13 Replies Latest reply on Mar 18, 2018 6:01 AM by Kukurykus
    Reopen dialog box
    geppettol66959005 Level 2
      I often use dialog boxes
      sometimes it would be useful for me to reopen after doing the job
      to close the panel you use
      win.close ();
      to reopen what I should put in
      win.open ();
      unfortunately it does not work
      you have some idea about it
        • 1. Re: Reopen dialog box
          c.pfaffenbichler Level 9
          Please explain what good that would be; what is the dialog for and how would that second showing of the dialog-window be included in the Script’s workflow?
          • 2. Re: Reopen dialog box
            once I click ok
            the panel closes
            use selected action
            app.bringToFront();
            function main(){
            var dlg=
            "dialog{text:'PANNEL ACTION',bounds:[100,100,510,240],"+
            "panel0:Panel{bounds:[10,10,400,130] , text:'' ,properties:{borderStyle:'etched',su1PanelCoordinates:true},"+
            "title:StaticText{bounds:[120,10,280,30] , text:'ACTION' ,properties:{scrolling:undefined,multiline:undefined}},"+
            "ActionSet:DropDownList{bounds:[10,40,190,60]},"+
            "ActionName:DropDownList{bounds:[200,40,380,60]},"+
            "button0:Button{bounds:[240,80,340,105] , text:'Ok' },"+
            "button1:Button{bounds:[20,80,120,105] , text:'Cancel' }}}";
            var win = new Window(dlg);
            if(version.substr(0,version.indexOf('.'))>9){
            win.panel0.title.graphics.font = ScriptUI.newFont("Georgia","BOLDITALIC",20);
            g = win.graphics;
            var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [1.00, 1.00, 1.00, 1]);
            //g.backgroundColor = myBrush;
            //var myPen =g.newPen (g.PenType.SOLID_COLOR, [1.00, 0.00, 0.00, 1],lineWidth=1);
            win.center();
            var actionSets = new Array();
            actionSets = getActionSets();
            for (var i=0,len=actionSets.length;i<len;i++) {
              item = win.panel0.ActionSet.add ('item', "" + actionSets[i]);
            win.panel0.ActionSet.selection=0;
            var actions = new Array();
            actions = getActions(actionSets[0]);
            for (var i=0,len=actions.length;i<len;i++) {
              item = win.panel0.ActionName.add ('item', "" + actions[i]);
            win.panel0.ActionName.selection=0;
            win.panel0.ActionSet.onChange = function() {
            win.panel0.ActionName.removeAll();
            actions = getActions(actionSets[parseInt(this.selection)]);
            var done = false;
                while (!done) {
                  var x = win.show();
                  if (x == 0 || x == 2) {
                    win.canceled = true;
                    //Cancelled
                    done = true;
                  } else if (x == 1) {
                    done = true;
                   var result = valiDate();
                    if(result != true) {
                    alert(result);
                    return;
                    }else
                  //  alert(win.panel0.ActionName.selection.text + " " + win.panel0.ActionSet.selection.text);  ////DISATTIVANDO QUESTA STRINGA NON ESCE LA FINESTRA DI AVVISO
                    doAction(win.panel0.ActionName.selection.text, win.panel0.ActionSet.selection.text);
            main();
            function valiDate(){
            return true;
            function getActionSets() {
            cTID = function(s) { return app.charIDToTypeID(s); };
            sTID = function(s) { return app.stringIDToTypeID(s); };
              var i = 1;
              var sets = [];
              while (true) {
                var ref = new ActionReference();
                ref.putIndex(cTID("ASet"), i);
                var desc;
                var lvl = $.level;
                $.level = 0;
                try {
                  desc = executeActionGet(ref);
                } catch (e) {
                  break;    // all done
                } finally {
                  $.level = lvl;
                if (desc.hasKey(cTID("Nm  "))) {
                  var set = {};
                  set.index = i;
                  set.name = desc.getString(cTID("Nm  "));
                  set.toString = function() { return this.name; };
                  set.count = desc.getInteger(cTID("NmbC"));
                  set.actions = [];
                  for (var j = 1; j <= set.count; j++) {
                    ref.putIndex(cTID('Actn'), j);
                    ref.putIndex(cTID('ASet'), set.index);
                    var adesc = executeActionGet(ref);
                    var actName = adesc.getString(cTID('Nm  '));
                    set.actions.push(actName);
                  sets.push(set);
                i++;
              return sets;
            function getActions(aset) {
              var i = 1;
              var names = [];
              if (!aset) {
                throw "Il set azione deve essere specificato";
              while (true) {
                var desc;
                try {
                } catch (e) {
                  break;    // all done
                  var name = desc.getString(cTID("Nm  "));
                  if (name == aset) {
                    var count = desc.getInteger(cTID("NmbC"));
                    var names = [];
                    for (var j = 1; j <= count; j++) {
                      ref.putIndex(cTID('ASet'), i);
                      names.push(actName);
                    break;
                i++;
              return names;
            At the end of the process I would like to open the window again
            to use another set of actions.
            thank you
            • 3. Re: Reopen dialog box
              Davide_Barranca Adobe Community Professional
              I've slightly modified your code:
              app.bringToFront();
              function main(){
              var dlg=
              "button0:Button{bounds:[240,80,340,105] , text:'Run' },"+
              "button1:Button{bounds:[20,80,120,105] , text:'Close' }}}";
              g = win.graphics;
              win.center();
              win.panel0.button0.onClick = function() {
                  if (valiDate()) { doAction(win.panel0.ActionName.selection.text, win.panel0.ActionSet.selection.text); }
              win.panel0.button1.onClick = function() {
                  win.close()
              var x = win.show();
              main();
              return true;
                var i = 1;
                var sets = [];
                while (true) {
                  var desc;
                  var lvl = $.level;
                  $.level = 0;
                  try {
                  } catch (e) {
                    break;    // all done
                  } finally {
                    $.level = lvl;
                    var set = {};
                    set.index = i;
                    set.actions = [];
                    sets.push(set);
                  i++;
                return sets;
                var i = 1;
                var names = [];
                if (!aset) {
                while (true) {
                  var desc;
                  try {
                  } catch (e) {
                    break;    // all done
                    if (name == aset) {
                      var names = [];
                      break;
                  i++;
                return names;
              The idea is that you create a Click event handler for the two buttons: the Run doesn't close the dialog, but runs the doAction.
              Let me know if I've got the valiDate function correctly.
              Hope this helps,
              Davide
              • 4. Re: Reopen dialog box
                This and a solution that I have already adopted, however, is not in my case
                I want the window to close and finally reopen
                I do not want you to stay active.
                • 5. Re: Reopen dialog box
                  Chuck Uebele Adobe Community Professional & MVP
                  Sounds like you might need to save your UI controls to an external file like an XML file, that can be reloaded with your last settings, and then either run the script again, or proceed from some other starting point within the script. This option can be saved also in an XML file. Here's a section of an XML file that I use to save all the data in a rather lengthy UI for one of my scripts.
                  • 6. Re: Reopen dialog box
                    Kukurykus Adobe Community Professional
                    Shouldn't you just use second main(), after first main()? Or perhaps you want it to open each time after some action you applied ended untill you eventually click 'Close' button. So not only twice but multitimes? if so it's very easy, replace lines:
                    1st to: app.bringToFront(); var c
                    62nd to: c = win.canceled = true
                    81st to: while(!c) main()
                    • 7. Re: Reopen dialog box
                      r-bin Level 4
                      dlg.opacity = 0.0;  // hides dialog
                      dlg.opacity = 1.0;  // shows dialog
                      • 8. Re: Reopen dialog box
                        Kukurykus
                        On photoshop 2018 it's not good
                        r-bin
                        I did not understand how to apply your scripts
                        you could be simpler.
                        Thank you
                        • 9. Re: Reopen dialog box
                          r-bin Level 4
                          Instead of win.close () from the first message, use win.opacity = 0.0
                          Instead of win.open (), use win.opacity = 1.0
                          What's wrong?
                          • 10. Re: Reopen dialog box
                            I tested your first big code with those 3 changes in CS6 EXTENDED and CC2018 (19.1.2) and there weren't any problems with.
                            • 11. Re: Reopen dialog box
                              Kukurykus
                              I did something wrong
                              now it seems to be fine
                              • 12. Re: Reopen dialog box
                                r-bin
                                I've also tried yours and it works very well
                                thanks to both for the help.
                                • 13. Re: Reopen dialog box
                                  I tried r-bin method but it didin't work for me. Could post exact lines with changes you made so I'll try it again.
                                  Btw there is other topic of you I replied to, but it seems you missed it: slider blur
