7 Replies Latest reply on Nov 1, 2017 5:08 PM by carogar7
    Adobe Acrobat DC 2017 Crashes 30 seconds after opening - mac OS Sierra
    marktru Level 1
      There are a ton of threads complaining about this same issue. I have not found a solution in any of them, as far as I can read. I'm going blind reading them, so I'm now going to ask directly. I am so disappointed that with all the threads on this, Adobe has not solved it yet, and in fact, every time an Adobe person engages in the thread, they act as if it is the first time they ever heard of the issue. And so all consideration of it starts at the beginning, even though that doesn't seem to have solved the problem for anyone -- so cut to the chase, stop wasting people's time.
      My Acrobat DC CC 2017, now at v. 17.009.20058, worked fine. Now it doesn't, it crashes every time I open it, crashing about 30 seconds after opening. It doesn't matter whether I even open anything in it, it crashes anyway, so its not a file that is causing it. Whether I try to do something or not, it crashes at about 30 seconds. It appears that something that goes on about 30 seconds after opening is the problem.
      I first noticed this problem 2-3 weeks ago. I had not used Acrobat since running Adobe CC 2017 updates at about the turn of August or early August, and around the same time updating my OS from macOS 10.12.5 to 10.12.6. I don't know if the problem started before or after those updates. After that, I cloned my main partition over to a second partition -- and the problem is on that second partition too, so it happened at the updates or before that, not since. I only installed Acrobat in early or mid May, and that August updating was the first time I updated since updating after the installation. So, whatever happened happened between the installation and that updating at about Aug. 1. Unfortunately, I do not know when I had last used Acrobat before that early August updating.
      I'm running macOS 10.12.16 on a Mac Mini (Late 2014) at 2.6 GHz Core i5 processor, 8 GB RAM, 1 TB HDD that tests as fine, passes SMART test.
      I have sent in at least a half dozen crash reports. The crash report is 30 pages long. I have seen so many long crash reports posted in the threads on this, I don't see any point in posting one here. However, I noted toward the top of mine a section identifying a problem, I think it must be THE problem:
      System Integrity Protection: enabled
      Crashed Thread:                0  Dispatch queue: com.apple.main-thread
      Exception Type:                EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes:               KERN_INVALID_ADDRESS at 0x0000000000000000
      Exception Note:                EXC_CORPSE_NOTIFY
      Termination Signal:            Segmentation fault: 11
      Termination Reason:            Namespace SIGNAL, Code 0xb
      Terminating Process:           exc handler [0]
      VM Regions Near 0:
      That is identifying a crashed Thread: 0. I don't even find com.apple.main-thread on my hard drive, I did a search, and I also looked in Library/Preferences and in User/(name)/Library/Preferences.
      Deep down in that crash report, I found what must be the thread: 0 it is talking of, in Thread 16 -- none of the other threads through 16 show any issue:
      Thread 16:
      0   libsystem_pthread.dylib          0x00007fffaba9e070 start_wqthread + 0
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x0000000000000000  rbx: 0x0000600000867740  rcx: 0x0000000000000000  rdx: 0x0000000000000005
        rdi: 0x0000000000000000  rsi: 0x00000001098b6f7d  rbp: 0x00007fff580e40c0  rsp: 0x00007fff580e40c0
         r8: 0x0000000000000000   r9: 0x0000000000000230  r10: 0x07534943226f0071  r11: 0x00007fd0a58097a0
        r12: 0x07534943226f0071  r13: 0x00007fd0a45122f8  r14: 0x00007fd0a4496710  r15: 0x00006080008561d0
        rip: 0x00007fffaba93e00  rfl: 0x0000000000010293  cr2: 0x0000000000000000
      Logical CPU:     0
      Error Code:      0x00000004
      Trap Number:     14
      Thread 16 at line 0 seems to be the Crashed Thread: 0 it is referring to.
      I looked for libsystem_pthread.dylib. There doesn't seem to be any libsystem_pthread.dylib on my computer. It does have two libsystem_pthread.tbd files, but not of that name ending in .dylib.
      So, those parts of my crash report should say where the problem is, what is causing it. And I am informing that Acrobat crashes about 30 seconds after opening. What does Acrobat do about 30 seconds after opening -- that is where the problem is?
      I have already done pretty much all the troubleshooting you can tell me to do. Nothing solves this, nothing makes any difference.
      I have taken the preferences out of the preferences folders, both the main one in Library/Preferences and the ones in User/(name)/Preferences/Adobe -- I took out the ones Adobe listed to take out and some more too.
      I have done restarts.
      I have started the computer in Safe Mode.
      I have uninstalled and reinstalled Acrobat from a new download via the CC 2017 Adobe Creative Cloud desktop application. That took most of  day, a huge download -- Adobe could at least let us download the installer to our desktop so we can have it going forward to do this instead of having to do four+ hours of downloading all the time.
      I booted from another partition with a clone of my main partition, same problem.
      I tried deleting cache files at:
      Font caches:
      /users/yoursessionname/Library/Application Support/Adobe/Acrobat/version number, eg DC/AdobeCMapFnt17.lst and AdobeSysFnt15.lst and AdobeSysFnt17.lst and UserCache64.bin
      Application caches:
      /users/yoursessionname/Library/Caches/Acrobat/version number, eg DC/AcroFnt17.lst
      I have Validated all the fonts in Font Book categorized as "pdf fonts."  I also found all the Adobe fonts I could, 5-6 of them, and Validated them -- there might be more, but they are not readily identifiable, ans I have more than 1,000 fonts.
      I tried taking all my fonts A-K out of the Fonts folder, and tested. No difference. I put them back in and tried taking out L-Z, no difference. Yes, of course I restarted each time before testing.
      I tried creating a new user account, and then booting into that account. No difference.
      I went to my Time Machine backup and actually moved the oldest Acrobat application, from around July 20, from there to my main partition, and tested it. Same problem.
      So, Adobe, what is the problem, how can I -- and a ton of other people here -- fix it? I have given you a lot of info here. So have people in other threads. You can't just keep selling Acrobat and not solve this issue -- that would be criminal. So, considering all the people having this issue, and for how long back in time I see people complaining about it, and all this time and all this info given to you -- I think you better make this a high priority to fix and pronto. That this does not have a solution yet is unconscionable.
      Message was edited by: Mark Trujillo 9/7/17, to fix typos.
        • 1. Re: Adobe Acrobat DC 2017 Crashes 30 seconds after opening - mac OS Sierra
          marktru Level 1
          OK, for lack of any interest whatsoever from Adobe to this problem so far, here is my LATEST full crash report -- maybe you will respond to this. I note, it is bot the same as the one I previously excerpted from, Thread 16 is not showing anything special in this one. So, the issue might be variable. This issue has been in the threads for years now. This is unconscionable:
          Process:           AdobeAcrobat [2065]
          Path:              /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
          Identifier:        com.adobe.Acrobat.Pro
          Version:           17.009.20058 (17.009.20058)
          Code Type:         X86-64 (Native)
          Parent Process:    ??? [1]
          Responsible:       AdobeAcrobat [2065]
          User ID:           502
          Date/Time:         2017-09-09 14:12:49.754 -0700
          OS Version:        Mac OS X 10.12.6 (16G29)
          Report Version:    12
          Anonymous UUID:    513B18A7-E1F6-4E5F-8406-52C0042CE596
          Sleep/Wake UUID:   9B8C19BB-9351-4FE8-8DBF-E2AE4AF3D843
          Time Awake Since Boot: 9500 seconds
          Time Since Wake:   3000 seconds
          Termination Signal:Segmentation fault: 11
          Termination Reason:Namespace SIGNAL, Code 0xb
          VM Regions Near 0:
          __TEXT             0000000101c38000-0000000101c39000 [4K] r-x/rwx SM=COW  /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
          Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
          0   libsystem_platform.dylib 0x00007fffa6492e00 _platform_strncmp + 320
          1   com.adobe.Acrobat.framework  0x0000000102738668 0x101c3d000 + 11515496
          2   com.adobe.Acrobat.framework  0x000000010271a945 0x101c3d000 + 11393349
          3   com.adobe.Acrobat.framework  0x0000000102e22c99 0x101c3d000 + 18767001
          4   com.adobe.Acrobat.framework  0x00000001035bcf29 0x101c3d000 + 26738473
          5   com.adobe.Acrobat.framework  0x00000001035bc95e 0x101c3d000 + 26736990
          6   com.adobe.Acrobat.framework  0x00000001035bcabc 0x101c3d000 + 26737340
          7   com.adobe.Acrobat.framework  0x0000000102ed9aa8 0x101c3d000 + 19516072
          8   com.adobe.Acrobat.framework  0x0000000102ed8b75 0x101c3d000 + 19512181
          9   com.adobe.Acrobat.framework  0x0000000101db2e51 0x101c3d000 + 1531473
          10  com.apple.Foundation     0x00007fff9256652a __NSThreadPerformPerform + 326
          11  com.apple.CoreFoundation 0x00007fff90b24321 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
          12  com.apple.CoreFoundation 0x00007fff90b0521d __CFRunLoopDoSources0 + 557
          13  com.apple.CoreFoundation 0x00007fff90b04716 __CFRunLoopRun + 934
          14  com.apple.CoreFoundation 0x00007fff90b04114 CFRunLoopRunSpecific + 420
          15  com.apple.HIToolbox      0x00007fff90064ebc RunCurrentEventLoopInMode + 240
          16  com.apple.HIToolbox      0x00007fff90064cf1 ReceiveNextEventCommon + 432
          17  com.apple.HIToolbox      0x00007fff90064b26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
          18  com.apple.AppKit         0x00007fff8e5fda54 _DPSNextEvent + 1120
          19  com.apple.AppKit         0x00007fff8ed797ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
          20  com.apple.AppKit         0x00007fff8e5f23db -[NSApplication run] + 926
          21  com.adobe.Acrobat.framework  0x0000000101c45f6d 0x101c3d000 + 36717
          22  com.adobe.Acrobat.framework  0x0000000101c448fe RunAcrobat + 246
          23  com.adobe.Acrobat.Pro    0x0000000101c38f47 main + 86
          24  libdyld.dylib            0x00007fffa6284235 start + 1
          Thread 1:: Dispatch queue: NSOperationQueue 0x60000023b4e0 :: NSOperation 0x60000023b500 (QOS: USER_INTERACTIVE)
          0   libsystem_kernel.dylib   0x00007fffa63b2f46 __semwait_signal + 10
          1   libsystem_c.dylib        0x00007fffa6339b72 nanosleep + 199
          2   com.apple.Foundation     0x00007fff925d1a1b +[NSThread sleepForTimeInterval:] + 156
          3   com.adobe.Acrobat.framework  0x0000000102ca034e 0x101c3d000 + 17183566
          4   com.apple.Foundation     0x00007fff92537324 -[__NSOperationInternal _start:] + 672
          5   com.apple.Foundation     0x00007fff925331db __NSOQSchedule_f + 201
          6   libdispatch.dylib        0x00007fffa624e8fc _dispatch_client_callout + 8
          7   libdispatch.dylib        0x00007fffa62649a0 _dispatch_queue_serial_drain + 896
          8   libdispatch.dylib        0x00007fffa6257306 _dispatch_queue_invoke + 1046
          9   libdispatch.dylib        0x00007fffa62506b5 _dispatch_root_queue_drain + 476
          10  libdispatch.dylib        0x00007fffa625048c _dispatch_worker_thread3 + 99
          11  libsystem_pthread.dylib  0x00007fffa649d5a2 _pthread_wqthread + 1299
          12  libsystem_pthread.dylib  0x00007fffa649d07d start_wqthread + 13
          Thread 2:
          0   libsystem_kernel.dylib   0x00007fffa63b344e __workq_kernreturn + 10
          1   libsystem_pthread.dylib  0x00007fffa649d621 _pthread_wqthread + 1426
          Thread 3:
          Thread 4:
          0   libsystem_kernel.dylib   0x00007fffa63b2bf2 __psynch_cvwait + 10
          1   libsystem_pthread.dylib  0x00007fffa649e7fa _pthread_cond_wait + 712
          2   com.adobe.AGM            0x000000010443d030 0x104430000 + 53296
          3   com.adobe.AGM            0x000000010443cf6d 0x104430000 + 53101
          4   com.adobe.AGM            0x00000001047ca265 0x104430000 + 3777125
          5   libsystem_pthread.dylib  0x00007fffa649d93b _pthread_body + 180
          6   libsystem_pthread.dylib  0x00007fffa649d887 _pthread_start + 286
          7   libsystem_pthread.dylib  0x00007fffa649d08d thread_start + 13
          Thread 5:
          Thread 6:
          Thread 7:
          2   com.adobe.Acrobat.framework  0x00000001020a507b 0x101c3d000 + 4620411
          3   com.adobe.Acrobat.framework  0x0000000102095a11 0x101c3d000 + 4557329
          4   com.adobe.Acrobat.framework  0x0000000102d54241 0x101c3d000 + 17920577
          5   com.adobe.Acrobat.framework  0x0000000102091412 0x101c3d000 + 4539410
          6   com.adobe.Acrobat.framework  0x000000010209fab4 0x101c3d000 + 4598452
          7   libsystem_pthread.dylib  0x00007fffa649d93b _pthread_body + 180
          8   libsystem_pthread.dylib  0x00007fffa649d887 _pthread_start + 286
          9   libsystem_pthread.dylib  0x00007fffa649d08d thread_start + 13
          Thread 8:: com.apple.NSEventThread
          0   libsystem_kernel.dylib   0x00007fffa63ab34a mach_msg_trap + 10
          1   libsystem_kernel.dylib   0x00007fffa63aa797 mach_msg + 55
          2   com.apple.CoreFoundation 0x00007fff90b05434 __CFRunLoopServiceMachPort + 212
          3   com.apple.CoreFoundation 0x00007fff90b048c1 __CFRunLoopRun + 1361
          5   com.apple.AppKit         0x00007fff8e74af02 _NSEventThread + 205
          6   libsystem_pthread.dylib  0x00007fffa649d93b _pthread_body + 180
          7   libsystem_pthread.dylib  0x00007fffa649d887 _pthread_start + 286
          8   libsystem_pthread.dylib  0x00007fffa649d08d thread_start + 13
          Thread 9:
          1   libsystem_pthread.dylib  0x00007fffa649d48e _pthread_wqthread + 1023
          Thread 10:
          0   libsystem_kernel.dylib   0x00007fffa63b4246 read + 10
          1   com.adobe.Acrobat.framework  0x0000000102093db7 0x101c3d000 + 4550071
          2   com.adobe.Acrobat.framework  0x00000001020921fe 0x101c3d000 + 4542974
          3   com.adobe.Acrobat.framework  0x000000010209c266 0x101c3d000 + 4584038
          4   com.adobe.Acrobat.framework  0x0000000102091412 0x101c3d000 + 4539410
          5   com.adobe.Acrobat.framework  0x000000010209fab4 0x101c3d000 + 4598452
          Thread 11:
          0   libsystem_kernel.dylib   0x00007fffa63b3d96 kevent + 10
          1   com.adobe.Acrobat.framework  0x00000001035c8784 0x101c3d000 + 26785668
          2   com.adobe.Acrobat.framework  0x00000001034f7c64 0x101c3d000 + 25930852
          3   libsystem_pthread.dylib  0x00007fffa649d93b _pthread_body + 180
          4   libsystem_pthread.dylib  0x00007fffa649d887 _pthread_start + 286
          5   libsystem_pthread.dylib  0x00007fffa649d08d thread_start + 13
          Thread 12:
          5   com.adobe.AcrobatPlugin.EFS  0x000000010c5d89af 0x10c5bf000 + 104879
          6   com.apple.Foundation     0x00007fff925278ad __NSThread__start__ + 1243
          Thread 13:: com.apple.NSURLConnectionLoader
          5   com.apple.CFNetwork      0x00007fff8fc41734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
          Thread 14:
          2   com.adobe.Acrobat.framework  0x00000001035bd8a8 0x101c3d000 + 26740904
          3   com.adobe.Acrobat.framework  0x00000001035bd2ec 0x101c3d000 + 26739436
          4   com.adobe.Acrobat.framework  0x00000001035bb337 0x101c3d000 + 26731319
          Thread 15:
          0   libsystem_kernel.dylib   0x00007fffa63b2eb6 __select + 10
          1   com.adobe.AcrobatPlugin.Comments    0x000000010ca30fa8 0x10c6a2000 + 3731368
          2   com.adobe.AcrobatPlugin.Comments    0x000000010ca31475 0x10c6a2000 + 3732597
          3   com.adobe.AcrobatPlugin.Comments    0x000000010ca3185b 0x10c6a2000 + 3733595
          4   com.adobe.AcrobatPlugin.Comments    0x000000010c9b22f5 0x10c6a2000 + 3212021
          5   com.adobe.AcrobatPlugin.Comments    0x000000010cbcc29d 0x10c6a2000 + 5415581
          Thread 16:
          Thread 17:
            rax: 0x0000000000000000  rbx: 0x000060000086aa00  rcx: 0x0000000000000000  rdx: 0x0000000000000005
            rdi: 0x0000000000000000  rsi: 0x00000001039d3f7d  rbp: 0x00007fff5dfc60c0  rsp: 0x00007fff5dfc60c0
             r8: 0x0000000000000000   r9: 0x00000000000001e8  r10: 0xe9ba60750c9f0048  r11: 0x00007f8a2abcfba0
            r12: 0xe9ba60750c9f0048  r13: 0x00007f8a29c91508  r14: 0x00007f8a29cef560  r15: 0x0000608000a46990
            rip: 0x00007fffa6492e00  rfl: 0x0000000000010293  cr2: 0x0000000000000000
          Logical CPU: 2
          Trap Number: 14
          Binary Images:
             0x101c38000 -    0x101c38fff +com.adobe.Acrobat.Pro (17.009.20058 - 17.009.20058) <89FD27AE-19C1-32AC-AD60-56BF734C7A87> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
             0x101c3d000 -    0x103f4dff7 +com.adobe.Acrobat.framework (17.009.20058 - 17.009.20058) <BEFA9703-203A-30C3-B28D-A235E4CF2A4C> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
             0x1042cf000 -    0x104414ff7 +com.adobe.ACE (AdobeACE 2.20.02.37824 - 2.20.02.37824) <2A4A6267-20BC-325C-931C-E227220B7650> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x104430000 -    0x104978ffb +com.adobe.AGM (AdobeAGM 4.30.69.1 - 4.30.69.1) <41AB0A45-A247-3A5E-AF7B-E838BC92E7FD> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x104a2d000 -    0x104a49ffb +com.adobe.BIB (AdobeBIB 1.2.03.37824 - 1.2.03.37824) <63152A89-179C-3DE0-94B8-2ED83DA0CC8C> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x104a55000 -    0x104d46ff7 +com.adobe.CoolType (AdobeCoolType 5.14.05.37990 - 5.14.05.37990) <67877A6B-82A9-3931-9D53-9A95ACACBF4D> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x104d94000 -    0x104ecafff +com.adobe.AIDE (1.5.0 - 1.5.0.34124) <CE69D37F-2D03-3B1D-8E63-C04CCC3FC37A> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
             0x104f3e000 -    0x104f41fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporte r
             0x10a041000 -    0x10a062fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.9.0.37990 - 3.9.0.37990) <E37A46A9-6654-3135-AE2E-61FDE4CC4D49> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8Shared Expat
             0x10a8c2000 -    0x10aa68fff  GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
             0x10aaa7000 -    0x10b002ff7  com.apple.driver.AppleIntelHD5000GraphicsGLDriver (10.25.17 - 10.2.5) <37814D97-7FB0-3378-BF1E-375CE00043ED> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD5000GraphicsGLDriver
             0x10b21a000 -    0x10b244fff  GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
             0x10b24e000 -    0x10b2c6ff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.25.17 - 10.2.5) <256C1732-C04F-3952-9630-9AE95BDCB245> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleI ntelHD5000GraphicsMTLDriver
             0x10b603000 -    0x10b94cff7 +com.adobe.AcrobatPlugin.EScript (17.009.20044 - 17.009.20044) <9729D67A-983F-3560-B074-48B28B4712C7> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Plugins/EScript.acroplugin/Contents/MacOS/EScript
             0x10bac0000 -    0x10bc0bfef +IMSLib.dylib (10.0.0.19 - 10.0.0.19) <32EDDC00-4237-3F41-8B49-8B8010FAA72B> /Applications/Utilities/Adobe Application Manager/*/IMSLib.dylib
             0x10bc2c000 -    0x10bc99fff +com.adobe.AcroSQLite (AcroSQLite - 1.0.0) <C5EDF3B4-FBED-3A2F-A83C-BFCBF0BD90C9> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite
             0x10c4b6000 -    0x10c4dafff +com.adobe.AcrobatPlugin.Updater (17.009.20044 - 17.009.20044) <DAF0EC42-E56C-3AED-A1C2-09BAA09B467A> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Plugins/Updater.acroplugin/Contents/MacOS/Updater
             0x10c51b000 -    0x10c51ffff +AcrobatUpdateHelperLib.dylib (1) <A8384547-A9BA-3F85-BCA4-4DDE1BD48369> /Library/Application Support/Adobe/*/AcrobatUpdateHelperLib.dylib
             0x10c5bf000 -    0x10c5e1fff +com.adobe.AcrobatPlugin.EFS (17.009.20044 - 17.009.20044) <D536C9E5-A5B6-38AC-8715-8226CC39A127> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Plugins/EFS.acroplugin/Contents/MacOS/EFS
             0x10c5ec000 -    0x10c665fff  com.apple.xquery (1.3.1 - 30) <031D5366-8C48-3124-93EC-3AB4A5758460> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
             0x10c6a2000 -    0x10ce07ffb +com.adobe.AcrobatPlugin.Comments (17.009.20044 - 17.009.20044) <1A20F000-9A0F-352C-9159-5F91DBA30B59> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Plugins/Comments.acroplugin/Contents/MacOS/Comments
             0x10cfe5000 -    0x10cfffff7  com.apple.security.csparser (3.0 - 57740.60.18) <119893A8-D878-3AF2-BA3C-F70D5C6E6950> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
             0x10d5fb000 -    0x10d6e2fe7 +com.adobe.amtlib (amtlib 6.2.0.42 - 6.2.0.42) <1EC10EEE-A265-89C3-E1E0-46AE6B541674> /Applications/Adobe Creative Cloud 2017/*/Adobe Acrobat.app/Contents/Frameworks/amtlib.framework/amtlib
             0x110aff000 -    0x110b3cdc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
          0x7fff8b72e000 - 0x7fff8ba73ff7  com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fff8d2aa000 - 0x7fff8d46bfff  com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
          0x7fff8d46c000 - 0x7fff8d50eff7  com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
          0x7fff8d5d9000 - 0x7fff8d5d9fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff8d5da000 - 0x7fff8d5f1ffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
          0x7fff8d5f2000 - 0x7fff8db0bfeb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff8db0c000 - 0x7fff8dc7dff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff8dc7e000 - 0x7fff8dc92ffb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
          0x7fff8dc93000 - 0x7fff8e089fef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff8e08a000 - 0x7fff8e0a0fff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
          0x7fff8e0a1000 - 0x7fff8e0a7fff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
          0x7fff8e0a8000 - 0x7fff8e0bcff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
          0x7fff8e0bd000 - 0x7fff8e244fe7  libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff8e245000 - 0x7fff8e2f7fff  libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff8e2f8000 - 0x7fff8e2f8fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff8e5b7000 - 0x7fff8f390ff3  com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff8f3a2000 - 0x7fff8f3a2fff  com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff8f3a3000 - 0x7fff8f411ff7  com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff8f4ab000 - 0x7fff8f5daff7  libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fff8f5db000 - 0x7fff8f625fff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fff8f682000 - 0x7fff8f6b5fff  libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x7fff8f722000 - 0x7fff8f7ccff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff8f7cd000 - 0x7fff8f81efff  com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff8f81f000 - 0x7fff8f82eff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fff8f82f000 - 0x7fff8f87cfff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff8f87d000 - 0x7fff8f8b8fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff8f8b9000 - 0x7fff8f8c4fff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff8f8c5000 - 0x7fff8fad1ff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff8fad2000 - 0x7fff8fad2fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff8fc3b000 - 0x7fff90015fff  com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
          0x7fff9002f000 - 0x7fff9002ffff  com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff90030000 - 0x7fff90033fff  com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff90034000 - 0x7fff9033dfff  com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff9033e000 - 0x7fff90341ff7  com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff90342000 - 0x7fff90347fff  com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff90348000 - 0x7fff903dfff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff903e0000 - 0x7fff903fafff  com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff903fb000 - 0x7fff903fcff3  com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff903fd000 - 0x7fff903ffff7  com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff90400000 - 0x7fff90406ff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff90407000 - 0x7fff904e6ffb  com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
          0x7fff904e7000 - 0x7fff904e7fff  com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff90631000 - 0x7fff906befff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff906bf000 - 0x7fff906d2fff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
          0x7fff906d3000 - 0x7fff909cefff  com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff909cf000 - 0x7fff90a7cff7  com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
          0x7fff90a7d000 - 0x7fff90f16ff7  com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff90f17000 - 0x7fff91599fff  com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
          0x7fff9159a000 - 0x7fff917ddffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
          0x7fff917de000 - 0x7fff91843ff7  com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
          0x7fff91844000 - 0x7fff918f5fff  com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fff918f6000 - 0x7fff91941ff7  com.apple.CoreMediaIO (805.0 - 4932) <03F2B863-BF99-36DF-9A14-1DB534A289F3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
          0x7fff91942000 - 0x7fff91942fff  com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff91943000 - 0x7fff91994fff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff91995000 - 0x7fff91c70ff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff91c71000 - 0x7fff91ca4fff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff91ca5000 - 0x7fff91cadff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
          0x7fff91cae000 - 0x7fff91e1aff7  com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff91e1b000 - 0x7fff91ecbffb  com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff91ecc000 - 0x7fff91f2bfff  com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff91f2c000 - 0x7fff91f9cfff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff91f9d000 - 0x7fff91fe2ff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
          0x7fff9206b000 - 0x7fff921b8ffb  com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
          0x7fff921b9000 - 0x7fff921eeff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff921ef000 - 0x7fff92260ffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
          0x7fff9235e000 - 0x7fff92363fff  com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff924f5000 - 0x7fff9289bfff  com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff928c7000 - 0x7fff928f8ff7  com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
          0x7fff929b8000 - 0x7fff92a5bfff  com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
          0x7fff92a5c000 - 0x7fff92af2ff7  com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff92af3000 - 0x7fff92af9ffb  com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fff92afa000 - 0x7fff92b4bff7  com.apple.ImageCaptureCore (7.0 - 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fff92b4c000 - 0x7fff92cacfef  com.apple.ImageIO.framework (3.3.0 - 1599.12) <E54ADBF0-6001-3DEB-AEB0-3F857A781E06> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
          0x7fff92cad000 - 0x7fff92cb1fff  libGIF.dylib (1599.12) <A0836C44-9566-32A3-ACCF-82A5BAF2E521> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
          0x7fff92cb2000 - 0x7fff92da2ff7  libJP2.dylib (1599.12) <0DB4F152-B36D-365C-97B1-34F1C114982B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
          0x7fff92da3000 - 0x7fff92dc6ffb  libJPEG.dylib (1599.12) <2F66BA16-D569-35AD-A4BB-7A1909F1BF11> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
          0x7fff92dc7000 - 0x7fff92deeff7  libPng.dylib (1599.12) <A068239E-7DB3-33AD-BEA9-499D8DEF771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
          0x7fff92def000 - 0x7fff92df1ff3  libRadiance.dylib (1599.12) <D26D6FC9-1175-38AB-ACAA-0CA073FD3978> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
          0x7fff92df2000 - 0x7fff92e40ffb  libTIFF.dylib (1599.12) <5D161E6A-D279-37A0-9F5F-A71A4C13BB09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
          0x7fff92f9e000 - 0x7fff93ba8fff  com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fff93ba9000 - 0x7fff93bc2ff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff93e4c000 - 0x7fff93e52fff  com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
          0x7fff93e68000 - 0x7fff943a1ff7  com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fff943a2000 - 0x7fff943fdfff  com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
          0x7fff94ce6000 - 0x7fff94ceefff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fff94ec5000 - 0x7fff94ecdff7  libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
          0x7fff94ece000 - 0x7fff94f1cff3  com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fff94f1d000 - 0x7fff94f36ffb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fff94f37000 - 0x7fff94f42ff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fff94f43000 - 0x7fff94f45fff  libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
          0x7fff94f46000 - 0x7fff94f49ff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
          0x7fff94f4a000 - 0x7fff94f4efff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fff94f4f000 - 0x7fff94f58ff7  libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fff94f59000 - 0x7fff94f64fff  libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff94f65000 - 0x7fff94fa1ff7  libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff94fa2000 - 0x7fff95118ff3  libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff95119000 - 0x7fff9515aff7  libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff95ac2000 - 0x7fff95ad0fff  com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff95b6d000 - 0x7fff95cb4fff  com.apple.QTKit (7.7.3 - 2978.7) <49F88771-52FE-3989-AAB7-10A7494C4419> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff95cb5000 - 0x7fff95f1fff7  com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fff95f20000 - 0x7fff95fe7fff  com.apple.PDFKit (1.0 - 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fff95fe8000 - 0x7fff9650eff7  com.apple.QuartzComposer (5.1 - 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fff9650f000 - 0x7fff96532ffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fff96533000 - 0x7fff96620fff  com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fff96621000 - 0x7fff96621fff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fff96622000 - 0x7fff96822fff  com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff96823000 - 0x7fff96878fff  com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fff96879000 - 0x7fff9688efff  com.apple.SafariServices.framework (12603 - 12603.3.8) <966BF0C8-B94B-3BDF-AFE1-0F99DAAE6D99> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
          0x7fff96d71000 - 0x7fff96d88ff7  com.apple.ScriptingBridge (1.3.3 - 69) <F51B85CD-9C80-317E-B594-4A03612EAF52> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
          0x7fff96d89000 - 0x7fff9708bff7  com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff9708c000 - 0x7fff97101fff  com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fff9712c000 - 0x7fff9712fff3  com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
          0x7fff974b6000 - 0x7fff97525ff7  com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff97526000 - 0x7fff978d4fff  com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fff978d5000 - 0x7fff98c5cff3  com.apple.WebCore (12603 - 12603.3.8) <FE0B8503-5E89-3D55-BF48-1370FE81910A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
          0x7fff98c5d000 - 0x7fff98e49ff3  com.apple.WebKitLegacy (12603 - 12603.3.8) <8C2FFEAA-1E05-3756-8EA7-DF406C866191> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
          0x7fff98e4a000 - 0x7fff991f5fff  com.apple.WebKit (12603 - 12603.3.8) <C28C5735-5B6B-3434-8054-FDBC57B4E2DE> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
          0x7fff99d7c000 - 0x7fff99d97ff3  com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
          0x7fff99d98000 - 0x7fff99da5ff3  com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
          0x7fff99da6000 - 0x7fff99dc8ffb  com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
          0x7fff99dc9000 - 0x7fff99dd8feb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
          0x7fff99ec6000 - 0x7fff99f5197f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
          0x7fff99f8a000 - 0x7fff99f8dff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
          0x7fff99f8e000 - 0x7fff99fe0fff  com.apple.AppleVAFramework (5.0.36 - 5.0.36) <7352078D-C230-397C-81A5-57A48CF218C0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fff99fea000 - 0x7fff99ff1ff7  com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
          0x7fff9a384000 - 0x7fff9a402ff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
          0x7fff9b08d000 - 0x7fff9b0b4ff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
          0x7fff9b0b5000 - 0x7fff9b141ff7  com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
          0x7fff9b9d9000 - 0x7fff9b9e2ffb  com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
          0x7fff9bb67000 - 0x7fff9bf46ff7  com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x7fff9bf47000 - 0x7fff9bf77fff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
          0x7fff9c12b000 - 0x7fff9c13bfff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
          0x7fff9c200000 - 0x7fff9c216ff3  com.apple.CoreMediaAuthoring (2.2 - 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
          0x7fff9c21d000 - 0x7fff9c2adffb  com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fff9c476000 - 0x7fff9c4a6ff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
          0x7fff9c737000 - 0x7fff9c7c6ff7  com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
          0x7fff9c7c7000 - 0x7fff9c906fe7  com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff9c907000 - 0x7fff9c9d7ff3  com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
          0x7fff9ca27000 - 0x7fff9ca8cff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
          0x7fff9ca8d000 - 0x7fff9ca9bff7  com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
          0x7fff9cb0d000 - 0x7fff9cb17ffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
          0x7fff9cb18000 - 0x7fff9cb1cff3  com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDispla y
          0x7fff9cb52000 - 0x7fff9cbc7ffb  com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fff9cc03000 - 0x7fff9cc42fff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
          0x7fff9cc43000 - 0x7fff9cd54fff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff9ce97000 - 0x7fff9cea2fff  com.apple.DisplayServicesFW (3.1 - 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fff9d03c000 - 0x7fff9d46dff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
          0x7fff9e7c4000 - 0x7fff9e7c4fff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
          0x7fff9e7d1000 - 0x7fff9e7dcff3  libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
          0x7fff9ea95000 - 0x7fff9eab1fff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
          0x7fff9eaca000 - 0x7fff9f17cfff  com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
          0x7fff9f1c2000 - 0x7fff9f238ff3  com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
          0x7fff9f239000 - 0x7fff9f24afff  com.apple.HelpData (2.1.12 - 100.1) <EEB8CC44-9AFF-3005-A25D-18FE46574FD5> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
          0x7fff9f853000 - 0x7fff9f85affb  com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
          0x7fff9f85c000 - 0x7fff9f870ff7  com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
          0x7fff9f871000 - 0x7fff9f893fff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
          0x7fff9f92f000 - 0x7fff9f93fff3  com.apple.IntlPreferences (2.0 - 216) <77C9C2E7-EF9F-34BB-A5E3-B8BEA4226B5F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
          0x7fff9f97a000 - 0x7fff9fb31fff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
          0x7fff9fc2d000 - 0x7fff9fcefff3  com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
          0x7fffa01a1000 - 0x7fffa01a4fff  com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
          0x7fffa0452000 - 0x7fffa04cbff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerfo rmanceShaders
          0x7fffa0627000 - 0x7fffa0635fff  com.apple.MobileKeyBag (2.0 - 1.0) <D0983DB7-EF9D-3E19-A084-21319ECE5846> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
          0x7fffa0646000 - 0x7fffa066eff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fffa0720000 - 0x7fffa072bfff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
          0x7fffa1003000 - 0x7fffa1044ff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
          0x7fffa16f1000 - 0x7fffa172bffb  com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
          0x7fffa172c000 - 0x7fffa1746fff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
          0x7fffa1747000 - 0x7fffa1756ff7  com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
          0x7fffa175f000 - 0x7fffa1782ff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
          0x7fffa244c000 - 0x7fffa244ffff  com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
          0x7fffa24de000 - 0x7fffa256bfff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
          0x7fffa256c000 - 0x7fffa258bff7  com.apple.shortcut (2.16 - 98) <6C0435B1-83DD-3254-B0D3-3B86C6CE606A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
          0x7fffa258c000 - 0x7fffa27f2feb  com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
          0x7fffa29d1000 - 0x7fffa29ddff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
          0x7fffa30c9000 - 0x7fffa313dfdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
          0x7fffa357c000 - 0x7fffa3582ff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
          0x7fffa360e000 - 0x7fffa36d4ff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
          0x7fffa3748000 - 0x7fffa3749fff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fffa374a000 - 0x7fffa38daff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
          0x7fffa43a9000 - 0x7fffa4469fff  com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
          0x7fffa48b4000 - 0x7fffa48bafff  com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
          0x7fffa498b000 - 0x7fffa498dffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
          0x7fffa49e2000 - 0x7fffa49fdff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
          0x7fffa49fe000 - 0x7fffa4a09fff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
          0x7fffa4a9b000 - 0x7fffa4a9cff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
          0x7fffa4a9d000 - 0x7fffa4cb0fff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
          0x7fffa4ccc000 - 0x7fffa4cd3fff  libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
          0x7fffa4cd4000 - 0x7fffa4cd4fff  libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
          0x7fffa4cd5000 - 0x7fffa4cd9ffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
          0x7fffa4cda000 - 0x7fffa4cdbffb  libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
          0x7fffa4d47000 - 0x7fffa4d72ff3  libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
          0x7fffa4d73000 - 0x7fffa4deffc7  libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
          0x7fffa4df3000 - 0x7fffa4df3ff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
          0x7fffa4df4000 - 0x7fffa4e04ff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
          0x7fffa4e05000 - 0x7fffa4e13ff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
          0x7fffa4e14000 - 0x7fffa4e6aff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
          0x7fffa4e6b000 - 0x7fffa4e94ff7  libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
          0x7fffa4e95000 - 0x7fffa4ea5ffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
          0x7fffa4ea6000 - 0x7fffa4ebcfcf  libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
          0x7fffa4ebd000 - 0x7fffa4ebdff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
          0x7fffa4ebe000 - 0x7fffa4ebfff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
          0x7fffa4f79000 - 0x7fffa505eff7  libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
          0x7fffa51fc000 - 0x7fffa524fff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
          0x7fffa52a3000 - 0x7fffa52aaff3  libdscsym.dylib (148.3) <EF99B991-18D9-3A73-BE88-4DC55F036DEF> /usr/lib/libdscsym.dylib
          0x7fffa52cc000 - 0x7fffa52ccfff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
          0x7fffa52da000 - 0x7fffa52dbfff  libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
          0x7fffa52dc000 - 0x7fffa52e1ff7  libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
          0x7fffa52e2000 - 0x7fffa53d4ff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
          0x7fffa53d5000 - 0x7fffa55faffb  libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
          0x7fffa5600000 - 0x7fffa5601fff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
          0x7fffa5602000 - 0x7fffa561bffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
          0x7fffa561c000 - 0x7fffa5632ff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
          0x7fffa5633000 - 0x7fffa58dbff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
          0x7fffa590e000 - 0x7fffa5988ff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
          0x7fffa5989000 - 0x7fffa5d5b047  libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
          0x7fffa5d5e000 - 0x7fffa5d62fff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
          0x7fffa5d63000 - 0x7fffa5d94fff  libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
          0x7fffa5db1000 - 0x7fffa5dcdffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
          0x7fffa5dce000 - 0x7fffa5e07fff  libsandbox.1.dylib (592.70.1) <9C428C49-9D9A-3F9F-9573-BF5202D1F933> /usr/lib/libsandbox.1.dylib
          0x7fffa5e1b000 - 0x7fffa5e1cff3  libspindump.dylib (231.3) <C7CEEB64-06F4-3ACA-AAC1-30ECA909501A> /usr/lib/libspindump.dylib
          0x7fffa5e1d000 - 0x7fffa5f6bff7  libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
          0x7fffa5fc7000 - 0x7fffa6017fff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
          0x7fffa6060000 - 0x7fffa606dfff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
          0x7fffa606e000 - 0x7fffa615dfff  libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
          0x7fffa615e000 - 0x7fffa6187fff  libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
          0x7fffa6188000 - 0x7fffa6199ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
          0x7fffa61a8000 - 0x7fffa61acff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
          0x7fffa61ad000 - 0x7fffa61b7fff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
          0x7fffa61b8000 - 0x7fffa61bffff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
          0x7fffa61c0000 - 0x7fffa61c8fff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
          0x7fffa61c9000 - 0x7fffa624cfdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
          0x7fffa624d000 - 0x7fffa627efff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
          0x7fffa627f000 - 0x7fffa6284ffb  libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
          0x7fffa6285000 - 0x7fffa6285ffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
          0x7fffa6286000 - 0x7fffa6292fff  libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
          0x7fffa6293000 - 0x7fffa6293fff  liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
          0x7fffa6294000 - 0x7fffa6299ff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
          0x7fffa629a000 - 0x7fffa629cff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
          0x7fffa629d000 - 0x7fffa629effb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
          0x7fffa629f000 - 0x7fffa62b7ff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
          0x7fffa62b8000 - 0x7fffa62b8ff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
          0x7fffa62b9000 - 0x7fffa6346fef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
          0x7fffa6347000 - 0x7fffa634affb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
          0x7fffa634b000 - 0x7fffa634efff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
          0x7fffa634f000 - 0x7fffa6367fff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
          0x7fffa6368000 - 0x7fffa636efff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
          0x7fffa636f000 - 0x7fffa6398ff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
          0x7fffa6399000 - 0x7fffa63bbff7  libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
          0x7fffa63bc000 - 0x7fffa6403fe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
          0x7fffa6404000 - 0x7fffa6422ff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
          0x7fffa6423000 - 0x7fffa647cffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
          0x7fffa647d000 - 0x7fffa6486ff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
          0x7fffa6487000 - 0x7fffa6490ff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
          0x7fffa6491000 - 0x7fffa6499fe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
          0x7fffa649a000 - 0x7fffa64a4ff7  libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
          0x7fffa64a5000 - 0x7fffa64a8ff7  libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
          0x7fffa64a9000 - 0x7fffa64aaff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
          0x7fffa64ab000 - 0x7fffa64b2ffb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
          0x7fffa64b3000 - 0x7fffa64c6ff7  libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
          0x7fffa64c7000 - 0x7fffa64ccffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
          0x7fffa64cd000 - 0x7fffa64f6ff7  libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
          External Modification Summary:
            Calls made by other processes targeting this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
            Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
            Calls made by all processes on this machine:
          task_for_pid: 3548
          thread_create: 0
          thread_set_state: 0
          VM Region Summary:
          ReadOnly portion of Libraries: Total=392.8M resident=0K(0%) swapped_out_or_unallocated=392.8M(100%)
          Writable regions: Total=165.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=165.7M(100%)
                                      VIRTUAL   REGION
          REGION TYPE                    SIZECOUNT (non-coalesced)
          Accelerate framework           384K    4
          Activity Tracing               256K    2
          CG backing stores             5616K    5
          CG image                       644K   24
          CoreAnimation                   56K    9
          CoreUI image data             1260K   15
          CoreUI image file              184K    5
          Foundation                       4K    2
          Image IO                        76K    4
          Kernel Alloc Once                8K    2
          MALLOC                       120.9M   81
          MALLOC guard page               48K   10
          Memory Tag 242                  12K    2
          Memory Tag 251                  16K    2
          SQLite page cache               64K    2
          STACK GUARD                   56.1M   19
          Stack                         17.6M   20
          VM_ALLOCATE                   2540K   29
          __DATA                        36.1M  294
          __GLSLBUILTINS                2588K    2
          __IMAGE                        528K    2
          __LINKEDIT                   117.9M   26
          __TEXT                       274.9M  286
          __UNICODE                      556K    2
          mapped file                   58.3M   23
          shared memory                 18.4M   18
          TOTAL                        714.6M  864
          Model: Macmini7,1, BootROM MM71.0220.B29, 2 processors, Intel Core i5, 2.6 GHz, 8 GB, SMC 2.24f32
          Graphics: Intel Iris, Intel Iris, Built-In
          Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5444
          Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E424C54414C41522D4E5444
          AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x13B), Broadcom BCM43xx 1.0 (7.21.171.130.1a1)
          Bluetooth: Version 5.0.5f1, 3 services, 27 devices, 1 incoming serial ports
          Network Service: Wi-Fi, AirPort, en1
          Serial ATA Device: APPLE HDD HTS541010A9E662, 1 TB
          USB Device: USB 3.0 Bus
          USB Device: IR Receiver
          USB Device: BRCM20702 Hub
          USB Device: Bluetooth USB Host Controller
          USB Device: CanoScan
          USB Device: Keyboard Hub
          USB Device: CDRW55292EXT3-B
          USB Device: Apple Keyboard
          Thunderbolt Bus: Mac mini, Apple Inc., 26.1
          • 2. Re: Adobe Acrobat DC 2017 Crashes 30 seconds after opening - mac OS Sierra
            Rave Adobe Employee
            Hi Mark,
            If Acrobat is crashing on launch without even opening any file then it seems to be a licensing issue to me. Acrobat tries to validate its license and may be crashing due to failure. You can provide the amt3.log file for further analysis.
            Location of log files:
            amt3.log and oobelib.log: /Users/<current user>/Library/Logs
            PDapp.log: /Users/<current user>/Library/Logs
            Meanwhile, try the steps below:
            Delete all the files from following folders:
            Library/Application Support/Adobe/SLStore
            Library/Application Support/Adobe/SLCache
            And, delete all files from following folder except cache.db
            Library/Application Support/Adobe/Adobe PCD
            Launch Acrobat, activate when prompted and check.
            Regards,
            Rave
            • 3. Re: Adobe Acrobat DC 2017 Crashes 30 seconds after opening - mac OS Sierra
              marktru Level 1
              Hello Rave,
              I just tried deleting those files you said to delete. I then tested, it did not crash at 30 seconds, was still open well after a minute. I closed it. I then restarted my computer, and tested again. Again, it stayed open well past a minute. I then closed, and opened Acrobat once more -- and it stayed open, no crashing, for 10 minutes or more, and then I closed it.
              That appears to have solved the issue -- maybe. I will be testing and watching for the next couple days before I decide that fix is final.
              Thank you for that. What are those files? I presume they simply got corrupted? I did earlier try an uninstall with the uninstaller and reinstalled. Should I have cleared those files manually too?
              How could it be that simple to fix, when the other thread has been out there for years with no fix -- in fact, I don't think I saw anywhere in it to try this.
              • 4. Re: Adobe Acrobat DC 2017 Crashes 30 seconds after opening - mac OS Sierra
                Rave Adobe Employee
                Hi Mark,
                When Acrobat launches it also validates the license information periodically that is saved in the files you deleted. In case of corrupt files or any event that causes the licensing to break, the program shuts down due to license failure.
                Improper permissions to the aforementioned folders also lead to licensing failure as Acrobat will not be able to access the folders to write or read the information.
                I assumed that might be the situation here and suggested the steps. Deleting these files are recommended only as a last resort because it could lead to licensing failure of other installed Adobe applications on your machine.You will then have to launch and relicense the respective applications.
                I am glad that the steps worked for you.
                Regards,
                Rave
                • 5. Re: Adobe Acrobat DC 2017 Crashes 30 seconds after opening - mac OS Sierra
                  marktru Level 1
                  Well, this fix has failed, it has not passed the test of time. Two days later, and Acrobat has started crashing again about 30 seconds after opening. In fact, the way I found out was that I a crash report popped up this morning even though I hadn't opened Acrobat -- how could that happen? And ever since that, all I get is the crashing.
                  I tried eliminating those files again -- but there were none in those folders now.
                  What process goes on about 30 second after opening, every time? That is where the problem is.
                  Should I delete certain preference files? I just went in and deleted some named for Acrobat from Users/(me)/Preferences. But then int testing, it still crashed.
                  This is like I saw some people saying in another thread here, that they had tried a solution that was offered, it worked, but then it stopped working a couple-few days later. Doesn't that crash report I posted tell you something -- if not, what is the point of crash reports?
                  • 6. Re: Adobe Acrobat DC 2017 Crashes 30 seconds after opening - mac OS Sierra
                    Rave Adobe Employee
                    Hi Mark,
                    Sorry for the delay in response.
                    As mentioned in my response# 2, could you please provide me the log files.
                    You can email me directly at trkumar@adobe.com
                    Also provide me the following information:
                    1. Exact version of Acrobat.
                    2. The Adobe ID used to activate the license.
                    3. Check if you have Read/ Write permissions to SLSTORE, SLCACHE and Adobe PCD folders.
                    4. Check the steps mentioned in the KB: Resolve connection errors with Adobe Creative Cloud and Creative Suite applications
                    5. When was the last time that Acrobat worked fine. Did any update or software install break the workflow?
                    6. Check in Safe mode or a different admin user account if Acrobat launches fine.
                    Regards,
                    Rave
                    • 7. Re: Adobe Acrobat DC 2017 Crashes 30 seconds after opening - mac OS Sierra
                      carogar7 Level 1
                      I have the exact same problem that Mark has or had, I have Mac Sierra and Adobe DC Pro was working fine until a couple of weeks ago, in all my computers (all Mac, same OS), I have lost count of how many reports I have sent already.
                      Reading Mark's and your posts Rave, what I can tell you is that my Adobe crashes only when I open a file, and only if the file comes from the adobe creative cloud, if I open a file from my hard drive there is no problem. I checked this carefully after reading your posts. The crash report says the same as Mark's report, the only difference is the version of acrobat,
                      I am not as savvy with computers as Mark, so, would you explain to me how to fix this as if you were talking to your mom or dad, if they know something about computers, I mean, I know something.
