Hello,
I currently use adobe animate cc trial and I do not have the panel to do blur effects for example.
As in this tutorial =>https://helpx.adobe.com/fr/animate/using/graphic-filters/_jcr_content/main-pars/image_0.img.png/se_f... (Utilisation de filtres graphiques dans Animate CC )
I can only change the size and position
Could you tell me how I can add the missing panels?
thank you very much
Filters can only be applied to MovieClip and Button Symbols. You will need to select the object on the stage and convert it to a Symbol, then select it again and look at the bottom of the Properties window. You should now see the filters section.
