10 Replies Latest reply on Sep 19, 2017 5:03 AM by Vinothmannu
    Increment text value in illustrator
    Vinothmannu Level 1
      Hi All,
      i have found the below script for text increment in illustrator this is working fine, but i need the increment value to be variable
      If the starting number is 7 and the increment value is 7 and number of steps is 5 then our requirement would be 7,14, 21,28,35.
      #target illustrator
      var selectedItems;
      // if a document is open
      if(documents.length >0)
          var idoc = app.activeDocument;
         // if textframes exist in the document
         if(activeDocument.textFrames.length > 0)
            // check to make sure something is selected.
            selectedItems = selection
            if (selectedItems.length > 0)
                  var itemFound = false;
                  for(var i=0; i<selectedItems.length; i++)
                     if(selectedItems[i].typename == "TextFrame")
                        itemFound = true;
                        alert ("The following text item is selected: >" + selectedItems[i].contents + "<")
                        var startNum = prompt ("Enter a starting number");
                        var incY = prompt ("Enter a Y offset in points (72 points = 1 inch)", "72", "Y Offset");
                        var steps = prompt ("How many steps?");
                        var increment = prompt ("count?"); //Added new
                        selectedItems[i].contents = startNum;
                        var myGroup = app.activeDocument.groupItems.add();
                        selectedItems[i].move( myGroup , ElementPlacement.PLACEATEND);
                        selectedItems[i].position = [0,0];
                        for(var a=0; a<steps; a++)
                            selectedItems[i].duplicate ();
                            var newNumber = parseFloat(startNum) + (a+1);
                            selectedItems[i].contents = newNumber;
                            var newY = incY / 72;
                            selectedItems[i].position = [0, -((a+1)*incY)];
                  if(itemFound == false) alert("No text items are selected.");
            else
               alert("Nothing is selected, select a text item(s) or a text range.");
         else
            alert("Open a document and select 1 or more text items or a text range.");
      else
      Regards,
      Vinoth
        • 1. Re: Increment text value in illustrator
          Ten A Adobe Community Professional
          Try to change this line,
          var newNumber = parseFloat(startNum) + (a+1) ;
          to
          var newNumber = parseFloat(startNum) + (a+1) * increment;
          • 2. Re: Increment text value in illustrator
            Vinothmannu Level 1
            Thanks for the update, its working.
            Instead of [0,0]; position the text has to be retained in the same position where the text is selected, it that is possible.
            Regards,
            Vinoth
            • 3. Re: Increment text value in illustrator
              Vinothmannu Level 1
              Any further updates for the above.
              • 4. Re: Increment text value in illustrator
                You can reference selected objects position, duplicate it and move it. reference below
                var pos = selectedItems.position;
                for(.....){
                   SelectedItems.position = [pos[0], pos[1]-((a+1)*incY)]
                • 5. Re: Increment text value in illustrator
                  Vinothmannu Level 1
                  Thanks for update Ten,
                  I am not so good in scripting, could you please update this for me.
                  Regards,
                  Vinoth
                  • 6. Re: Increment text value in illustrator
                    Try it
                    #target illustrator
                    var selectedItems, pos;
                                      itemFound = true;
                                      //selectedItems[i].position = [0,0]; //ignore this line.
                                      pos = selectedItems[i].position; //get original objects position(x,y cordinates) in Array.
                                          selectedItems[i].position =  [pos[0], pos[1]-((a+1)*incY)]; //
                          else
                       else
                    else
                    However, I recommend you to learn around Scripting. Actually, We don't have enough time to write for someone and you don't always get it.
                    • 7. Re: Increment text value in illustrator
                      Vinothmannu Level 1
                      Thanks a lot. surely i am in the learning process.
                      • 8. Re: Increment text value in illustrator
                        Vinothmannu Level 1
                        In the decimal value for example 0.5 , 1.0 , 1.5 , 2.0. etc the value are found as 0.5 , 1 , 1.5 , 2. the value of 0 is missing after round value.
                        • 9. Re: Increment text value in illustrator
                          You can use toFix method like below.
                          var pai = 3.1415926535897932;
                          var fixedValue = pai.toFix(1);
                          • 10. Re: Increment text value in illustrator
                            Vinothmannu Level 1
                            Great i solved this issue, Thanks
