The problem happens only on Mac OS.
When I execute the CmdUtils::ProcessCommand with IImportResourceCmdData then the error code 29446 is returned and the error message "Either the file does not exist, you do not have permission, or the file may be in use" pops up.
The file is there and have enough permissions. When I insert the image manually then it works.
What is causing the problem and how could i resolve it?
Thanks in advance
This message pops up when you pass invalid IDFile.
On Mac, you can create IDFile either with PMString or WideString
When creating IDFile with PMString pass HFS Path
When creating IDFile with WideString pass posix Path.
Regards,
Rahul Rastogi
www.izinesolutions.com
