• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
String array to int array.
New Here ,
Sep 05, 2017 Sep 05, 2017
Hello. In my aplication i save progress in txt files. Where i save all variables
....//example
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
0,6,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
My script load all fast and good, But problem is one. Its loades as String not Number
       var variablesList = [];
        var variableFile= new File("C://Users//FCT//Documents//testVar.txt"); //open order.txt file
        variableFile.open('r');
        while (!variableFile.eof) { //get all lines from order txt file
        st = variableFile.readln();
        variablesList.push(st);
  } //end of all lines from order txt file
        variableFile.close();
     alert(startFrom);
apronBlackCounter=variablesList[0].split(',');
apronFuchsiaCounter=variablesList[1].split(',');
apronRedCounter=variablesList[2].split(',');
apronRoyalBlueCounter=variablesList[3].split(',');
How can i conver that to number when i cant use .map(Number);???
I shuld make" for (var i=0;apronBlackCounter.length; i++){    apronBlackCounter = parseInt(apronBlackCounter);} ". But it wont work...
TOPICS
Actions and scripting
Views
337
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Advocate ,
what about this:
var myArray = myString.split(",");
This will convert string to array. Replace "," if you use other character as a separator.
Votes
Translate
Translate
Report
Report
Guide ,
This may help.
   //  alert(startFrom);
alert(typeof(apronBlackCounter[0]));
alert(typeof(Number(apronBlackCounter[0])));
Votes
Translate
Translate
Report
Report
Community Expert ,
You can use several things to convert a string to a number. For what you're doing, I use:
var myNum = parseInt('0')//will give an interger. This will strip any string elements like px after the number.
var myNum = parseFloat('0')//will give an floating number
var myNum = Number('0')//will not give just an integer if the original number is a floating point number. Will give NaN error if any string elements are included.
var myNum = Math.round('0')//will give an interger and round the number.
var myNum = Math.ceil('0')//will give an interger and always round up.
var myNum = Math.floor('0')//will give an interger and always round down.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Here is polyfill for map: Array.prototype.map() - JavaScript | MDN
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Neat. learn something new from you all the time.
Votes
Translate
Translate
Report
Report
