1 Reply Latest reply on Sep 13, 2017 7:24 AM by Mukolajko
    pstrSecurityToken missing from LogOn response using node js
    Mukolajko Level 1
      Hi.
      I try to integrate to adobe campaign API.
      I use example from Web service calls  to try receive session and security token.
      Here is my sample code from node.js
      var body = '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:xtk:session">' +
         '<soapenv:Header/><soapenv:Body><urn:Logon>' +
         '<urn:sessiontoken/> ' +
         '<urn:strLogin>username</urn:strLogin> ' +
         '<urn:strPassword>pass</urn:strPassword> ' +
         '<urn:elemParameters/>' +
      '</urn:Logon></soapenv:Body></soapenv:Envelope>';
      request({
         headers : {
         "Content-Type" : "text/xml; charset=utf-8",
         "SOAPAction" : "xtk:session#Logon"
         uri: this.loginUrl,
         body: body,
         method: 'POST'
      }, (err, response, body) => {
         console.log(err);
         console.log(body);
      And here is body response
      <?xml version='1.0'?><SOAP-ENV:Envelope xmlns:xsd='http://www.w3.org/2001/XMLSchema' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xmlns:ns='urn:xtk:session' xmlns:SOAP-ENV='http://schemas.xmlsoap.org/soap/envelope/'><SOAP-ENV:Body><LogonResponse xmlns='urn:xtk:session' SOAP-ENV:encodingStyle='http://schemas.xmlsoap.org/soap/encoding/'><pstrSessionToken xsi:type='xsd:string'>SessionTokenHere</pstrSessionToken><pSessionInfo xsi:type='ns:Element' SOAP-ENV:encodingStyle='http://xml.apache.org/xml-soap/literalxml'><sessionInfo></sessionInfo></pSessionInfo></LogonResponse></SOAP-ENV:Body></SOAP-ENV:Env elope>
      As you can see pstrSecurityToken tag is missing from response. So my question is, am i doing something wrong, or security and management settings dont allow security token to be sent via LogOn call.
      Thank you.
        • 1. Re: pstrSecurityToken missing from LogOn response using node js
          Mukolajko Level 1
          So apparently i were doing something wrong.
          So to help other people with this. You don't actually need Security token to run query(on some cases).
          All what you need to do is to add in request body <urn:sessionToken> tag with valid token, and do not specify in HTTP headers X-Security-Token and cookie.
          Code looks like this in node JS.
          var body = '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:xtk:queryDef">' +
             '<soapenv:Header/><soapenv:Body><urn:ExecuteQuery><urn:sessiontoken>'+this.token+'</urn:sessiontoken><urn:entity>' +
             '<queryDef operation="select" schema="nms:recipient">' +
             '<select><node expr="@email"/><node expr="@lastName"/><node expr="@firstName"/></select>' +
             '<where><condition expr="@email = \'email@gmail.com\'"/></where>' +
             '</queryDef>' +
             '</urn:entity></urn:ExecuteQuery></soapenv:Body></soapenv:Envelope>';
          request({
             headers : {
             "SOAPAction" : "xtk:queryDef#ExecuteQuery"
             uri: "https://neweratickets-s.neolane.net/nl/jsp/soaprouter.jsp",
             body: body,
             method: 'POST'
             console.log(err);
             console.log(body);
               //All OK here.
          Hope this helps.
