7 Replies Latest reply on Sep 8, 2017 6:11 AM by Ps-Design
    How to check if there is any layer with the color red?
    smithcgl9043167 Level 2
      Hello everyone! I need to find a way to perform a task only in layers determined by the red color: It would greatly facilitate a script that checks if there is any layer with the color red in the document. If it exists: Trigger an alert with the message "true!" If it does not exist: Trigger an alert with the message "false" Thanks in advance!
        • 2. Re: How to check if there is any layer with the color red?
          Hi pixxxel schubser I've been working hard to understand scripts. Before my post I researched here and the closest result I found was this example from c.pfaffenbichler, but I confess that I could not understand and make modifications that meet my goals. A simple alert script stating that there is at least one layer of red color in the document already helped me a lot how to proceed.
          • 3. Re: How to check if there is any layer with the color red?
            c.pfaffenbichler Level 9
            Might the Layer Filter not suffice?
            So you found such a Script already?
            And would a Script selecting all red Layers not make more sense?
            • 4. Re: How to check if there is any layer with the color red?
              Hi c.pfaffenbichler! No, I have not found the script yet! I believe there was an error in the translation. The layer filter can be enough yes, it will check and identify if there is any layer with red color and if it exists then it will trigger a "Do something" alert if not "Do nothing".
              It would be somewhat similar to this script, it identifies whether the layer is visible or not, in my case, modify to identify whether or not there is layer with red color.
              Thanks for listening
              #target photoshop
              if ( app.documents.length <= 0 ) alert( "No Image in Use" );
              else{main();}
              function main(){
                  var docRef = app.activeDocument;
                  var myLayers=docRef.layers;
                  for(i=0; i<myLayers.length;i++){
                      if(myLayers[i].typename=="ArtLayer" && myLayers[i].visible==true ){
                          alert("Layer is Visible");
                      else if (myLayers[i].typename=="ArtLayer" && myLayers[i].visible==false ){
                          alert("Layer is inVisible");
              • 5. Re: How to check if there is any layer with the color red?
                Does this help?
                // 2017, use it at your own risk;
                #target photoshop
                if (app.documents.length > 0) {
                // the file;
                var myDocument = app.activeDocument;
                // get number of layers;
                var ref = new ActionReference();
                ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                var applicationDesc = executeActionGet(ref);
                var theNumber = applicationDesc.getInteger(stringIDToTypeID("numberOfLayers"));
                // process the layers;
                var theLayers = new Array;
                var theOthers = new Array;
                for (var m = 0; m <= theNumber; m++) {
                try {
                ref.putIndex( charIDToTypeID( "Lyr " ), m);
                var layerDesc = executeActionGet(ref);
                var layerSet = typeIDToStringID(layerDesc.getEnumerationValue(stringIDToTypeID("layerSection")));
                var isBackground = layerDesc.getBoolean(stringIDToTypeID("background"));
                // if not layer group collect values;
                if (layerSet != "layerSectionEnd" /*&& layerSet != "layerSectionStart"*/ && isBackground != true) {
                var theName = layerDesc.getString(stringIDToTypeID('name'));
                var theID = layerDesc.getInteger(stringIDToTypeID('layerID'));
                var visible = layerDesc.getBoolean(stringIDToTypeID("visible"));
                var theColor = layerDesc.getEnumerationValue(stringIDToTypeID("color"));
                if (typeIDToStringID(theColor) == "red") {theLayers.push([theName, theID])}
                else {theOthers.push([theName, theID])}
                catch (e) {};
                // if layers are red;
                if (theLayers.length > 0) {alert ("there is at least one red layer")}
                else {alert ("no red layers")}
                • 6. Re: How to check if there is any layer with the color red?
                  That was great. Perfect! This will help me a lot to give life to some projects that I have. c.pfaffenbichler,Thank you so much again.
                  • 7. Re: How to check if there is any layer with the color red?
                    Ps-Design Level 1
                    c.pfaffenbichler very interesting method of color checking, this will be very useful.
                    I have searched in this and other community something like this, but replaced color layer method by a value of the "width" size of the current document.
                    This post has already been answered, I'm going to create a discussion about scripting that I'm looking for.
