I always want to open the first page when I open a pdf file from a reader
Please tell me how
Hi 오승훈오,
This is a designed behavior of mobile application. You can not change the preferences setting in mobile app as you can on desktop application. By default it will open the pdf file from its last viewed page.
Regards,
Akanchha
Generally, that is how they open. Can you give us some more info on what is actually happening when you open a pdf? Is it one in particular or is it all of them? What version of Reader?
For example-
reading a file at page30 and closed it.
When I open the file next it opens up from the last view (page30) again
at Mobile (Android)
Hi 오승훈오,
Regards,
Akanchha
Hi 오승훈오,
As requested by~graffiti, to understand the issue in better manner it would be helpful if you describe it a little bit more?
I assume, is that you are referring to the file opens up from the same page where you closed last time?
For example- If you were reading a file at page30 and closed it. When you open the file next it opens up from the last view (page30) again.
If this is the case, then you can change this setting from- Edit>Preference>Document> Uncheck "Restore last view settings when reopening document "
Regards,
Akanchha
Yes, that's right
but
I wonder how it works on mobile (Android)
please help
