                  25  com.adobe.flash          0x0030ca19 CTemporaryMenu::~CTemporaryMenu() + 1117
                  26  com.adobe.flash          0x00fd5bc6 TextWithHeader<CListCtrlImpl::ColumnHeader>::SetText(unsigned short const*) + 2928
                  27  com.adobe.flash          0x001feb01 CArray<CTimer*, CTimer*>::~CArray() + 11005
                  28  com.adobe.flash          0x004de5a6 CToolsCommandScope::GetAcceleratorsHandle() + 1742
                  29  com.adobe.flash          0x0030cbe2 CTemporaryMenu::~CTemporaryMenu() + 1574
                  30  com.adobe.flash          0x00fe641e CRgn::~CRgn() + 5692
                  31  com.adobe.flash          0x00fc36b3 CPropertyPage::GetRuntimeClass() const + 7503
                  32  com.adobe.flash          0x010632b8 cf_bad_change::~cf_bad_change() + 3550
                  33  com.apple.HIToolbox      0x92f7c746 _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 26
                  34  com.apple.HIToolbox      0x92f296b9 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1948
                  35  com.apple.HIToolbox      0x92f2888a SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374
                  36  com.apple.HIToolbox      0x92f28702 SendEventToEventTargetWithOptions + 40
                  37  com.apple.HIToolbox      0x92f5eaa8 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1006
                  38  com.apple.HIToolbox      0x92f29b5c DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 3135
                  39  com.apple.HIToolbox      0x92f2888a SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374
                  40  com.apple.HIToolbox      0x92f39b1f SendEventToEventTarget + 33
                  41  com.apple.HIToolbox      0x930b7ff3 ToolboxEventDispatcher + 82
                  42  com.apple.HIToolbox      0x930b7ebe RunApplicationEventLoop + 192
                  43  com.adobe.flash          0x00fcc1fb CArray<MACFTYPES*, MACFTYPES*>::SetSize(int, int) + 5271
                  44  com.adobe.flash          0x00fa4c1d CTimerImpl::~CTimerImpl() + 1293
                  45  com.adobe.flash          0x00fa4e00 CTimerImpl::~CTimerImpl() + 1776
                  46  com.adobe.flash          0x0020fc4d std::vector<Symmetry*, std::allocator<Symmetry*> >::vector(std::allocator<Symmetry*> const&) + 6295
                  Thread 1:
                  0   libsystem_kernel.dylib   0xa76f6d26 __psynch_cvwait + 10
                  1   libsystem_pthread.dylib  0xa78264db _pthread_cond_wait + 658
                  2   libsystem_pthread.dylib  0xa7828130 pthread_cond_wait$UNIX2003 + 51
                  3   com.apple.CoreServices.CarbonCore    0x9490e938 TSWaitOnCondition + 113
                  4   com.apple.CoreServices.CarbonCore    0x9490eb2a TSWaitOnConditionTimedRelative + 173
                  5   com.apple.CoreServices.CarbonCore    0x948e8e58 MPWaitOnQueue + 189
                  6   com.adobe.ACE            0x06a2da69 0x69ee000 + 260713
                  7   com.adobe.ACE            0x06a2cd99 0x69ee000 + 257433
                  8   com.apple.CoreServices.CarbonCore    0x948e92a2 PrivateMPEntryPoint + 51
                  9   libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  10  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  11  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 2:
                  Thread 3:
                  Thread 4:
                  Thread 5:
                  Thread 6:
                  Thread 7:
                  Thread 8:
                  3   com.adobe.AFlame         0x0bc0d439 Flame_Terminate + 1281926
                  4   com.adobe.AFlame         0x0bc57950 Flame_Terminate + 1586333
                  5   com.adobe.AFlame         0x0bc0ba35 Flame_Terminate + 1275266
                  6   libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  7   libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  8   libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 9:
                  0   libsystem_kernel.dylib   0xa76f6f9e __recvfrom + 10
                  1   libsystem_c.dylib        0xa7663f00 recv$UNIX2003 + 30
                  2   ServiceManager-Launcher.dylib     0x143c0733 Invoke + 47867
                  3   ServiceManager-Launcher.dylib     0x143bf846 Invoke + 44046
                  4   ServiceManager-Launcher.dylib     0x143be988 Invoke + 40272
                  5   ServiceManager-Launcher.dylib     0x143bea0f Invoke + 40407
                  6   ServiceManager-Launcher.dylib     0x143b9baf Invoke + 20343
                  7   ServiceManager-Launcher.dylib     0x143b9ea7 Invoke + 21103
                  8   ServiceManager-Launcher.dylib     0x143ba685 Invoke + 23117
                  9   ServiceManager-Launcher.dylib     0x143ba8f9 Invoke + 23745
                  10  ServiceManager-Launcher.dylib     0x143bd2a0 Invoke + 34408
                  11  ServiceManager-Launcher.dylib     0x143bd3fd Invoke + 34757
                  12  ServiceManager-Launcher.dylib     0x143bdc91 Invoke + 36953
                  13  ServiceManager-Launcher.dylib     0x143bddb2 Invoke + 37242
                  14  ServiceManager-Launcher.dylib     0x143b0656 Login + 461
                  15  ServiceManager-Launcher.dylib     0x143b409a Login + 15377
                  16  ServiceManager-Launcher.dylib     0x143be165 Invoke + 38189
                  17  ServiceManager-Launcher.dylib     0x143c02eb Invoke + 46771
                  18  libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  19  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  20  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 10:: Java: Exception Handler Thread
                  0   libsystem_kernel.dylib   0xa76ed742 mach_msg_trap + 10
                  1   libsystem_kernel.dylib   0xa76ecd7f mach_msg + 47
                  2   libsystem_kernel.dylib   0xa76ed484 mach_msg_server + 300
                  3   libjvm.dylib             0x5665677a 0x56640000 + 92026
                  4   libjvm.dylib             0x56656603 0x56640000 + 91651
                  5   libjvm.dylib             0x5665508c 0x56640000 + 86156
                  Thread 11:: Java: Gang worker#0 (Parallel GC Threads)
                  2   libjvm.dylib             0x566557e6 0x56640000 + 88038
                  3   libjvm.dylib             0x56655722 0x56640000 + 87842
                  4   libjvm.dylib             0x566555e8 0x56640000 + 87528
                  5   libjvm.dylib             0x5665512d 0x56640000 + 86317
                  6   libjvm.dylib             0x56654fb7 0x56640000 + 85943
                  7   libjvm.dylib             0x5666ca59 0x56640000 + 182873
                  8   libjvm.dylib             0x5666c943 0x56640000 + 182595
                  9   libjvm.dylib             0x5665508c 0x56640000 + 86156
                  10  libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  11  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  12  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 12:: Java: Gang worker#1 (Parallel GC Threads)
                  Thread 13:: Java: Gang worker#2 (Parallel GC Threads)
                  Thread 14:: Java: Gang worker#3 (Parallel GC Threads)
                  Thread 15:: Java: Gang worker#4 (Parallel GC Threads)
                  Thread 16:: Java: Gang worker#5 (Parallel GC Threads)
                  Thread 17:: Java: Gang worker#6 (Parallel GC Threads)
                  Thread 18:: Java: Gang worker#7 (Parallel GC Threads)
                  Thread 19:: Java: Gang worker#0 (Parallel CMS Threads)
                  7   libjvm.dylib             0x5695286e 0x56640000 + 3221614
                  Thread 20:: Java: Gang worker#1 (Parallel CMS Threads)
                  Thread 21:: Java: Concurrent Mark-Sweep GC Thread
                  2   libjvm.dylib             0x566558b6 0x56640000 + 88246
                  3   libjvm.dylib             0x566733ca 0x56640000 + 209866
                  4   libjvm.dylib             0x56655604 0x56640000 + 87556
                  7   libjvm.dylib             0x5677fed5 0x56640000 + 1310421
                  8   libjvm.dylib             0x5677fe43 0x56640000 + 1310275
                  9   libjvm.dylib             0x566731e5 0x56640000 + 209381
                  10  libjvm.dylib             0x5665508c 0x56640000 + 86156
                  11  libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  12  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  13  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 22:: Java: VM Thread
                  7   libjvm.dylib             0x566ee134 0x56640000 + 713012
                  8   libjvm.dylib             0x566eddd3 0x56640000 + 712147
                  Thread 23:: Java: Reference Handler
                  4   libjvm.dylib             0x566fd2a0 0x56640000 + 774816
                  5   libjvm.dylib             0x566fc7a2 0x56640000 + 772002
                  6   libjvm.dylib             0x566fc491 JVM_MonitorWait + 211
                  7   libjvmlinkage.dylib      0x1426add5 JVM_MonitorWait + 69
                  8   ???                      0xb0f339d9 0 + 2968730073
                  9   ???                      0xb0f2be31 0 + 2968698417
                  10  ???                      0xb0f2be31 0 + 2968698417
                  11  ???                      0xb0f29374 0 + 2968687476
                  12  libjvm.dylib             0x566ef4a3 0x56640000 + 717987
                  13  libjvm.dylib             0x566ef215 0x56640000 + 717333
                  14  libjvm.dylib             0x566fc139 0x56640000 + 770361
                  15  libjvm.dylib             0x566fbfc1 0x56640000 + 769985
                  16  libjvm.dylib             0x566fbf40 0x56640000 + 769856
                  17  libjvm.dylib             0x566fbd8d 0x56640000 + 769421
                  18  libjvm.dylib             0x566fbbc3 0x56640000 + 768963
                  19  libjvm.dylib             0x5665508c 0x56640000 + 86156
                  20  libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  21  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  22  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 24:: Java: Finalizer
                  10  ???                      0xb0f2bf97 0 + 2968698775
                  11  ???                      0xb0f2bf97 0 + 2968698775
                  12  ???                      0xb0f29374 0 + 2968687476
                  13  libjvm.dylib             0x566ef4a3 0x56640000 + 717987
                  14  libjvm.dylib             0x566ef215 0x56640000 + 717333
                  15  libjvm.dylib             0x566fc139 0x56640000 + 770361
                  16  libjvm.dylib             0x566fbfc1 0x56640000 + 769985
                  17  libjvm.dylib             0x566fbf40 0x56640000 + 769856
                  18  libjvm.dylib             0x566fbd8d 0x56640000 + 769421
                  19  libjvm.dylib             0x566fbbc3 0x56640000 + 768963
                  20  libjvm.dylib             0x5665508c 0x56640000 + 86156
                  21  libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  22  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  23  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 25:: Java: Surrogate Locker Thread (Concurrent GC)
                  6   libjvm.dylib             0x56654efa 0x56640000 + 85754
                  7   libjvm.dylib             0x5670d58c 0x56640000 + 841100
                  8   libjvm.dylib             0x5670d4d0 0x56640000 + 840912
                  9   libjvm.dylib             0x566fbd8d 0x56640000 + 769421
                  10  libjvm.dylib             0x566fbbc3 0x56640000 + 768963
                  11  libjvm.dylib             0x5665508c 0x56640000 + 86156
                  12  libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  13  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  14  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 26:: Java: Signal Dispatcher
                  0   libsystem_kernel.dylib   0xa76ed77e semaphore_wait_trap + 10
                  1   libjvm.dylib             0x5670de7a 0x56640000 + 843386
                  2   libjvm.dylib             0x5670d850 0x56640000 + 841808
                  3   libjvm.dylib             0x566fbd8d 0x56640000 + 769421
                  4   libjvm.dylib             0x566fbbc3 0x56640000 + 768963
                  Thread 27:: Java: C1 CompilerThread0
                  7   libjvm.dylib             0x5671590e 0x56640000 + 874766
                  8   libjvm.dylib             0x5670f060 0x56640000 + 847968
                  9   libjvm.dylib             0x5670ee0a 0x56640000 + 847370
                  10  libjvm.dylib             0x566fbd8d 0x56640000 + 769421
                  11  libjvm.dylib             0x566fbbc3 0x56640000 + 768963
                  12  libjvm.dylib             0x5665508c 0x56640000 + 86156
                  13  libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  14  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  15  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 28:: Java: Low Memory Detector
                  7   libjvm.dylib             0x5670fda0 0x56640000 + 851360
                  Thread 29:: Java: VM Periodic Task Thread
                  4   libjvm.dylib             0x56712951 0x56640000 + 862545
                  Thread 30:: Java: FelixDispatchQueue
                  11  ???                      0xb0f2be31 0 + 2968698417
                  12  ???                      0xb0f2be31 0 + 2968698417
                  13  ???                      0xb0f2c30d 0 + 2968699661
                  14  ???                      0xb0f29374 0 + 2968687476
                  15  libjvm.dylib             0x566ef4a3 0x56640000 + 717987
                  16  libjvm.dylib             0x566ef215 0x56640000 + 717333
                  17  libjvm.dylib             0x566fc139 0x56640000 + 770361
                  18  libjvm.dylib             0x566fbfc1 0x56640000 + 769985
                  19  libjvm.dylib             0x566fbf40 0x56640000 + 769856
                  20  libjvm.dylib             0x566fbd8d 0x56640000 + 769421
                  21  libjvm.dylib             0x566fbbc3 0x56640000 + 768963
                  22  libjvm.dylib             0x5665508c 0x56640000 + 86156
                  23  libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  24  libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  25  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 31:: Java: FelixStartLevel
                  11  ???                      0xb0f2c30d 0 + 2968699661
                  Thread 32:: Java: FelixPackageAdmin
                  Thread 33:: Java: Code Model Worker
                  3   libjvm.dylib             0x568fbfa9 0x56640000 + 2867113
                  4   libjvm.dylib             0x5693d0c2 0x56640000 + 3133634
                  5   ???                      0xb0f339d9 0 + 2968730073
                  6   ???                      0xb0f2be31 0 + 2968698417
                  7   ???                      0xb0f2be31 0 + 2968698417
                  8   ???                      0xb0f2c30d 0 + 2968699661
                  9   ???                      0xb0f2c473 0 + 2968700019
                  Thread 34:: Java: Code Model Worker
                  Thread 35:
                  0   libsystem_kernel.dylib   0xa76f7126 __semwait_signal + 10
                  1   libsystem_c.dylib        0xa7663df7 nanosleep$UNIX2003 + 189
                  2   com.adobe.flash.flbridge 0x3afdf93b ScObjects::Thread::sleep(unsigned int) + 59
                  3   com.adobe.flash.flbridge 0x3afdb799 ScObjects::BridgeTalkThread::run() + 185
                  4   com.adobe.flash.flbridge 0x3afdfca8 ScObjects::Thread::go(void*) + 168
                  5   libsystem_pthread.dylib  0xa782550d _pthread_body + 347
                  6   libsystem_pthread.dylib  0xa78253b2 _pthread_start + 357
                  7   libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 36:
                  1   libsystem_pthread.dylib  0xa7826525 _pthread_cond_wait + 732
                  2   libsystem_pthread.dylib  0xa7826244 pthread_cond_wait + 25
                  3   com.macromedia.Flash Player.authplaylib    0x1a80411f 0x1a3b4000 + 4522271
                  4   com.macromedia.Flash Player.authplaylib    0x1a3ce25f 0x1a3b4000 + 107103
                  5   com.macromedia.Flash Player.authplaylib    0x1a80420c 0x1a3b4000 + 4522508
                  6   com.macromedia.Flash Player.authplaylib    0x1a804250 0x1a3b4000 + 4522576
                  7   com.macromedia.Flash Player.authplaylib    0x1a804376 0x1a3b4000 + 4522870
                  10  libsystem_pthread.dylib  0xa7824a8e thread_start + 34
                  Thread 37:
                  Thread 38:
                  Thread 39:
                  Thread 40:: com.apple.NSURLConnectionLoader
                  2   com.apple.CoreFoundation 0x9394d3b8 __CFRunLoopServiceMachPort + 296
                  3   com.apple.CoreFoundation 0x9394c3a6 __CFRunLoopRun + 2262
                  4   com.apple.CoreFoundation 0x9394b7a1 CFRunLoopRunSpecific + 641
                  5   com.apple.CoreFoundation 0x9394b50a CFRunLoopRunInMode + 122
                  6   com.apple.CFNetwork      0x92dc1f55 -[__CoreSchedulingSetRunnable runForever] + 663
                  7   com.apple.CFNetwork      0x92dc2686 +[__CoreSchedulingSetRunnable _run:] + 129
                  8   com.apple.Foundation     0x9532afe8 -[NSThread main] + 39
                  9   com.apple.Foundation     0x9532ae6c __NSThread__start__ + 1269
                  Thread 41:: com.apple.CFSocket.private
                  0   libsystem_kernel.dylib   0xa76f707e __select + 10
                  1   com.apple.CoreFoundation 0x93985899 __CFSocketManager + 777
                  Thread 42:
                  0   libsystem_kernel.dylib   0xa76f76ee __workq_kernreturn + 10
                  1   libsystem_pthread.dylib  0xa7825090 _pthread_wqthread + 1536
                  2   libsystem_pthread.dylib  0xa7824a6a start_wqthread + 34
                  Thread 43:
                  1   libsystem_pthread.dylib  0xa7824e9b _pthread_wqthread + 1035
                  Thread 44:
                  Thread 45:
                  1   libsystem_pthread.dylib  0xa7824e70 _pthread_wqthread + 992
                  Thread 46:
                  Thread 47:
                  2   com.adobe.flash          0x00f4767b void std::sort<__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)>(__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, __gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)) + 101302
                  3   com.adobe.flash          0x00f442b9 void std::sort<__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)>(__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, __gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)) + 88052
                  4   com.adobe.flash          0x00f479e8 void std::sort<__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)>(__gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, __gnu_cxx::__normal_iterator<ColorCube**, std::vector<ColorCube*, std::allocator<ColorCube*> > >, bool (*)(ColorCube*, ColorCube*)) + 102179
                  Thread 48:: Java: Thread-4
                  3   libjvm.dylib             0x5678ad05 0x56640000 + 1355013
                  4   libjvm.dylib             0x5678e23a JVM_Sleep + 254
                  5   libjvmlinkage.dylib      0x1426b9c8 JVM_Sleep + 72
                  6   ???                      0xb0f339d9 0 + 2968730073
                  9   ???                      0xb0f29374 0 + 2968687476
                  10  libjvm.dylib             0x566ef4a3 0x56640000 + 717987
                  11  libjvm.dylib             0x566ef215 0x56640000 + 717333
                  12  libjvm.dylib             0x566fc139 0x56640000 + 770361
                  13  libjvm.dylib             0x566fbfc1 0x56640000 + 769985
                  14  libjvm.dylib             0x566fbf40 0x56640000 + 769856
                  15  libjvm.dylib             0x566fbd8d 0x56640000 + 769421
                  16  libjvm.dylib             0x566fbbc3 0x56640000 + 768963
                  17  libjvm.dylib             0x5665508c 0x56640000 + 86156
                  Thread 49:
                  2   libsystem_pthread.dylib  0xa7827872 pthread_cond_timedwait_relative_np + 27
                  3   com.macromedia.Flash Player.authplaylib    0x1a8040e7 0x1a3b4000 + 4522215
                  4   com.macromedia.Flash Player.authplaylib    0x1a5949de 0x1a3b4000 + 1968606
                  Thread 0 crashed with X86 Thread State (32-bit):
                    eax: 0x00000000  ebx: 0xa9b301c0  ecx: 0xbfffe27c  edx: 0x00000000
                    edi: 0xa782836a  esi: 0x0000002d  ebp: 0xbfffe2a8  esp: 0xbfffe27c
                     ss: 0x00000023  efl: 0x00000206  eip: 0xa76f6eae   cs: 0x0000000b
                     ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
                    cr2: 0xa9b15330
                  Logical CPU: 0
                  Error Code:  0x00080148
                  Trap Number: 132
                  Binary Images:
                  0x1000 -  0x1b81fe7 +com.adobe.flash (12.0.0.481 - 12.0.0) <CFAB9248-6011-0498-4D7A-985E1FB68592> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/Adobe Flash CS6
                  0x272a000 -  0x2735ff7 +libChar16.dylib (1) <5E278E11-8234-CB11-AAC9-090FBD037DB7> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/libChar16.dylib
                  0x273e000 -  0x2760fff +libCoreTypes.dylib (1) <5799BD8C-B334-518F-3F6F-EAA503B43831> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/MacOS/libCoreTypes.dylib
                  0x2778000 -  0x2778ffb +com.adobe.SPBasic (SPBasic version 16.0.0 - 16.0.0.646) <936C3F3E-8DDD-50EC-D247-C1F242633914> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
                  0x277d000 -  0x27c2fdf  dyld (519.2.2) <7B7B05B7-204A-38FF-BD32-4CBB51752DD4> /usr/lib/dyld
                  0x2806000 -  0x299afff +com.adobe.PlugPlug (3.0.0.383 - 3.0.0.383) <2205B6E1-7C9E-1892-EC68-C1B326C727A8> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                  0x2a42000 -  0x2b2afe3 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <2540764B-C2F2-61D7-EFBA-6663171FD19A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                  0x2bbb000 -  0x2c59fe3 +libicucnv.40.0.dylib (40) <D11DC46F-D58E-B17C-9356-46F593D5A7CF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
                  0x2c7b000 -  0x2db0fe7 +libicui18n.40.0.dylib (40) <8BE3FE71-0CE6-2B93-B5F2-B4F0DD274B91> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/libicui18n.40. 0.dylib
                  0x2e24000 -  0x2f15fef +libicuuc.40.0.dylib (40) <4CF7066A-6E82-FF80-93E6-6849149FBB98> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/libicuuc.40.0.dylib
                  0x2f52000 -  0x3c97ff7 +libicudata.40.0.dylib (40) <015E6351-4F42-00C1-2096-BEE385B275B1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
                  0x3caa000 -  0x3ed8fff  com.apple.carbonframeworktemplate (1.0 - 1.0) <9F3FE9F2-8834-4654-C0D0-F4F356E6A906> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/Xerces.framework/Versions/A/Xerces
                  0x418f000 -  0x57f9fff +com.adobe.AILib (AILib version 16.0.0 - 16.0.0.646) <317A871E-E0A5-8C5E-B60F-7448ADEBEDBD> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
                  0x6872000 -  0x68cdfff +com.adobe.aiport (aiport version 16.0.0 - 16.0.0.646) <59612576-B2F2-BF25-B09D-6120A3B1462C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AIPort.framework/Versions/A/aiport
                  0x690d000 -  0x696dfff +com.adobe.filterport (filterport version 16.0.0 - 16.0.0.646) <AF193FFA-F555-2379-81B3-7DA07698E466> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FilterPort.framework/Versions/A/filterport
                  0x69b8000 -  0x69d4ff9 +AdobePDFSettings (1) /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
                  0x69ee000 -  0x6b6aff3 +com.adobe.ACE (AdobeACE 2.19.18.19822 - 2.19.18.19822) <2EC89B0E-6B51-4F7F-314A-FB6E18BFC36D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                  0x6b79000 -  0x7114fef +com.adobe.AGM (AdobeAGM 4.26.20.19822 - 4.26.20.19822) <F394945E-943B-B99F-9B45-07E96C293C05> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                  0x7184000 -  0x71befef +com.adobe.ARE (AdobeARE 1.5.02.19822 - 1.5.02.19822) <2A3CBF43-F63E-B5B6-19EA-A2C392CA92F4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                  0x71c4000 -  0x71dffff +com.adobe.BIB (AdobeBIB 1.2.02.19822 - 1.2.02.19822) <CD35337B-CA58-50D9-5AAE-74E720CCE415> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                  0x71e5000 -  0x720bfff +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <606DA5E0-CCB3-90B2-3971-A48349DA046A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                  0x7211000 -  0x7538ffb +com.adobe.CoolType (AdobeCoolType 5.10.31.19822 - 5.10.31.19822) <A5344CC0-BD71-A071-A001-EDB3A28B9A8D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                  0x7570000 -  0x796bfe7 +com.adobe.MPS (AdobeMPS 5.8.0.19673 - 5.8.0.19673) <D65ABA15-80D2-3F1C-2500-EEF873019149> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                  0x79c8000 -  0x7accfef +com.adobe.PDFPort (AdobePDFPort 2.1.0.19734 - 2.1.0.19734) <71232DFD-06FB-837B-8246-BD20F862B5E3> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
                  0x7ae5000 -  0x82ddffb +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 10.0.1.18562) <F24575DF-1B4D-B13E-1525-3C7F5CB88B3E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                  0x8368000 -  0x8390feb +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636) <C38ACBCE-04AA-DF40-FF79-29377F25CDAF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
                  0x83af000 -  0x83d7ff3 +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.7.101.18636 - 3.7.101.18636) <AD333DEF-C5AC-1F75-0486-DF86F89433CD> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
                  0x83f6000 -  0x8452fef +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <123A0829-A85B-6E67-0E48-4F37B08E4C03> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                  0x845b000 -  0x84d3fe3 +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 66.145433) <EF13921E-1CC6-2891-0EEC-D8D8C68D5D87> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                  0x84e2000 -  0x86c1ffb +com.adobe.owl (AdobeOwl version 4.0.93 - 4.0.93) <D102FCD2-496D-5322-AEC0-7A5091CAA2CA> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                  0x86ee000 -  0x979aff3 +com.adobe.psl (AdobePSL 13.0.0.19655 - 13.0.0.19655) <47A9AAEC-43CD-17C9-6E58-6312315FC15D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                  0x9913000 -  0x9b3dffb +com.adobe.linguistic.LinguisticManager (6.0.0 - 17018) <DE928A0E-AE8F-4FB7-6B6C-C52E4FD366A1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                  0x9baf000 -  0x9bb2ffb +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <6CE1936E-6AC7-6900-769B-876CBB68B5BC> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                  0x9bba000 -  0x9fedffb +com.adobe.dvaui.framework (5.0.0 - 5.0.0.0) <EAD7D965-79BB-EA89-AB42-692578840BA8> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                  0xa426000 -  0xa5dbff3 +com.adobe.dvacore.framework (5.0.0 - 5.0.0.0) <EDDA1DA8-726A-0F1E-8733-CF6A482F307C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                  0xa729000 -  0xab3cfe7 +com.adobe.dvaadameve.framework (5.0.0 - 5.0.0.0) <E717BB78-EC59-A9C3-B02B-91A7D46DDBB3> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                  0xb14d000 -  0xb22fff3 +com.adobe.amtlib (amtlib 6.0.0.93 - 6.0.0.93) <2218F05B-09B7-AE0E-5EF7-98FBA5DF9C86> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                  0xb23e000 -  0xb2abffb +com.adobe.headlights.LogSessionFramework (2.1.2.1652) <82DA9279-45D2-AD40-C86C-F5A94B9DAAFF> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                  0xb2fa000 -  0xb32eff7 +com.adobe.pip (6.0.0.1654) <21A87289-747E-A0BD-2692-F9E844932E26> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
                  0xb33a000 -  0xb47afeb +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <6D085279-1185-E7F0-B0D8-FBADBA062516> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                  0xb4ec000 -  0xb4f4ff7 +com.adobe.boost_date_time.framework (5.0.0 - 5.0.0.0) <6397AF50-419F-3030-C6D6-A28D34CF3412> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                  0xb50c000 -  0xb524ff3 +com.adobe.boost_filesystem.framework (5.0.0 - 5.0.0.0) <8DC64C9A-155F-DE79-3521-8869C4A2661D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                  0xb545000 -  0xb5efffb +com.adobe.boost_regex.framework (5.0.0 - 5.0.0.0) <F143073E-6033-B137-7633-9601D846FC1A> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                  0xb674000 -  0xb67fff7 +com.adobe.boost_signals.framework (5.0.0 - 5.0.0.0) <5F9FB957-8AC2-A2FD-1518-9F9D978B0C58> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                  0xb693000 -  0xb695ff3 +com.adobe.boost_system.framework (5.0.0 - 5.0.0.0) <5641DBC5-37C4-7349-4BB4-FC19F46EEFFC> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                  0xb69b000 -  0xb6a7ff7 +com.adobe.boost_threads.framework (5.0.0 - 5.0.0.0) <6F6A3465-894D-2E05-9FDE-16A15486E583> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                  0xb6c3000 -  0xb876fe3 +com.adobe.AFlamingo (AFlamingo 2.3.102.19287 - 2.3.102.19287) <A04AE11D-8128-3324-295F-504CBAD447E1> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
                  0xb892000 -  0xb899ffb +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <B711CAA7-29D6-D5CF-CE1B-A611896C8D87> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                  0xb8a1000 -  0xb96afeb +FlashIK Framework (1.0) <A8AFFB46-F2F7-FBFF-CF77-6BC999E1D266> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
                  0xb9f3000 -  0xba27ff7 +com.adobe.pff.framework (1.0 - 1.0) <E053457E-4AA0-D931-14AF-37BFE91AA1E4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
                  0xba50000 -  0xc3f3fef +com.adobe.AFlame (AFlame 2.03.54.19287 - 2.03.54.19287) <21495560-EA23-BCA2-8E91-9F0C1EF440EB> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
                  0xc467000 -  0xc496fff +com.adobe.contextui.framework (5.0.0 - 5.0.0.0) <109B01C7-7CB9-D3CA-2CBB-B8D4ADC7AE3E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/contextui.framework/Versions/A/contextui
                  0xc4dd000 -  0xc501fe7 +com.adobe.dvaunittesting.framework (5.0.0 - 5.0.0.0) <B32EF0E4-EBCF-6A17-56B2-FC5F2A969F45> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                  0xc539000 -  0xc558fff +libtbb.dylib (0) <6EA19434-60D6-505D-CB6F-5CA562A0F2A7> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/libtbb.dylib
                  0xc56f000 -  0xc577fef +libtbbmalloc.dylib (0) <7A79ED70-A4AC-737A-2FAA-63B6FB29D4ED> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/libtbbmalloc.dylib
                  0xc586000 -  0xc641fef +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.4 -f 49 - 66.145661) <B8855D3A-C827-D9EB-040E-F808043458DA> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                  0xc670000 -  0xc673ffb +com.adobe.dvaflashview.framework (5.0.0 - 5.0.0.0) <F06AF987-2A15-A8B9-11C9-2368422D061E> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
                  0xc682000 -  0xc754fff +com.adobe.dvaworkspace.framework (5.0.0 - 5.0.0.0) <2B746397-82F4-3C89-28C1-1EC7EE317435> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                  0xc8c3000 -  0xc8c4fff  com.apple.textencoding.unicode (4.0 - 4.0) <A4BE917A-9F3D-34B6-B086-C1B86D325BB3> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                  0xf7f3000 -  0xf7f4ff3 +com.macromedia.Flash.flastoragelib (9.0 - 9.0) <AB678254-543D-CC50-3CF8-EC0AA01D99D4> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
                  0x12345000 - 0x12347ff7 +com.macromedia.Flash.FLfile (12.0.0.481 - 12.0.0) <639D8AF3-69A7-4D91-5826-F54C86AB1BD1> /Applications/Adobe Flash CS6/*/FLfile.bundle/Contents/MacOS/FLfile
                  0x140d3000 - 0x140e6ff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.18561 - 1.1.0.18561) <5A153C87-DD7A-CE28-2E93-7DC120D4244F> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
                  0x14256000 - 0x1425affb  com.apple.audio.AppleHDAHALPlugIn (280.12 - 280.12) <687E756D-6AAB-32A7-917F-6CC8E2CCBAE0> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                  0x1426a000 - 0x14271ffb +libjvmlinkage.dylib (1) <D9427B46-8FEB-3FA9-AC0C-3E0FA4824320> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
                  0x14284000 - 0x1428bfff +libverify.dylib (1.0 - 1.0) <683BCE2E-6200-3734-A926-10129E43A284> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
                  0x14290000 - 0x142adfff +libjava.jnilib (1) <FCA2018B-641E-32C8-8978-1935FF8F8544> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
                  0x142cb000 - 0x142d7fff +libzip.jnilib (1) <788F148B-73D1-30C5-8310-DE41C9206221> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
                  0x143ab000 - 0x143d2ffb +ServiceManager-Launcher.dylib (389) <4EEAF886-0B48-9FF4-BE65-41E222123A50> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
                  0x143dc000 - 0x143ebfff +com.yourcompany.PointGrid (1.0) <2CB987CD-6752-D333-7F4F-A6713A901947> /Applications/Adobe Flash CS6/*/PointGrid.bundle/Contents/MacOS/PointGrid
                  0x14600000 - 0x14622ff7 +com.adobe.flash.cs6.airAndroid (12.0.0.0 - 12.0.0) <48421B0A-923E-5940-9F04-B00DA3A75C11> /Applications/Adobe Flash CS6/*/Air_Android.bundle/Contents/MacOS/Air_Android
                  0x14636000 - 0x1465eff7 +com.adobe.flash.cs6.air (12.0.0.0 - 12.0.0) <871E06CB-E151-DD97-46AB-A8B2E9D75665> /Applications/Adobe Flash CS6/*/Air_Desktop_iOS.bundle/Contents/MacOS/Air_Desktop_iOS
                  0x15800000 - 0x15d3efff  com.apple.driver.AppleIntelHD4000GraphicsGLDriver (10.30.12 - 10.3.0) <3A85569D-C753-365C-AEF0-67704DB7CB96> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD4000GraphicsGLDriver
                  0x197b1000 - 0x197c0fff  libSimplifiedChineseConverter.dylib (70) <7F4EA439-FF06-3CF8-9FD0-6B69059104E6> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                  0x197c5000 - 0x197d7fff  libTraditionalChineseConverter.dylib (70) <A421E237-655C-304A-A73E-E31B0713F46C> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                  0x1a3b4000 - 0x1ada6ff3 +com.macromedia.Flash Player.authplaylib (10.2.153.2 - 10.2.153.2) <3CFE191B-E5E1-6C47-46DB-FE24C06872B7> /Applications/Adobe Flash CS6/*/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
                  0x1b048000 - 0x1b3b2fff  com.apple.RawCamera.bundle (8.02.0 - 1017.2.2) <2BA977FD-99E8-3614-B754-535CDF1776D2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                  0x1b40a000 - 0x1b47cfef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <E4ADECD5-05B4-E78B-09D8-E45FD640E84D> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                  0x1bbd9000 - 0x1bc2dfe7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <0B80F7A7-EC10-A7C7-5E6E-787953553C55> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                  0x1bd04000 - 0x1bd47ff3 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <4B40551F-5306-C836-02AD-109826BD580C> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
                  0x3afbe000 - 0x3b005fff +com.adobe.flash.flbridge (12.0.0.481 - 12.0.0) <9301CA9F-DABA-0BB4-84D3-B9DAE690711D> /Applications/Adobe Flash CS6/*/FLBridge.bundle/Contents/MacOS/FLBridge
                  0x40000000 - 0x400c4fe3 +com.adobe.JP2K (2.0.0 - 2.0.0.18562) <FFA540EA-6CEB-F4D1-E0EF-A844A536D499> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                  0x45811000 - 0x4586efef +com.yourcompany.Brush (1.0) <2136D27E-974D-81F0-6078-492B233E16FC> /Applications/Adobe Flash CS6/*/Brush.bundle/Contents/MacOS/Brush
                  0x50611000 - 0x50694ffb +com.yourcompany.Collision (1.0) <F0E00160-1946-C591-89EC-FBD99ACCC449> /Applications/Adobe Flash CS6/*/Collision.bundle/Contents/MacOS/Collision
                  0x55000000 - 0x55101fff +com.yourcompany.Stroke (1.0) <B1BDF135-128A-A5D9-3EC0-E0EBEC447500> /Applications/Adobe Flash CS6/*/Stroke.bundle/Contents/MacOS/Stroke
                  0x56640000 - 0x569a8fe6 +libjvm.dylib (1) <FD52FA39-2545-3053-AB1C-354995E08DDD> /Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm.dylib
                  0x869aa000 - 0x87558ff3 +com.adobe.flash.createjs (1.1.0.0 - 1.1.0) <D9B1E8C1-68E2-3A8E-91BC-7B2807F535F9> /Users/USER/Library/Application Support/Adobe/*/FLCreateJS.bundle/Contents/MacOS/FLCreateJS
                  0x90015000 - 0x9001cfff  com.apple.agl (3.3.1 - AGL-3.3.1) <DE1399CF-739C-3AAC-AAFC-766D4AAFD282> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                  0x9001d000 - 0x901d8ff7  com.apple.avfoundation (2.0 - 1528.24) <1A334EEE-99A1-3F7A-A14B-0D987EE1F193> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                  0x901d9000 - 0x90296ff7  com.apple.audio.AVFAudio (1.0 - ???) <5658CF45-3305-3112-9394-510CF049EF6C> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                  0x90298000 - 0x90298fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <F4A138F5-290D-3413-AD17-ECD395935FF3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                  0x90299000 - 0x902afffb  libCGInterfaces.dylib (417) <92B03F58-1974-35E7-BC7F-28B6B285A860> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                  0x902b0000 - 0x909f1fdf  com.apple.vImage (8.1 - ???) <591C941E-6475-347E-89DA-F541E88F949A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                  0x909f2000 - 0x90b2dff7  libBLAS.dylib (1211.30.1) <A850E0E2-3A72-3916-9907-AF1E7ECC95F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                  0x90b2e000 - 0x90b5bffb  libBNNS.dylib (37) <C29094A0-5C89-3C5E-AB37-510C28588E2E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                  0x90b5c000 - 0x90ecffff  libLAPACK.dylib (1211.30.1) <2DDDE838-0FF1-3679-8E62-9C09923ECB7E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                  0x90ed0000 - 0x90ee6ffb  libLinearAlgebra.dylib (1211.30.1) <8A120E75-CAF4-3CAE-BBE6-E2F5FAE44DB8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                  0x90ee7000 - 0x90f00ff7  libSparseBLAS.dylib (1211.30.1) <0C5E0EF4-E9A5-3FC4-B7A3-1FE59DB4A2AA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                  0x90f01000 - 0x9105ffc7  libvDSP.dylib (622.20.8) <C5F16300-061F-3DF0-B91E-8BD0D2173351> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                  0x91060000 - 0x9113effb  libvMisc.dylib (622.20.8) <1C8D5D80-F32C-3853-8309-57C8A82B7DA5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                  0x9113f000 - 0x9113ffff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7A0D5DD6-C302-390D-9178-0B2EA94BB5ED> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                  0x91333000 - 0x920f4ffb  com.apple.AppKit (6.9 - 1561.20.106) <5EC573DC-BD5D-3901-AC06-65690425A1B1> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x92146000 - 0x92146fff  com.apple.ApplicationServices (48 - 50) <BFE7FB45-365B-341F-A8FC-B9483AE87709> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                  0x92147000 - 0x921adff3  com.apple.ApplicationServices.ATS (377 - 445) <CD3D5685-2BB9-3A7B-AC97-2A74A81CB7CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                  0x921ae000 - 0x921affff  ATSHI.dylib (445) <A8BA760D-02EE-3EB5-B39C-1C67A2699275> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                  0x921b0000 - 0x922d4ff3  libFontParser.dylib (222.1.2) <8F7D388A-299C-3C6D-9864-40EC0914A96B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                  0x922d5000 - 0x92321ffb  libFontRegistry.dylib (221) <8D81FDCF-F05D-3556-AB6D-090F9508C25E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                  0x92370000 - 0x923a3ff3  libTrueTypeScaler.dylib (222.1.2) <CFBA5950-79C1-32F9-9DB4-902A31A72EFE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                  0x923a4000 - 0x9240eff7  libType1Scaler.dylib (136) <260982B2-CA75-36CB-89F5-27008AD3CBFC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
                  0x9240f000 - 0x92414fff  com.apple.ColorSyncLegacy (4.13.0 - 1) <AB5CE7D2-8BE5-35C8-A9D5-ED0FB5BAB7D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncL egacy.framework/Versions/A/ColorSyncLegacy
                  0x924be000 - 0x92515ff7  com.apple.HIServices (1.22 - 622) <8544026A-17BE-301D-BA2A-782F3AD864DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                  0x92516000 - 0x92525ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <E3245701-039B-353F-923D-F81B2242842C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                  0x92526000 - 0x9257effb  com.apple.print.framework.PrintCore (13 - 503) <FD0F7A18-6F78-34C9-B067-B3AB76C3D4C8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                  0x9257f000 - 0x92615ffb  com.apple.QD (3.12 - 403) <372AFF26-17D1-3C6F-9E47-17C955C2045B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                  0x92616000 - 0x92622ff3  com.apple.speech.synthesis.framework (7.2.1 - 7.2.1) <A0201575-0BFF-3C43-99C6-9DB3861F8A07> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                  0x92623000 - 0x9286fff3  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <489BC806-28CC-3340-BB52-D37A65CADEC9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                  0x92871000 - 0x92871fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <3CF15BE4-B8D9-3D92-AB17-B613CD0BFBFE> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                  0x92b8f000 - 0x92efcffb  com.apple.CFNetwork (893.13.1 - 893.13.1) <960BA636-F94A-3DF7-B587-3165654BF020> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                  0x92f11000 - 0x92f11fff  com.apple.Carbon (158 - 158) <1545E2E8-F562-33D6-8DA7-5FD34045B314> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                  0x92f12000 - 0x92f1bff3  com.apple.audio.SoundManager (4.2 - 4.2) <83AE7AA9-8661-3449-99F4-291A42640692> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                  0x92f1c000 - 0x92f20fff  com.apple.CommonPanels (1.2.6 - 98) <DA1D99A4-53F6-31AF-964D-86739FA74B52> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                  0x92f21000 - 0x932b7ffb  com.apple.HIToolbox (2.1.1 - 910.4) <16D13C1E-B4A1-3AF0-A7A3-B3AC344D25F6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                  0x932b8000 - 0x9330cffb  com.apple.htmlrendering (77 - 1.1.4) <BAF5C846-FF50-3C80-97F5-71F1399CA85C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                  0x9330d000 - 0x93310fff  com.apple.help (1.3.8 - 64) <1E913488-5D7B-388E-904D-64EF8C99E704> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                  0x93311000 - 0x93316ffb  com.apple.ImageCapture (9.0 - 9.0) <1887749B-D641-3057-B91F-3C2D8E990115> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                  0x93317000 - 0x933b1ffb  com.apple.ink.framework (10.9 - 220) <5340E055-BD3D-35AD-9797-F22E1ECEDAC6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                  0x933b2000 - 0x933ecfff  com.apple.NavigationServices (3.8 - 227) <6B1000C3-9C00-33F5-88D5-62F6BD5DD7F8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                  0x933ed000 - 0x93408ffb  com.apple.openscripting (1.7 - 174) <CD281A8D-54C8-3201-B9F7-DE2439088302> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                  0x93409000 - 0x9340efff  com.apple.print.framework.Print (12 - 267) <F7BEF8BA-7D1F-34A2-97B8-D49F20886644> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                  0x9340f000 - 0x93411fff  com.apple.securityhi (9.0 - 55006) <E9FF8254-B8E1-312A-8FC3-2B4EA8CE9AEA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                  0x93412000 - 0x93418fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C27FB7B-A467-3171-A73B-8C9B403028E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                  0x93419000 - 0x93419fff  com.apple.Cocoa (6.11 - 22) <299860CC-316E-3580-B0A3-3BF73B6E80E8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                  0x93426000 - 0x934e5ff7  com.apple.ColorSync (4.13.0 - 546) <DACC5623-8E37-3134-9562-4E8601127F67> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
                  0x934e6000 - 0x93581fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <D0803409-87D1-3794-8A6C-C06AE7CA94AD> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                  0x935df000 - 0x935e4fff  com.apple.CoreBluetooth (1.0 - 1) <E0F40A70-9E04-31FE-A4C8-BE05F6432BAD> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                  0x935e5000 - 0x938c5fff  com.apple.CoreData (120 - 849.2) <E17C36CB-6DED-36F4-930C-AD056F0F5953> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                  0x938c6000 - 0x938ccff3  com.apple.CoreDisplay (1.0 - 81.7) <CF8FEFA1-D61A-30D9-A79F-342A55C71133> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
                  0x938cd000 - 0x93d57ff3  com.apple.CoreFoundation (6.9 - 1450.16) <5FAD88AF-D901-3D54-9480-BFD8BBB95A09> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                  0x93d59000 - 0x94388ffb  com.apple.CoreGraphics (2.0 - 1129.5) <20752785-E9DA-3CC6-ACDD-5A82AD344209> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                  0x9438a000 - 0x94600ffb  com.apple.CoreImage (13.0.0 - 579.2.9) <D91C42B6-CBEE-39AE-A4EA-22D3DE1C96B7> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                  0x946bc000 - 0x9479dfff  com.apple.CoreMedia (1.0 - 2267.40.5) <7D2BE382-4A76-3A7A-978C-0C8CD9B84B2E> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                  0x9479e000 - 0x947f0fff  com.apple.CoreMediaIO (812.0 - 4993) <78FA5884-4BE4-366F-AAAD-8831A8978C0F> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                  0x947f1000 - 0x947f1fff  com.apple.CoreServices (822.19 - 822.19) <5BEC50B1-0B38-3237-8D48-7858156721F5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                  0x947f2000 - 0x94864ff3  com.apple.AE (735.1 - 735.1) <3E1B0CED-0AC3-3252-AEDD-5D8F91E3AAA7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                  0x94865000 - 0x94b43ffb  com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <E61EA71D-294F-3C8B-95BD-0CDBA0FFC907> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                  0x94b44000 - 0x94b78ff3  com.apple.DictionaryServices (1.2 - 284) <56BEF6B8-50D2-38A0-9EF2-D7093E9AAB56> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                  0x94b79000 - 0x94b81fff  com.apple.CoreServices.FSEvents (1239 - 1239) <CABC21F7-E3AB-3954-ACBE-B8066A37516A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                  0x94b82000 - 0x94ce0fff  com.apple.LaunchServices (822.19 - 822.19) <44D623FB-2F50-3322-BEEC-A6A2DD3CD9E6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                  0x94ce1000 - 0x94d8dff7  com.apple.Metadata (10.7.0 - 1191.2.6) <6CE69880-6AF3-3A1A-A8E0-F89FC750EE4C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                  0x94d8e000 - 0x94decff7  com.apple.CoreServices.OSServices (822.19 - 822.19) <CA9178CA-70B1-3BDC-B61B-A176DD7CE7F9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                  0x94ded000 - 0x94e5eff3  com.apple.SearchKit (1.4.0 - 1.4.0) <FAD60011-970B-3889-B6BD-3715CCF599CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                  0x94e5f000 - 0x94e82fff  com.apple.coreservices.SharedFileList (71.4 - 71.4) <CD97E31D-0354-36AB-9997-C4FAF3221D30> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                  0x94e83000 - 0x94fceffb  com.apple.CoreText (352.0 - 578.12) <6389222B-6B26-3F46-93C2-ABE07168227F> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                  0x94fcf000 - 0x95009ff3  com.apple.CoreVideo (1.8 - 279.2) <0D75C395-3C86-3539-9206-C7A330BE3551> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                  0x9500a000 - 0x95090ff3  com.apple.framework.CoreWLAN (13.0 - 1339) <F2109362-0F47-3D05-A67F-D9752B03EB6B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                  0x951f4000 - 0x951fefff  com.apple.DirectoryService.Framework (10.13 - 207) <250D0788-9C38-3D6C-8761-E2BCF924EFB6> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                  0x951ff000 - 0x952befff  com.apple.DiscRecording (9.0.3 - 9030.4.5) <80DF1650-3C57-352F-B0DC-6CBA11B5CAB1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                  0x952e4000 - 0x952edff7  com.apple.DiskArbitration (2.7 - 2.7) <E3552A79-57A4-36AE-8B54-5FE2EB5193DA> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                  0x952fe000 - 0x9566dffb  com.apple.Foundation (6.9 - 1450.16) <3838D116-6432-30EE-8C80-68FE79D28DE5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                  0x956ae000 - 0x956ddff3  com.apple.GSS (4.0 - 2.0) <78C94D11-21DF-34C6-B4E8-88564551D67E> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                  0x9570a000 - 0x95822ff3  com.apple.Bluetooth (6.0.2 - 6.0.2f2) <48DCB862-4D56-3D7A-83BF-F182D238090A> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                  0x95888000 - 0x95929ffb  com.apple.framework.IOKit (2.0.2 - 1445.31.1) <22A82C10-B391-3359-B23A-053108AE9EB1> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                  0x9592b000 - 0x95932fff  com.apple.IOSurface (209.2.2 - 209.2.2) <0CCA9904-FCBB-3278-96A1-714BDB961D8A> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                  0x95933000 - 0x95986fff  com.apple.ImageCaptureCore (7.0 - 7.0) <9E9ADEDE-0C33-37E7-9179-957B8CA121E3> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                  0x95987000 - 0x95b0bff3  com.apple.ImageIO.framework (3.3.0 - 1713) <3A5C1E33-7CCC-3537-819B-53F39F70F034> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                  0x95b0c000 - 0x95b10ffb  libGIF.dylib (1713) <47A6BFCC-6651-3AAE-A70C-7BA3717B13BB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                  0x95b11000 - 0x95c02fff  libJP2.dylib (1713) <AC278AEA-560B-30E6-BA69-C1A2416F0849> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                  0x95c03000 - 0x95c25ff7  libJPEG.dylib (1713) <EFD86068-C17E-32AD-B4A5-79C20BC93411> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                  0x95f06000 - 0x95f2cff7  libPng.dylib (1713) <A10259A1-2581-3642-946D-5B3F101615EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                  0x95f2d000 - 0x95f2fffb  libRadiance.dylib (1713) <EE872547-4C9F-397B-B41B-C79FEEE68267> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                  0x95f30000 - 0x95f7afff  libTIFF.dylib (1713) <7A56E3C4-9965-3471-8E98-5F6B28D68FBF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                  0x96029000 - 0x9687fffb  com.apple.JavaScriptCore (13604 - 13604.4.7.1.6) <51BA4256-D385-3CB7-AE66-83716754432C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                  0x96880000 - 0x96887fff  JavaNativeFoundation (74) <6E1A3FCA-E162-3267-BD93-8CAAE66C1E3C> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
                  0x96888000 - 0x96890ff3  com.apple.java.JavaRuntimeSupport (15.0.1 - 15.0.1) <6166BC97-12D2-3D11-8DBE-73A340478724> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.fram ework/Versions/A/JavaRuntimeSupport
                  0x96891000 - 0x96895fff  com.apple.JavaVM (15.0.2 - 15.0.2) <18FAFCBC-D27E-35CD-B071-E6743BC0DA51> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
                  0x96897000 - 0x968affff  com.apple.Kerberos (3.0 - 1) <8A399DB7-5440-3EC0-A241-3DD10E82DDB2> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                  0x968b0000 - 0x968e3ffb  com.apple.LDAPFramework (2.4.28 - 194.5) <7A129625-1C7A-34A3-AD2F-0D55D33BE623> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                  0x96907000 - 0x9690ffff  com.apple.MediaAccessibility (1.0 - 114) <087BD9A6-6E5E-3884-B4F7-8F0A6B662B8D> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                  0x96910000 - 0x96f23ff3  com.apple.MediaToolbox (1.0 - 2267.40.5) <EF94A3D5-D37B-3AEF-85CE-85F3DBA504B4> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                  0x96f25000 - 0x96f9bfff  com.apple.Metal (124.7 - 124.7) <30F249EE-27E6-3C0F-AD33-792A2E77D75B> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                  0x96f9d000 - 0x96fa9fff  com.apple.NetFS (6.0 - 4.0) <F37A4DA0-AAB6-3F0B-BA18-E322BFA52CC4> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                  0x99c6d000 - 0x99c75ff7  libcldcpuengine.dylib (2.8.7) <E3B50B98-E1E4-396C-BB05-935AACC6FD80> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                  0x99c76000 - 0x99cc1fff  com.apple.opencl (2.8.12 - 2.8.12) <EC1CCEC3-19B3-3EC8-AEF5-2E1360E0B950> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                  0x99cc2000 - 0x99cdefff  com.apple.CFOpenDirectory (10.13 - 207) <F0632A8B-7F3D-3E73-B96E-2843058A3728> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                  0x99cdf000 - 0x99ceafff  com.apple.OpenDirectory (10.13 - 207) <86931646-B3A1-3200-A3CB-35005468F987> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                  0x9aef4000 - 0x9aef5fff  libCVMSPluginSupport.dylib (16.4.2) <909D788E-692E-3FF1-AFF0-2AB4609C53D7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                  0x9aef6000 - 0x9aefafff  libCoreFSCache.dylib (162.4) <D53B0D41-0774-3C6A-BB59-8BA7DB8A8374> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                  0x9aefb000 - 0x9aefffff  libCoreVMClient.dylib (162.4) <19767FEB-6A89-3892-8F18-1F9E73463050> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                  0x9af00000 - 0x9af08ff7  libGFXShared.dylib (16.4.2) <F62281F1-9495-3589-A576-75D84880D42D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                  0x9af09000 - 0x9af15fff  libGL.dylib (16.4.2) <028B909B-DD19-388B-8113-1850DFAD3DCA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                  0x9af16000 - 0x9af51ffb  libGLImage.dylib (16.4.2) <AE5E3974-656A-3F88-956E-F28192BA98C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                  0x9af52000 - 0x9b0caffb  libGLProgrammability.dylib (16.4.2) <141160DE-8DB1-3A9C-95CA-0167D90B0A5A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                  0x9b0cb000 - 0x9b10dff7  libGLU.dylib (16.4.2) <9E1283AA-A7E0-37BA-BDEB-EE5256D677C7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                  0x9bab4000 - 0x9bac2fff  com.apple.opengl (16.4.2 - 16.4.2) <40645026-52DC-3CFC-8308-EFA2FA79D5A0> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                  0x9bac3000 - 0x9bc50ffb  GLEngine (16.4.2) <C8DAFD05-BBC9-3CE5-8940-114DA2E0147B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                  0x9bc51000 - 0x9bc7bfff  GLRendererFloat (16.4.2) <C50B4E84-163D-32E3-9643-290308B11918> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                  0x9bd99000 - 0x9beeaffb  com.apple.QTKit (7.7.3 - 3014) <9DB2668A-3F68-32F0-BF51-C7F791FEE8EE> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                  0x9beeb000 - 0x9c136ff3  com.apple.imageKit (3.0 - 1040) <50E40E4F-2865-35B1-9FA3-A516921FBB8A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                  0x9c137000 - 0x9c20affb  com.apple.PDFKit (1.0 - 677.4) <1245217B-ADBE-3C64-B0B6-B8E795391421> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                  0x9c20b000 - 0x9c71dff3  com.apple.QuartzComposer (5.1 - 364) <16A5F426-C732-30B0-B141-6AC3DAB4E86A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                  0x9c71e000 - 0x9c73fff7  com.apple.quartzfilters (1.10.0 - 1.10.0) <C29EBE6F-03A5-3EAF-9155-6A224E671432> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                  0x9c740000 - 0x9c825ff7  com.apple.QuickLookUIFramework (5.0 - 743.7) <57F8FF70-DD07-3808-A563-E96F8A56C0C2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                  0x9c826000 - 0x9c826fff  com.apple.quartzframework (1.5 - 21) <AFDC52CF-3DDF-3100-9D60-9DEFAE551CD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                  0x9c827000 - 0x9ca5dff7  com.apple.QuartzCore (1.11 - 584.8.94) <FF9C6423-5220-3BCC-9D9A-1B90BF4BD95C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                  0x9ca5e000 - 0x9cab2ffb  com.apple.QuickLookFramework (5.0 - 743.7) <EED11263-0CE3-3C40-953E-49F4E800FE74> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                  0x9cab3000 - 0x9cd0bfeb  com.apple.QuickTime (7.7.3 - 3014) <A38CF029-378C-3D67-9359-7DC15452B0E4> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                  0x9ceb9000 - 0x9cebafff  com.apple.SafariServices.framework (13604 - 13604.4.7.1.6) <4D49864F-E3B4-32EE-AB9E-94917DB9D6E7> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
                  0x9cef6000 - 0x9d222ff3  com.apple.security (7.0 - 58286.31.2) <BF1FF3A9-0DA4-307D-84EE-B58EF2C98815> /System/Library/Frameworks/Security.framework/Versions/A/Security
                  0x9d223000 - 0x9d2aaff3  com.apple.securityfoundation (6.0 - 55185.30.4) <54362CD6-89D0-3328-9915-EC2F74748529> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                  0x9d2d6000 - 0x9d2dafff  com.apple.xpc.ServiceManagement (1.0 - 1) <B09C1309-46A2-3081-B489-DCE549A8BA46> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                  0x9d405000 - 0x9d475ff3  com.apple.SystemConfiguration (1.17 - 1.17) <318C287A-BB41-3F72-9095-9DFF0382CB77> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                  0x9d61f000 - 0x9d9acfff  com.apple.VideoToolbox (1.0 - 2267.40.5) <F85F21A8-2F27-3903-BA62-DA7689F13C43> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                  0x9d9ad000 - 0x9ed84ff7  com.apple.WebCore (13604 - 13604.4.7.1.6) <AC17FBCF-F35B-3CF5-B477-200F515EAEE6> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                  0x9ed85000 - 0x9ef18ffb  com.apple.WebKitLegacy (13604 - 13604.4.7.1.6) <E3D7EB10-BAE8-3A37-836C-14DC6FD030B7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                  0x9ef19000 - 0x9f259ff7  com.apple.WebKit (13604 - 13604.4.7.1.6) <4A1C5262-7691-3E89-8DAC-E7626FA955E6> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                  0x9f26b000 - 0x9f302ff7  com.apple.APFS (1.0 - 1) <DC1D47F4-3D45-35F4-9D86-14B5946CEFA1> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
                  0x9f916000 - 0x9f941ff3  com.apple.framework.Apple80211 (13.0 - 1345) <6805C16F-21E5-3758-B77C-29870A7C6627> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                  0x9f943000 - 0x9f94dfff  com.apple.AppleFSCompression (96.30.2 - 1.0) <BEA6D735-9BF0-3146-9D45-32A3D9433602> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                  0x9fa46000 - 0x9fa83ff3  com.apple.AppleJPEG (1.0 - 1) <E87393BB-6140-389C-BF53-36B3985A56D3> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                  0x9faa2000 - 0x9faaafff  com.apple.AppleSRP (5.0 - 1) <0C288A20-01A0-3C3C-8091-B8672B1F0CC6> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                  0x9fb79000 - 0x9fb7cfff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <E0ACE999-E0DF-3227-BBF5-A04ECB3F6ECF> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                  0x9fb7d000 - 0x9fbccffb  com.apple.AppleVAFramework (5.0.39 - 5.0.39) <9EC588A6-D942-3B7C-88B4-59044051465A> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                  0x9fbd6000 - 0x9fbddfff  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <71FD5EA2-8D0B-3E21-94E4-6D5BD45005E7> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/Backgroun dTaskManagement
                  0x9fbde000 - 0x9fc69ff7  com.apple.backup.framework (1.9.2 - 1.9.2) <19BE4138-61BB-33C8-80C5-0309B58CA16A> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                  0x9fdad000 - 0x9fdb6ffb  com.apple.CommonAuth (4.0 - 2.0) <424B8D39-396A-3A78-84C1-5161B54A8F5B> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                  0x9fe60000 - 0xa0178fef  com.apple.CoreAUC (249.0.0 - 249.0.0) <77A27B7D-9EB4-39E0-9411-C9B7BDF0B1A8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                  0xa0179000 - 0xa01aafff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <EC1E91A7-CFD3-31E4-AE53-1D57BC7F852A> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                  0xa021f000 - 0xa0227fff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <20358A6F-D9AD-350F-B3D5-9D0988BAB017> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                  0xa0228000 - 0xa0238ff7  com.apple.CoreEmoji (1.0 - 69.3) <165A133F-DED4-3B24-A9BF-6EA6F3F7A152> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
                  0xa0239000 - 0xa024fff7  com.apple.CoreMediaAuthoring (2.2 - 956) <7FB86A4B-5DC0-3267-AC40-3A99436D3FF1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                  0xa0303000 - 0xa039cfff  com.apple.CorePDF (4.0 - 414) <4A8D560F-DBD3-37B7-B296-8123A03C81AF> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                  0xa03c0000 - 0xa03f3ff7  com.apple.CoreServicesInternal (309.1 - 309.1) <1F73ECC7-F09F-3730-A290-472B89788807> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                  0xa03f4000 - 0xa048aff3  com.apple.CoreSymbolication (63075) <6223068D-FCD8-39C1-841D-834EF0AC6445> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                  0xa048b000 - 0xa05b1fe3  com.apple.coreui (2.1 - 492.2) <4B915963-6D32-3D89-B585-94094ACCF2E8> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                  0xa05b2000 - 0xa064dff3  com.apple.CoreUtils (5.3 - 530.57) <21D34447-A1FC-31C4-BE73-F61577ABB2F5> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                  0xa069e000 - 0xa06fbff3  com.apple.framework.CoreWiFi (13.0 - 1339) <5434C7AB-A80A-3DD3-B0F1-4EFEA912B16B> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                  0xa06fc000 - 0xa070cfff  com.apple.CrashReporterSupport (10.13 - 1) <86DA5C7B-BA5E-3182-A787-28B6F580FF38> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                  0xa077a000 - 0xa0787fff  com.apple.framework.DFRFoundation (1.0 - 191.1) <8EF25CE9-3ED3-3E20-A4A2-20743EA32265> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
                  0xa07d3000 - 0xa0844fff  com.apple.datadetectorscore (7.0 - 590.3) <2210A987-9208-3E20-8425-90180C57DE8C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                  0xa0845000 - 0xa0885ffb  com.apple.DebugSymbols (141 - 141) <96BB879B-1A83-3622-BB02-1DDA5C4FD939> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                  0xa0886000 - 0xa09c5ff7  com.apple.desktopservices (1.12.2 - 1.12.2) <DC51DB71-E241-3715-8EEF-BA1166B551DD> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                  0xa09fb000 - 0xa0addff7  com.apple.DiskImagesFramework (480.30.2 - 480.30.2) <461AEBC8-5A57-3F1C-B845-E9EAB23490FF> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                  0xa0ade000 - 0xa0b54ffb  com.apple.DiskManagement (11.2 - 1339) <BD5D176C-418C-3DB9-921E-C009402C692E> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
                  0xa0b55000 - 0xa0b5ffff  com.apple.DisplayServicesFW (3.1 - 380) <8940F718-0E7D-3805-80F9-C971E5DC9E30> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                  0xa0b95000 - 0xa0b97fff  com.apple.EFILogin (2.0 - 2) <71E8BCE8-33B4-3F07-AD0E-847393177410> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                  0xa0c91000 - 0xa10c1ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <B2288C3D-E67F-3AAE-A652-E920CD19F267> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                  0xa2e6d000 - 0xa2e77fff  libGPUSupportMercury.dylib (16.4.2) <AAAAF228-51D8-3425-9D15-4D34F41EA791> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                  0xa3108000 - 0xa312effb  com.apple.GenerationalStorage (2.0 - 285) <430145ED-153B-3548-A6D4-6850752A9E6A> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                  0xa3a65000 - 0xa3ad8ff3  com.apple.Heimdal (4.0 - 2.0) <560C8A98-E261-39C9-9862-3340EC6ABC9C> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                  0xa3d8a000 - 0xa3d90fff  com.apple.IOAccelerator (376.6 - 376.6) <4EFED596-8863-35F6-8EA3-CB11C5D9D157> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                  0xa3d91000 - 0xa3da9ffb  com.apple.IOPresentment (1.0 - 32.1) <EBD4DB8D-03D3-3136-B431-969A2E5E1B91> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
                  0xa3e06000 - 0xa3e25ff3  com.apple.IconServices (97.4 - 97.4) <3F593C33-E45D-3D77-B82C-F811428C4901> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                  0xa3e2e000 - 0xa3e3dfff  com.apple.IntlPreferences (2.0 - 227) <A3DB41BE-6754-3A0D-8AE0-4177CFEF5413> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                  0xa3e4a000 - 0xa3e4efff  JavaLaunching (42) <4CC877B4-CE5A-3DC7-AB58-45ABCB558F37> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
                  0xa3e5d000 - 0xa3f51ff7  com.apple.LanguageModeling (1.0 - 159.3.1) <AA880B14-031D-33FB-9B48-0A8AAB7342C6> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                  0xa3f52000 - 0xa3f93ff7  com.apple.Lexicon-framework (1.0 - 33.2) <13FAB8A2-507A-3AEA-A571-27BDDFD96B31> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
                  0xa3f97000 - 0xa3f9dff3  com.apple.LinguisticData (1.0 - 238.3) <C47B3EB0-0463-3613-8A09-344F1639EE92> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
                  0xa3fad000 - 0xa3fb2ff3  com.apple.LoginUICore (4.0 - 4.0) <811AE2E4-4487-36F5-94CF-334E4FFEB7AB> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
                  0xa4107000 - 0xa413dffb  com.apple.MediaKit (16 - 871) <3677518D-3972-38C9-8DBE-BDA83F5A19CF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                  0xa434b000 - 0xa4374ffb  com.apple.MultitouchSupport.framework (1204.13 - 1204.13) <01BDF9A5-8C83-3611-A999-F43F9121A173> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                  0xa4493000 - 0xa449dfff  com.apple.NetAuth (6.2 - 6.2) <52F67DC1-8C96-3944-8E54-C02DD51FD9FC> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                  0xa4545000 - 0xa4581fff  com.apple.PerformanceAnalysis (1.183.1 - 183.1) <FFE20C99-7FE3-3722-AD6C-C6ECF2C2D103> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                  0xa45da000 - 0xa461fffb  com.apple.ProtectedCloudStorage (1.0 - 1) <ED5DB3B0-4CCE-3698-93BE-CAC3AD7F4F88> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                  0xa4620000 - 0xa463cff7  com.apple.ProtocolBuffer (1 - 259) <BBB59E09-0B06-3262-9C81-C126DF34667C> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                  0xa4713000 - 0xa4727fff  com.apple.QuickLookThumbnailing (1.0 - 1) <5DB01EC5-14D5-3E51-9FF1-E034E62354D3> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
                  0xa4728000 - 0xa474afff  com.apple.RemoteViewServices (2.0 - 125) <5720B413-E761-3368-964F-7FEAC5535669> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                  0xa4800000 - 0xa482dffb  com.apple.Sharing (972.6 - 972.6) <94426AD7-4302-3870-9D7B-F5ED6900BBCE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                  0xa484c000 - 0xa484dfff  com.apple.performance.SignpostNotification (1.0 - 1) <9AD547F6-ED5A-3AC8-BF4C-811C69801CDF> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotif ication
                  0xa484e000 - 0xa48d3ffb  com.apple.SkyLight (1.600.0 - 312.23.4) <A78C5D21-4D37-358A-8C18-EADA8084BFCA> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
                  0xa4903000 - 0xa4910ffb  com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <BACA23B0-AF15-3B7F-8933-15DDEE48318B> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                  0xa4bdd000 - 0xa4c5eff3  com.apple.Symbolication (9.0 - 63079.1) <97DA4973-352E-3CBA-9B4A-BC22C3AFD597> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                  0xa4c7a000 - 0xa4ca5fff  com.apple.framework.SystemAdministration (1.0 - 1.0) <46AB55C6-5CAF-38BA-9EA9-1640C7D060D8> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
                  0xa4cb1000 - 0xa4cb8fff  com.apple.TCC (1.0 - 1) <4B76752A-36A0-3175-87C7-CB42E33CCB5A> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                  0xa4cb9000 - 0xa4cd0ff3  com.apple.TextureIO (3.7 - 3.7) <B46FD025-BC89-3A84-B2E1-5E744E2F9C33> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
                  0xa4cf8000 - 0xa4cf9fff  com.apple.TrustEvaluationAgent (2.0 - 31) <185BD5A9-5A2D-3317-B7FE-9B67F14C4D2C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                  0xa4cfa000 - 0xa4e84fff  com.apple.UIFoundation (1.0 - 546.1.1) <DB0AE684-9FD6-3EFC-BAA0-BD6F5D27D24C> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                  0xa521b000 - 0xa52dffff  com.apple.ViewBridge (343.2 - 343.2) <E35AE410-455E-33FC-AD7B-C067EA0850CE> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                  0xa5452000 - 0xa5454fff  com.apple.loginsupport (1.0 - 1) <086FAE1B-87E2-324A-AE76-E6EC0B5F1517> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                  0xa5455000 - 0xa5466fff  com.apple.login (3.0 - 3.0) <A77D7047-2994-3696-8E3D-9922F2659A26> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
                  0xa54a6000 - 0xa54befff  com.apple.vmutils (4.2.1 - 110) <E0F135E6-103C-34C2-B4F3-C986B716A665> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
                  0xa54df000 - 0xa5512ff7  libclosured.dylib (519.2.2) <E0E52FC3-51A9-385F-953D-23A7CA8D5666> /usr/lib/closure/libclosured.dylib
                  0xa5562000 - 0xa5599ff3  libCRFSuite.dylib (41) <7F584902-74F1-3362-935D-95F5E735F5E7> /usr/lib/libCRFSuite.dylib
                  0xa559a000 - 0xa55a4ffb  libChineseTokenizer.dylib (28) <1FF5A32D-E012-3E76-B738-FAC26AD2A39B> /usr/lib/libChineseTokenizer.dylib
                  0xa55a5000 - 0xa563fffb  libCoreStorage.dylib (546) <CAD02BFA-05C3-3AA4-853F-956DF4CD93B3> /usr/lib/libCoreStorage.dylib
                  0xa5640000 - 0xa5641fff  libDiagnosticMessagesClient.dylib (104) <6829B180-2556-3A7E-A2E6-BD4859DF30A7> /usr/lib/libDiagnosticMessagesClient.dylib
                  0xa5673000 - 0xa585dff7  libFosl_dynamic.dylib (17.7) <DBE4D720-8A46-3879-AD2D-F9A8CE3E7476> /usr/lib/libFosl_dynamic.dylib
                  0xa5865000 - 0xa5865fff  libOpenScriptingUtil.dylib (174) <B7CEDC30-2D17-3896-9EFC-64DB3D11DF00> /usr/lib/libOpenScriptingUtil.dylib
                  0xa58af000 - 0xa58b3fff  libScreenReader.dylib (562.13) <F1DB780F-86F0-32D9-B2BA-73AF91F59393> /usr/lib/libScreenReader.dylib
                  0xa58b4000 - 0xa58b5fff  libSystem.B.dylib (1252) <334D9E12-F209-3C28-875B-77E0FD623AD7> /usr/lib/libSystem.B.dylib
                  0xa58c4000 - 0xa58d9ff7  libapple_nghttp2.dylib (1.24) <480C0C04-2533-3D44-8232-006B6CBA7758> /usr/lib/libapple_nghttp2.dylib
                  0xa58da000 - 0xa5905fff  libarchive.2.dylib (54) <D55C5F86-251D-3C33-A617-0C623D4F512E> /usr/lib/libarchive.2.dylib
                  0xa5906000 - 0xa5a55ffb  libate.dylib (1.13.1) <E109CCBF-357D-3C87-9CE5-D53AE03609A2> /usr/lib/libate.dylib
                  0xa5a59000 - 0xa5a59ff3  libauto.dylib (187) <CE2A78CC-670F-3E07-9539-822DCD2F6084> /usr/lib/libauto.dylib
                  0xa5a5a000 - 0xa5a6afff  libbsm.0.dylib (39) <067E9003-0673-32A3-9B40-492323182C5C> /usr/lib/libbsm.0.dylib
                  0xa5a6b000 - 0xa5a77ff7  libbz2.1.0.dylib (38) <77C24A36-BE84-3702-A786-935C597A0A86> /usr/lib/libbz2.1.0.dylib
                  0xa5a78000 - 0xa5ad1ffb  libc++.1.dylib (400.9) <AD612EEF-6CE3-315D-82C2-58248BE13431> /usr/lib/libc++.1.dylib
                  0xa5ad2000 - 0xa5af3fff  libc++abi.dylib (400.7) <41323E53-C7EA-3E9A-BD30-38E82399F843> /usr/lib/libc++abi.dylib
                  0xa5af5000 - 0xa5b06ff7  libcmph.dylib (6) <EC7664F1-B5A1-37F4-B7DC-F6AC10587E35> /usr/lib/libcmph.dylib
                  0xa5b07000 - 0xa5b1aff7  libcompression.dylib (47) <F80DDFC1-F96A-3BAD-967D-C1E24253273A> /usr/lib/libcompression.dylib
                  0xa5b1b000 - 0xa5b32ffb  libcoretls.dylib (155) <F66FAEBC-4B6E-31E0-ACA8-C8ACBC7689DD> /usr/lib/libcoretls.dylib
                  0xa5b33000 - 0xa5b34fff  libcoretls_cfhelpers.dylib (155) <8B8ABC2C-F251-3C80-9747-88C05A2CBE64> /usr/lib/libcoretls_cfhelpers.dylib
                  0xa5bd6000 - 0xa5cb4fff  libcrypto.0.9.8.dylib (76.30.1) <AE86D3F1-E7D3-32B5-983B-D436AAA191A2> /usr/lib/libcrypto.0.9.8.dylib
                  0xa5cb5000 - 0xa5e5cfff  libcrypto.35.dylib (22) <EE1BA2F7-F2F4-387B-8866-5B4A7023D29F> /usr/lib/libcrypto.35.dylib
                  0xa6010000 - 0xa601bff7  libcsfde.dylib (546) <F4322188-F1FF-31A3-8245-C9D62F795D4A> /usr/lib/libcsfde.dylib
                  0xa601c000 - 0xa6073fff  libcups.2.dylib (462.1) <0180AE97-A19F-3D49-9838-06995E73F572> /usr/lib/libcups.2.dylib
                  0xa609f000 - 0xa60f1fff  libcurl.4.dylib (105.30.2) <9BE04599-41D6-36F3-B46F-9FEA218E70F0> /usr/lib/libcurl.4.dylib
                  0xa6189000 - 0xa6189fff  libenergytrace.dylib (16) <34FC43C7-D9B6-3C01-8B65-E49059D31279> /usr/lib/libenergytrace.dylib
                  0xa61bd000 - 0xa61c1fff  libheimdal-asn1.dylib (520.30.1) <DEA7E913-118F-333E-BE08-5B4F19B33B9A> /usr/lib/libheimdal-asn1.dylib
                  0xa61ed000 - 0xa62ddff3  libiconv.2.dylib (51) <FE6D05A5-18DB-3FD8-A52F-B7BADB232C78> /usr/lib/libiconv.2.dylib
                  0xa62de000 - 0xa6500ff7  libicucore.A.dylib (59152.0.1) <1048B064-30DD-30CA-BB7D-41F0F3159DA9> /usr/lib/libicucore.A.dylib
                  0xa6548000 - 0xa6549fff  liblangid.dylib (128) <120FE992-47E4-3A73-A039-1B401F5696DC> /usr/lib/liblangid.dylib
                  0xa654a000 - 0xa6562ff7  liblzma.5.dylib (10) <8A5C9679-430A-3A19-AF68-9D21BAC442C7> /usr/lib/liblzma.5.dylib
                  0xa6563000 - 0xa6578fff  libmarisa.dylib (9) <805453EE-B829-3DA5-8DF3-5132D03D5B74> /usr/lib/libmarisa.dylib
                  0xa662d000 - 0xa684afff  libmecabra.dylib (779.7.6) <08A39874-BF80-3A92-A088-C494C518218A> /usr/lib/libmecabra.dylib
                  0xa6a11000 - 0xa6ae5fff  libnetwork.dylib (1229.30.11) <86111B18-D03B-3F4F-ACD8-9D9C510058F3> /usr/lib/libnetwork.dylib
                  0xa6ae6000 - 0xa6ec60fb  libobjc.A.dylib (723) <4AF346B8-C1A8-3199-B1BB-ADEDD64D5C1A> /usr/lib/libobjc.A.dylib
                  0xa6ec7000 - 0xa6ec7fff  libodfde.dylib (24) <C546D8F4-92DA-35F2-B166-10DCC67EB4CE> /usr/lib/libodfde.dylib
                  0xa6eca000 - 0xa6ecdfff  libpam.2.dylib (22) <7106F43C-84DD-3F26-905A-B52780AFEB3E> /usr/lib/libpam.2.dylib
                  0xa6ed0000 - 0xa6f01fff  libpcap.A.dylib (79.20.1) <154889CF-5F83-3012-953E-0FC8FEE50FF8> /usr/lib/libpcap.A.dylib
                  0xa6f3f000 - 0xa6f5affb  libresolv.9.dylib (65) <65A43F5B-CF88-3948-AE5C-D7CA02D814A1> /usr/lib/libresolv.9.dylib
                  0xa6f93000 - 0xa6fa4ff7  libsasl2.2.dylib (211) <31BFF961-171E-331A-BA3A-F79E69C6E63B> /usr/lib/libsasl2.2.dylib
                  0xa6fa5000 - 0xa712fff7  libsqlite3.dylib (274.5) <B09AF63F-4F1A-3481-9B61-6EBB64D12EB9> /usr/lib/libsqlite3.dylib
                  0xa7187000 - 0xa71e5ff7  libssl.35.dylib (22) <F96B7886-D3AA-39F3-A23D-3C2822678E13> /usr/lib/libssl.35.dylib
                  0xa723f000 - 0xa728fffb  libstdc++.6.0.9.dylib (104.1) <74744B76-524A-3052-A4CF-3C47446A32C0> /usr/lib/libstdc++.6.0.9.dylib
                  0xa72d3000 - 0xa730dffb  libusrtcp.dylib (1229.30.11) <39D76669-A48B-3BAC-8F45-1D6CA87E9B4B> /usr/lib/libusrtcp.dylib
                  0xa730e000 - 0xa7311ff7  libutil.dylib (51.20.1) <86BD9675-16A2-345D-9B8D-E8A3397F2365> /usr/lib/libutil.dylib
                  0xa7312000 - 0xa7320ff7  libxar.1.dylib (400) <4B664A7E-EC05-34AD-ACC6-C879B69DBA7C> /usr/lib/libxar.1.dylib
                  0xa7321000 - 0xa73ffff7  libxml2.2.dylib (31.7) <3E1F9E3D-6C44-3437-AB2B-E5ACE1927F81> /usr/lib/libxml2.2.dylib
                  0xa7400000 - 0xa7428ff3  libxslt.1.dylib (15.10) <1A3DC7B8-7C92-3D73-BF82-D60E64BC3DF0> /usr/lib/libxslt.1.dylib
                  0xa7429000 - 0xa7438ff7  libz.1.dylib (70) <588F445F-0065-3D77-8002-BA9411DA1D70> /usr/lib/libz.1.dylib
                  0xa7472000 - 0xa7476fff  libcache.dylib (80) <5D011637-CADA-38A1-A695-CE049657FD9D> /usr/lib/system/libcache.dylib
                  0xa7477000 - 0xa7481fff  libcommonCrypto.dylib (60118.30.2) <38B2C15B-D27F-3106-A337-F72F29844825> /usr/lib/system/libcommonCrypto.dylib
                  0xa7482000 - 0xa7487fff  libcompiler_rt.dylib (62) <FA07FEE2-CEFE-3CC0-A82F-E601AA2CCB36> /usr/lib/system/libcompiler_rt.dylib
                  0xa7488000 - 0xa7491ff3  libcopyfile.dylib (146.30.2) <F3A05833-AD1C-3E3A-8100-847297C882FC> /usr/lib/system/libcopyfile.dylib
                  0xa7492000 - 0xa74faff7  libcorecrypto.dylib (562.30.10) <0D8A61F8-2D7D-31F1-93AB-0597D80CCA85> /usr/lib/system/libcorecrypto.dylib
                  0xa7565000 - 0xa759afff  libdispatch.dylib (913.30.4) <D1812254-DE85-3A5B-AD7B-5CE23BB8C9E1> /usr/lib/system/libdispatch.dylib
                  0xa759b000 - 0xa75b8fff  libdyld.dylib (519.2.2) <A79B6A65-DDAA-31C5-B66B-95FB343125BE> /usr/lib/system/libdyld.dylib
                  0xa75b9000 - 0xa75b9fff  libkeymgr.dylib (28) <C448ACFC-DD1B-3F08-B4C3-D2B69D1210B1> /usr/lib/system/libkeymgr.dylib
                  0xa75ba000 - 0xa75c6ff7  libkxld.dylib (4570.31.3) <17609EC4-47F0-39C9-8F90-5F07FF52F217> /usr/lib/system/libkxld.dylib
                  0xa75c7000 - 0xa75c7fff  liblaunch.dylib (1205.30.29) <0F3BF17D-FCFA-3692-8A6E-FDE5C58DB3B7> /usr/lib/system/liblaunch.dylib
                  0xa75c8000 - 0xa75cdfff  libmacho.dylib (900.0.1) <F1F0BC1D-A2D9-39F9-9A11-263F8392CB3B> /usr/lib/system/libmacho.dylib
                  0xa75ce000 - 0xa75d0fff  libquarantine.dylib (86) <68DE2EB2-7911-304D-89D6-1517CA689001> /usr/lib/system/libquarantine.dylib
                  0xa75d1000 - 0xa75d2fff  libremovefile.dylib (45) <BEF76B44-53EA-3970-AB50-2296DC7F097F> /usr/lib/system/libremovefile.dylib
                  0xa75d3000 - 0xa75eaff7  libsystem_asl.dylib (356.1.1) <F96973B5-C36B-3037-8AEC-3BF7147D79E2> /usr/lib/system/libsystem_asl.dylib
                  0xa75eb000 - 0xa75ebfff  libsystem_blocks.dylib (67) <32CE9BB7-E047-3568-981E-4EA94D3DCBB5> /usr/lib/system/libsystem_blocks.dylib
                  0xa75ec000 - 0xa7678fff  libsystem_c.dylib (1244.30.3) <8BCBF89D-5CE7-3950-884A-86E37DBF2660> /usr/lib/system/libsystem_c.dylib
                  0xa7679000 - 0xa767cfff  libsystem_configuration.dylib (963.30.1) <0F30DC5A-F39F-32C9-BA01-05AAC699713A> /usr/lib/system/libsystem_configuration.dylib
                  0xa767d000 - 0xa7680fff  libsystem_coreservices.dylib (51) <C3D75760-EED5-3C5C-8245-FBD3D9FD60FD> /usr/lib/system/libsystem_coreservices.dylib
                  0xa7681000 - 0xa7682fff  libsystem_darwin.dylib (1244.30.3) <83B1D06A-9FA5-3F0B-A223-0659F4248E51> /usr/lib/system/libsystem_darwin.dylib
                  0xa7683000 - 0xa7689ff3  libsystem_dnssd.dylib (878.30.4) <3C4400C4-C531-3653-872B-E22892D7B29A> /usr/lib/system/libsystem_dnssd.dylib
                  0xa768a000 - 0xa76d9ffb  libsystem_info.dylib (517.30.1) <A8E62937-32F9-373C-8150-B6B442227226> /usr/lib/system/libsystem_info.dylib
                  0xa76da000 - 0xa76fdff7  libsystem_kernel.dylib (4570.31.3) <FBC48404-D7AD-31FA-BDE2-5B6A1D8EFC7A> /usr/lib/system/libsystem_kernel.dylib
                  0xa76fe000 - 0xa774dfdb  libsystem_m.dylib (3146) <DBE0AACD-3665-3EEB-BADA-A435E591C54B> /usr/lib/system/libsystem_m.dylib
                  0xa774e000 - 0xa7768fff  libsystem_malloc.dylib (140.1.1) <DFE0206A-865E-359D-B2F9-FE9DBB3B5B32> /usr/lib/system/libsystem_malloc.dylib
                  0xa7769000 - 0xa7806ffb  libsystem_network.dylib (1229.30.11) <84B584A7-7583-31E7-8A39-64B4A5AD643B> /usr/lib/system/libsystem_network.dylib
                  0xa7807000 - 0xa7811fff  libsystem_networkextension.dylib (767.30.7) <E88F13BB-D751-3FF9-A136-2C1158129BAA> /usr/lib/system/libsystem_networkextension.dylib
                  0xa7812000 - 0xa781aff3  libsystem_notify.dylib (172) <63E3CF8C-4F15-3D45-84A6-1218352031E9> /usr/lib/system/libsystem_notify.dylib
                  0xa781b000 - 0xa7821ffb  libsystem_platform.dylib (161.20.1) <82782E0E-7264-3CB4-AE69-571EDB5E7A24> /usr/lib/system/libsystem_platform.dylib
                  0xa7822000 - 0xa782cff3  libsystem_pthread.dylib (301.30.1) <7409C1E5-F3BA-3AB3-ADC1-9DCD356C6C13> /usr/lib/system/libsystem_pthread.dylib
                  0xa782d000 - 0xa7830ff3  libsystem_sandbox.dylib (765.30.4) <8226258C-47FE-30A9-AE91-C13DE173E368> /usr/lib/system/libsystem_sandbox.dylib
                  0xa7831000 - 0xa7833fff  libsystem_secinit.dylib (30) <CE2C90DE-27A4-3546-8A05-96B743861DD0> /usr/lib/system/libsystem_secinit.dylib
                  0xa7834000 - 0xa783cff7  libsystem_symptoms.dylib (820.30.7) <0283BDB3-16A2-371E-A25C-A26F076C24A5> /usr/lib/system/libsystem_symptoms.dylib
                  0xa783d000 - 0xa784ffff  libsystem_trace.dylib (829.30.14) <79446DE0-89F6-3979-B14C-7B463AD70351> /usr/lib/system/libsystem_trace.dylib
                  0xa7851000 - 0xa7857fff  libunwind.dylib (35.3) <642BBA03-0411-3FAA-A421-D79A9156AB1C> /usr/lib/system/libunwind.dylib
                  0xa7858000 - 0xa7880ff7  libxpc.dylib (1205.30.29) <CD44097B-4B65-3F75-AB7F-52228229FFB5> /usr/lib/system/libxpc.dylib
                  0xb0000000 - 0xb001afe3 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <928D8FAD-DEE7-F1D0-FE17-FA7F4E4C1E48> /Applications/Adobe Flash CS6/Adobe Flash CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                  0xba900000 - 0xba91cfff  libJapaneseConverter.dylib (70) <EB2076FC-9416-3130-A0B0-0DF885D1FFDC> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                  0xbab00000 - 0xbab21fff  libKoreanConverter.dylib (70) <11280CD6-08A2-3300-8BDB-8D04B67B3C79> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                  External Modification Summary:
                    Calls made by other processes targeting this process:
                  task_for_pid: 16
                  thread_create: 0
                  thread_set_state: 0
                    Calls made by this process:
                  task_for_pid: 0
                  thread_create: 0
                  thread_set_state: 0
                    Calls made by all processes on this machine:
                  task_for_pid: 656888
                  thread_create: 0
                  thread_set_state: 0
                  VM Region Summary:
                  ReadOnly portion of Libraries: Total=518.5M resident=0K(0%) swapped_out_or_unallocated=518.5M(100%)
                  Writable regions: Total=682.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=682.4M(100%)
                                              VIRTUAL   REGION
                  REGION TYPE                    SIZECOUNT (non-coalesced)
                  ATS (font support)            33.3M   12
                  Accelerate framework           256K    3
                  Activity Tracing               256K    2
                  CG backing stores             43.3M   15
                  CoreGraphics                     8K    2
                  CoreImage                        8K    3
                  CoreUI image data              852K   11
                  CoreUI image file              180K    4
                  Foundation                      16K    2
                  Image IO                        16K    2
                  Java                         225.2M    8
                  Java (reserved)               9908K    5     reserved VM address space (unallocated)
                  Kernel Alloc Once                8K    2
                  MALLOC                       290.5M   94
                  MALLOC guard page               64K   17
                  MALLOC_LARGE (reserved)       1024K    2     reserved VM address space (unallocated)
                  Mach message (reserved)          8K    2     reserved VM address space (unallocated)
                  Memory Tag 240                31.0M  121
                  Memory Tag 240 (reserved)        4K    2     reserved VM address space (unallocated)
                  Memory Tag 242                  12K    2
                  Memory Tag 249                 156K    3
                  OpenGL GLSL                    128K    3
                  Stack                         45.5M   52
                  Stack Guard                   56.3M   64
                  VM_ALLOCATE                   4288K  188
                  __DATA                        21.6M  394
                  __FONT_DATA                      4K    2
                  __GLSLBUILTINS                2588K    2
                  __IMPORT                        32K    7
                  __LINKEDIT                   132.9M   91
                  __OBJC                        4864K  139
                  __TEXT                       385.6M  368
                  __UNICODE                      560K    2
                  mapped file                    2.4G  658
                  shared memory                  768K   27
                  TOTAL                          3.7G 2276
                  TOTAL, minus reserved VM space 3.6G 2276
                  Model: Macmini6,2, BootROM MM61.010B.B00, 4 processors, Intel Core i7, 2.3 GHz, 16 GB, SMC 2.8f0
                  Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
                  Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x01BA, 0x202020202020202020202020202020202020
                  Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x01BA, 0x202020202020202020202020202020202020
                  AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x10E), Broadcom BCM43xx 1.0 (7.21.190.16.1a2)
                  Bluetooth: Version 6.0.2f2, 3 services, 27 devices, 1 incoming serial ports
                  Network Service: Wi-Fi, AirPort, en1
                  Serial ATA Device: APPLE HDD HTS541010A9E662, 1 TB
                  USB Device: USB 2.0 Bus
                  USB Device: Hub
                  USB Device: Hub
                  USB Device: Hub
                  USB Device: IR Receiver
                  USB Device: BRCM20702 Hub
                  USB Device: Bluetooth USB Host Controller
                  USB Device: Cintiq 24HD HUB
                  USB Device: Cintiq 24HD Tablet
                  USB Device: USB 3.0 Bus
                  USB Device: Yeti Stereo Microphone
                  USB Device: USB Receiver
                  USB Device: Apple USB SuperDrive
                  Thunderbolt Bus: Mac mini, Apple Inc., 23.4
