9 Replies Latest reply on Sep 13, 2017 3:39 AM by ccastleb
    Lens Profile - Canon EF 300mm f/2.8L IS II + TC 1.4x III or TC 2x III not detected
    marcoc46985288
      Hi.
      I am using the latest ACR 9.12 but this happens for very long time... I used 7D Mark II, 6D and 5D Mark IV to verify this.
      When I use only the EF 300mm and I check the Enable Lens Corrections box, automatically ACR detects the lens and puts Make, Model and Profile fields accordingly.
      But when I use Canon EF 300mm f/2.8L IS II in combination with TC 1.4x III or TC 2x III, ACR does not detect them. I need to change manually the Make to Canon, but the behaviour is different for each set when I change the maker:
      EF300 + TC 1.4x
      Setup: Custom
      Model: Canon EF 300mm f/2.8L IS II USM + 1.4x
      Profile: Adobe (Canon EF 300mm f/2.8L IS II USM + 1.4x)
      It is OK.
      EF300 + TC 2x
      Setup: Custom
      Model: Canon EF 600 f/4 L IS USM
      Profile: Adobe (Canon EF 600 f/4 L IS USM)
      It is wrong. And I need to change manually Model to Canon EF 300mm f/2.8L IS II USM + 2x
      Thank you.
