0 Replies Latest reply on Aug 12, 2008 9:48 AM by justria
    Which components have heavy impact on frame rates?
    justria Level 1
      As part of my small animation experiment located here
      http://www.flexolero.com/demos/AIRAnim.zip
      I made some curious observation.
      On my iMac, the demo renders with up to 200 animated objects with roughly 20 fps. If I increase the number even higher the frame rate decreases - as expected. The demo animates each object and does certain collision detection.
      The one aspect I'm curious about, is this: Even if I animate only 1 object, the frame rate keeps around 20.
      Does anybody has an idea, what might cause this effect? Are certain components absolutely no-goes? E.g. all real Flex components, while 'native' Flash components or OK?
      Why isn't the app reaching higher framerates if the app does more or less nothing?
      I tested the sample app as an AIR build. Next I'll check a browser build.
      [Needless to note, that I requested a high frame rate using " stage.frameRate = 99; ".]
