1 Reply Latest reply on Sep 3, 2017 9:08 PM by JJMack
    Crop Tool Resizes (Sometimes)
    Jack Level 1
      In the past I was able to set the crop tool for fixed-ratio dimensions, select the area, crop, and the result is rendered at the dimensions of the crop tool. Now that is no longer happening, and I am suspecting that some setting was changed. If one of you could show me where that is, I would be grateful.
      Best,
      jwc
        • 1. Re: Crop Tool Resizes (Sometimes)
          Yes if you specify a resolution it will interrpolate the crop. for example
          Crops will be resampled to 1800x1200 pixels 6"x4"@300DPI
          You want just a straight Aspect Ratio Crop any size any resolution.
          3:2, 6:4, 12:8, 9:6  all these are 3:2 aspect ratios
