Hello,
I have a problem with DrawShape script: Draw Shape in Photoshop with JavaScript · GitHub:
/* Code by Mike Hale http://www.ps-scripts.com/bb/viewtopic.php?f=14&t=1802&start=15
with small modification by Vladimir Carrer
function DrawShape() {
var doc = app.activeDocument;
var y = arguments.length;
var i = 0;
var lineArray = [];
for (i = 0; i < y; i++) {
lineArray = new PathPointInfo;
lineArray.kind = PointKind.CORNERPOINT;
lineArray.anchor = arguments;
lineArray.leftDirection = lineArray.anchor;
lineArray.rightDirection = lineArray.anchor;
var lineSubPathArray = new SubPathInfo();
lineSubPathArray.closed = true;
lineSubPathArray.operation = ShapeOperation.SHAPEADD;
lineSubPathArray.entireSubPath = lineArray;
var myPathItem = doc.pathItems.add("myPath", [lineSubPathArray]);
var desc88 = new ActionDescriptor();
var ref60 = new ActionReference();
ref60.putClass(stringIDToTypeID("contentLayer"));
desc88.putReference(charIDToTypeID("null"), ref60);
var desc89 = new ActionDescriptor();
var desc90 = new ActionDescriptor();
var desc91 = new ActionDescriptor();
desc91.putDouble(charIDToTypeID("Rd "), 0.000000); // R
desc91.putDouble(charIDToTypeID("Grn "), 0.000000); // G
desc91.putDouble(charIDToTypeID("Bl "), 0.000000); // B
var id481 = charIDToTypeID("RGBC");
desc90.putObject(charIDToTypeID("Clr "), id481, desc91);
desc89.putObject(charIDToTypeID("Type"), stringIDToTypeID("solidColorLayer"), desc90);
desc88.putObject(charIDToTypeID("Usng"), stringIDToTypeID("contentLayer"), desc89);
executeAction(charIDToTypeID("Mk "), desc88, DialogModes.NO);
myPathItem.remove();
// X,Y
// Put the coordinates in clockwise order
DrawShape([100, 100], [100, 200], [200, 200], [200, 100]);
I need to make a modification that will allow to enter Drawshape arguments from a defined array.
By default, the argument must be entered manually into a function as a set of points, for example: [100, 100], [100, 200], [200, 200], [200, 100].
I need to get this effect: DrawShape(myarray), where myarray is defined by function:
var importpoints= "0,26.82;14.44,38.23;10.74,42.89;20.77,50.83;45.78,19.33;21.32,0;0,26.82";
var myarray = importpoints.split(";");
for (var i = 0; i < myarray.length; i++) {
myarray = myarray.split(",");
The code that is written does not work. I can not understand how the myarray array should be defined so that it can be used as an argument to the DrawShape function.
Finally, the coordinates I want to load from the txt file, hence the idea to import txt into the table. Sorry for my English.
Some amendments might be needed for the way you want to use it.
with small modification by Vladimir Carrer and further editing
#target photoshop
function DrawShape(theArray) {
var y = theArray.length;
var i = 0;
var lineArray = [];
#target photoshop
var i = 0;
var lineArray = [];
lineArray.anchor = [Number(theArray[0]),Number (theArray[1])];
$.writeln(theArray.join("___")+("\n"))
DrawShape (myarray);
To create Paths with more than one subPathItem and bezier handles that are not identical with the points themselves you could use this:
var thePath = createPath2015([[[[123.946875,67.756875],[153.647014898625,67.756875],[94.246735101375,67.756875], true],[[177.72375,121.53375],[177.72375,151.233889898625],[177.72375,91.833610101375], true],
[[123.946875,175.310625],[94.246735101375,175.310625],[153.647014898625,175.310625], true],[[70.17,121.53375],[70.17,91.833610101375],[70.17,151.233889898625], true], true,1097098272],
[[[173.3953125,133.648125],[194.627376180187,133.648125],[152.163248819812,133.648125], true],[[211.839375,172.0921875],[211.839375,193.324251180188],[211.839375,150.860123819812], true],
[[173.3953125,210.53625],[152.163248819812,210.53625],[194.627376180187,210.53625], true],[[134.95125,172.0921875],[134.95125,150.860123819812],[134.95125,193.324251180188], true], true, 1737]], "aaa");
////// create a path from collectPathInfoFromDesc2012-array //////
function createPath2015(theArray, thePathsName) {
var originalRulerUnits = app.preferences.rulerUnits;
app.preferences.rulerUnits = Units.PIXELS;
// thanks to xbytor;
cTID = function(s) { return app.charIDToTypeID(s); };
sTID = function(s) { return app.stringIDToTypeID(s); };
var desc1 = new ActionDescriptor();
var ref1 = new ActionReference();
ref1.putProperty(cTID('Path'), cTID('WrPt'));
desc1.putReference(sTID('null'), ref1);
var list1 = new ActionList();
for (var m = 0; m < theArray.length; m++) {
var thisSubPath = theArray
; var desc2 = new ActionDescriptor();
desc2.putEnumerated(sTID('shapeOperation'), sTID('shapeOperation'), thisSubPath[thisSubPath.length - 1]);
var list2 = new ActionList();
var desc3 = new ActionDescriptor();
desc3.putBoolean(cTID('Clsp'), thisSubPath[thisSubPath.length - 2]);
var list3 = new ActionList();
for (var n = 0; n < thisSubPath.length - 2; n++) {
var thisPoint = thisSubPath
; var desc4 = new ActionDescriptor();
var desc5 = new ActionDescriptor();
desc5.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), thisPoint[0][0]);
desc5.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), thisPoint[0][1]);
desc4.putObject(cTID('Anch'), cTID('Pnt '), desc5);
var desc6 = new ActionDescriptor();
desc6.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), thisPoint[1][0]);
desc6.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), thisPoint[1][1]);
desc4.putObject(cTID('Fwd '), cTID('Pnt '), desc6);
var desc7 = new ActionDescriptor();
desc7.putUnitDouble(cTID('Hrzn'), cTID('#Rlt'), thisPoint[2][0]);
desc7.putUnitDouble(cTID('Vrtc'), cTID('#Rlt'), thisPoint[2][1]);
desc4.putObject(cTID('Bwd '), cTID('Pnt '), desc7);
desc4.putBoolean(cTID('Smoo'), thisPoint[3]);
list3.putObject(cTID('Pthp'), desc4);
desc3.putList(cTID('Pts '), list3);
list2.putObject(cTID('Sbpl'), desc3);
desc2.putList(cTID('SbpL'), list2);
list1.putObject(cTID('PaCm'), desc2);
desc1.putList(cTID('T '), list1);
executeAction(cTID('setd'), desc1, DialogModes.NO);
// name work path;
var check = false;
var x = activeDocument.pathItems.length - 1;
while (check == false) {
if (activeDocument.pathItems
.kind == PathKind.WORKPATH) { app.activeDocument.pathItems
.name = thePathsName; var myPathItem = app.activeDocument.pathItems
; check = true
x--
app.preferences.rulerUnits = originalRulerUnits;
return myPathItem
Nice.
I think Jive added wrong spaces.
Here
var thePath = createPath2015([[[[123.946875,67.756875],[153.647014898625,67.756875],[94.246735101375,67 .756875],
should be
and here
[[211.839375,172.0921875],[211.839375,193.324251180188],[211.839375,150.86012381981 2], true],
should be
After these little changes your code runs.
One question:
What changes are necessary to create shapes instead of paths?
https://forums.adobe.com/people/pixxxel+schubser wrote
Nice.
should be
shoulld be 7.7 not 7 .7
Yes. (Jive - again)
Thanks for noticing the breaks.
This should create a Shape Layer:
#target photoshop
var thePath = createShapeLayer([[[[123.946875,67.756875],[153.647014898625,67.756875],[94.246735101375,67.756875], true],[[177.72375,121.53375],[177.72375,151.233889898625],[177.72375,91.833610101375], true],
[[173.3953125,210.53625],[152.163248819812,210.53625],[194.627376180187,210.53625], true],[[134.95125,172.0921875],[134.95125,150.860123819812],[134.95125,193.324251180188], true], true, 1737]], "aaa", 0, 128, 0);
////// create a solid color layer //////
function createShapeLayer(theArray, thePathsName, theR, theG, theB) {
// solid color layer;
var desc16 = new ActionDescriptor();
var ref4 = new ActionReference();
ref4.putClass( stringIDToTypeID( "contentLayer" ) );
desc16.putReference( charIDToTypeID( "null" ), ref4 );
var desc17 = new ActionDescriptor();
var desc18 = new ActionDescriptor();
var desc19 = new ActionDescriptor();
desc19.putDouble( charIDToTypeID( "Rd " ), theR );
desc19.putDouble( charIDToTypeID( "Grn " ), theG );
desc19.putDouble( charIDToTypeID( "Bl " ), theB );
desc18.putObject( charIDToTypeID( "Clr " ), charIDToTypeID( "RGBC" ), desc19 );
var idsolidColorLayer = stringIDToTypeID( "solidColorLayer" );
desc17.putObject( charIDToTypeID( "Type" ), idsolidColorLayer, desc18 );
desc16.putObject( charIDToTypeID( "Usng" ), stringIDToTypeID( "contentLayer" ), desc17 );
executeAction( charIDToTypeID( "Mk " ), desc16, DialogModes.NO );
return activeDocument.activeLayer
