1 Reply Latest reply on Sep 7, 2017 11:32 AM by flavienl41432793
    Connecting to the admin console restarts multicast publishing
    flavienl41432793
      We have a serious issue
      We recently noticed that some log files are showing that when we connect to a server with the admin (Flash) console our multicast streams are republished.
      Also Core App seems to restart.
      We are running AMS Professional 5.0.14 r4006
      CORE.00
      #Date: 2017-09-05
      #Fields: date    time    x-pid    x-status    x-ctx    x-comment
      2017-09-05    10:49:41    12060    (i)2581237    Starting admin app on core (12060).    -
      2017-09-05    10:49:41    12060    (i)2581238    Core (12060) connecting to admin.    -
      2017-09-05    10:49:41    12060    (i)2581231    Core (12060) connected to admin.    -
      2017-09-05    10:49:41    12060    (i)2581234    Core (12060) connection to admin accepted.    -
      2017-09-05    10:49:41    12060    (i)2631174    Listener started ( _defaultRoot_ ) : 10.xx.xx.xx:19351 (rtmfp-core)/v4    -
      2017-09-05    10:49:41    12060    (i)2631174    Listener started ( _defaultRoot_ ) : 127.0.0.1:19351 (rtmfp-core)/v4    -
      2017-09-05    10:49:41    12060    (i)2631509    Public rtmfp-core addresses for listener _defaultRoot_ are: 10.xx.xx.xx:19351;10.xx.xx.xx:19351;127.0.0.1:19351    -
      2017-09-05    10:49:41    12060    (i)2581246    Core (12060) sending register cmd to edge.    -
      2017-09-05    10:49:41    12060    (i)2631521    Successfully bound and configured RTMFP native multicast socket for addr: 10.xx.xx.0:30000. Specific source addr: .     -
      2017-09-05    10:49:41    12060    (i)2631521    Successfully bound and configured RTMFP native multicast socket for addr: 10.xx.xx.1:30000. Specific source addr: .     -
      ACCESS.00
      #Date: 2017-09-05
      Fields: x-event    x-category    date    time    tz    x-ctx    s-ip    x-pid    x-cpu-load    x-mem-load    x-adaptor    x-vhost    x-app    x-appinst    x-duration    x-status    c-ip    c-proto    c-proto-ver    s-uri    cs-uri-stem    cs-uri-query    c-referrer    c-user-agent    c-client-id    cs-bytes    sc-bytes    c-connect-type    x-sname    x-sname-query    x-suri-query    x-suri-stem    x-suri    x-file-name    x-file-ext    x-file-size    x-file-length    x-spos    c-spos    cs-stream-bytes    sc-stream-bytes    x-service-name    x-sc-qos-bytes    x-comment    x-eid    x-sid    x-trans-sname    x-trans-sname-query    x-trans-file-ext    x-trans-mode    x-soffset    x-codec-type    x-codec    x-plugin    x-page-url    x-smax-rec-size    x-smax-rec-duration    x-forwarded-for    x-sprotection-ver
      server-start    server    2017-09-05    10:49:40    Eastern Daylight Time    -    -    12060    0    10    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -
      vhost-start    vhost    2017-09-05    10:49:41    Eastern Daylight Time    _defaultVHost_    -    12060    0    10    _defaultRoot_    _defaultVHost_    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -
      app-start    application    2017-09-05    10:49:41    Eastern Daylight Time    multicast    -    12060    -    -    _defaultRoot_    _defaultVHost_    multicast    _definst_    -    -    -    -    -    -    -    -    -    -    -    0    0    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -    -
      ADMIN.00
      2017-09-05    10:49:40    1216    (i)2581242    Core (11312) disconnected : _defaultRoot_:_defaultVHost_:::_1.    -
      2017-09-05    10:49:41    1216    (i)2581241    Connection to admin received.    -
      2017-09-05    10:49:41    1216    (i)2581243    Connection from core 12060 received.    -
      2017-09-05    10:49:41    1216    (i)2581244    Connection from core 12060 accepted.    -
      MASTER.00
      2017-09-05    10:49:40    1148    (i)2581223    Core (11312) is no longer active.    -
      2017-09-05    10:49:40    1148    (w)2581256    Core (11312) _defaultRoot_:_defaultVHost_:::_1 experienced 1 failure[s]!    -
      2017-09-05    10:49:40    1148    (i)2581221    Core (12060) started, arguments : -adaptor "_defaultRoot_" -vhost "_defaultVHost_" -app  -inst  -tag "_1" -conf "D:\Adobe Media Server 5\conf\server.xml" -name "_defaultRoot_:_defaultVHost_:::_1".    -
      2017-09-05    10:49:41    1148    (i)2581223    Core (11312) is no longer active.    -
      I confirm that the server was running before 10:49:41 (streams were pushed to mutlicast groups)
      Thank you.
