4 Replies Latest reply on Sep 10, 2017 3:41 AM by Tom Winkelmann
    Zoom in guide sections
    saikirans54625543 Level 1
      Is there a script to zoom in from one guide section to other.Currently, I do it manually by selecting grid by grid to zoom in
        • 1. Re: Zoom in guide sections
          I see that the scriptlistener records some steps when you do what you you show there. Not the code references the mouse not any x y or selection area and the code does not work is a script it troughs an error.
          var idtoolModalStateChanged = stringIDToTypeID( "toolModalStateChanged" );
              var desc47 = new ActionDescriptor();
              var idLvl = charIDToTypeID( "Lvl " );
              desc47.putInteger( idLvl, 1 );
              var idStte = charIDToTypeID( "Stte" );
              var identer = stringIDToTypeID( "enter" );
              desc47.putEnumerated( idStte, idStte, identer );
              var idTool = charIDToTypeID( "Tool" );
                  var desc48 = new ActionDescriptor();
                  var idIdnt = charIDToTypeID( "Idnt" );
                  desc48.putString( idIdnt, """zoom""" );
                  var idTtl = charIDToTypeID( "Ttl " );
                  desc48.putString( idTtl, """Zoom Tool""" );
              desc47.putObject( idTool, idTool, desc48 );
              var idKnd = charIDToTypeID( "Knd " );
              var idmouse = stringIDToTypeID( "mouse" );
              desc47.putEnumerated( idKnd, idKnd, idmouse );
              var idkcanDispatchWhileModal = stringIDToTypeID( "kcanDispatchWhileModal" );
              desc47.putBoolean( idkcanDispatchWhileModal, true );
          executeAction( idtoolModalStateChanged, desc47, DialogModes.NO );
              var desc49 = new ActionDescriptor();
              desc49.putInteger( idLvl, 0 );
              var idexit = stringIDToTypeID( "exit" );
              desc49.putEnumerated( idStte, idStte, idexit );
                  var desc50 = new ActionDescriptor();
                  desc50.putString( idIdnt, """zoom""" );
                  desc50.putString( idTtl, """Zoom Tool""" );
              desc49.putObject( idTool, idTool, desc50 );
              desc49.putEnumerated( idKnd, idKnd, idmouse );
              desc49.putBoolean( idkcanDispatchWhileModal, true );
          executeAction( idtoolModalStateChanged, desc49, DialogModes.NO );
          • 2. Re: Zoom in guide sections
            Jarda Bereza Level 4
            Try this:
            1) manual zoom in
            2) hold "H" key
            3) mouse click down
            4) drag mouse
            5) mouse click up
            Is this better than regular zooming?
            • 3. Re: Zoom in guide sections
              Thank you, I am familiar with this workflow.The reason I like using grid system because when I am working on a super high-resolution image of 10K resolution.I make my grids like 6X6 and go through one by one to fix any issues or artifacts.That way I know I am not missing any thing.
              • 4. Re: Zoom in guide sections
                Tom Winkelmann Level 2
                And if you set the size of your artboard to the size you wanna zoom in (e.g. 400x400px)? Then insert your image, so that you see only a part (400x400px) of your whole image.
                With some simple scripts, you can move the layer with your image (400px) left/right/up/down (can be done with shortcuts).
