• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Loading plugins under Windows 10
Participant ,
Sep 07, 2017 Sep 07, 2017
Hello everyone,
I developed some plugins, which work well on Windows 8.1 and Windows 7 for Illustrator CC 2017 and CC 2015.3.
Recently I tried to run the plugins on a Windows 10 machine (CC 2017 and CC 2015.3). When I start Illustrator a message "Error loading plugins" appears. The same message appears even for tutorial plugins of the SDK. I tried the same on a second Windows 10 machine with the same result.
Do you have any suggestions?
Is there some logging file, where Illustrator logs more detailed information during the launch process?
Many thanks and best regards
Denis
TOPICS
SDK
Views
983
Translate
Translate
Report
Report
Community guidelines
community guidelines
Participant , Sep 11, 2017 Sep 11, 2017
Thank you for the answer. Indeed, the problem was caused by missing dll files. I forgot, that my plugin used an additional custom dll file. I provided the file and additionally built the plugin using the static linking. After that the plugin could be loaded successfully. But only in the release mode. It was still not possible to debug the plugin on the Windows 10 machine. Installing the Windows 10 SDK solved that problem.
Votes
Translate
Translate
Adobe
Advocate ,
Probably because the Windows 10 machines don't have the required Microsoft visual studio runtime dlls installed. The best solution is to build with the static versions of the libraries (Configuration Properties | C/C++ | Code Generation | Runtime Library)
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Votes
Translate
Translate
Report
Report
