I'm trying to test the first sample from here ColdFusion Help | Using the cfprogressbar tag
where cfprogressbar ... bind="cfc:pbar.getProgessData()" and the backyard code in pb.cfc
There are plenty more similar samples out there to run cfprogressbar with cfc callback bind since CF9 or so but I get all the same results.
I'm running it on ColdFusion 2016 Update 4 and it only runs once from 0% to 10%. Only one step. Tested with both IE and Chrome with F12 debugger.
In the browser debugger I see pbar.cfc?method=getProgessData& ... calls every one second as it should but the response is always the same like {"MESSAGE":"10%","STATUS":0.1}
How can fix it, any ideas, please?
UPDATE: It works only via http://localhost or https://localhost
Stuck via http://127.0.0.1 or https://127.0.0.1 or direct public available IP address or any domain name to that computer
now runs OK
I need to check
in Server Settings > Memory Variables
and restart ColdFusion server
Hi SideX, thanks for sharing that.
