I have implemented a touch ui datepicker in page properties for a template. When I click on the datepicker the little calendar shows up and does not go to previous years. I have tried setting minDate to be a date in the past but I still can't navigate beyond the current year. Also the dates for the calendar not in the current month show NaN. I don't see any relevant errors in the logs or the browser console.
this is how i have the dialog implemented the field in question is publishedDate:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<jcr:root fileName="_cq_dialog.xml" xmlns:jcr="http://www.jcp.org/jcr/1.0" jcr:primaryType="nt:unstructured" jcr:title="Technical Article" mode="edit" xmlns:sling="http://sling.apache.org/jcr/sling/1.0" sling:resourceType="cq/gui/components/authoring/dialog">
<content jcr:primaryType="nt:unstructured" sling:resourceType="granite/ui/components/foundation/container">
<layout jcr:primaryType="nt:unstructured" sling:resourceType="granite/ui/components/foundation/layouts/tabs"/>
<items jcr:primaryType="nt:unstructured">
<TechnicalArticle xmlns:cq="http://www.day.com/jcr/cq/1.0" cq:hideOnEdit="{Boolean}false" cq:showOnCreate="{Boolean}true" jcr:primaryType="nt:unstructured" jcr:title="Technical Article" sling:resourceType="granite/ui/components/foundation/section">
<layout jcr:primaryType="nt:unstructured" sling:resourceType="granite/ui/components/foundation/layouts/fixedcolumns"/>
<column jcr:primaryType="nt:unstructured" sling:resourceType="granite/ui/components/foundation/container">
<author cq:hideOnEdit="{Boolean}false" cq:showOnCreate="{Boolean}true" disabled="{Boolean}false" fieldLabel="Author" jcr:primaryType="nt:unstructured" name="./author" renderReadOnly="{Boolean}true" required="{Boolean}false" sling:resourceType="granite/ui/components/foundation/form/textfield"/>
<publishedDate cq:hideOnEdit="{Boolean}false" cq:showOnCreate="{Boolean}true" disabled="{Boolean}false" displayedFormat="MM/DD/YYYY" fieldLabel="Published Date" jcr:primaryType="nt:unstructured" minDate="0" name="./publishedDate" renderReadOnly="{Boolean}true" required="{Boolean}false" sling:resourceType="granite/ui/components/foundation/form/datepicker" storedFormat="YYYY-MM-DD[T]HH:mm:ss.000Z"/>
<partNumber cq:hideOnEdit="{Boolean}false" cq:showOnCreate="{Boolean}true" disabled="{Boolean}false" fieldLabel="Part Number" jcr:primaryType="nt:unstructured" name="./partNumber" renderReadOnly="{Boolean}true" required="{Boolean}false" sling:resourceType="granite/ui/components/foundation/form/textfield"/>
</items>
</column>
</items>
</TechnicalArticle>
</items>
</content>
</jcr:root>
Views
Total Likes
I will look at this to see if this occurs or if issue in your environment for some reason.
Also - if a Granite data type does not meet your needs - there is a simple fix. You can write a custom sling resource type for a Touch UI component dialog. See this article where we used a color picker as an example -- Scott's Digital Community: Creating a custom Experience Manager sling:resourceType for Touch UI
A custom sling resource type is just a JQuery plug-in.
Views
Total Likes
There are many JQuery plug-ins that you can use for this purpose: http://www.learningjquery.com/2015/03/14-top-calendar-and-date-picker-jquery-plugins
Views
Total Likes
I have pasted the same xml you have provided in my dialog and it is working as expected and I am using AEM 6.2. Which version of AEM you are using?
Views
Total Likes
I'm using 6.1 with SP2 and Cumulative Fix Pack 8, I also tried it on my 6.2 instance and got the same result.
It seems to only be an issue when I select "view properties" from edit mode on the page. If I select view properties from the site manager it works as expected.
Views
Total Likes
You found any solution for this issue. I am also facing the same issue in my environment.
Views
Total Likes
Can you try with Coral3 type
e.g. granite/ui/components/coral/foundation/form/datepicker
Views
Total Likes
I am using AEM 6.1 SP2 and dont have coral components.
Views
Total Likes
