2 Replies Latest reply on Sep 12, 2017 9:52 AM by Colin Holgate
    Invalid Bundle when uploading iOS apps
    damianj67061058
      Hi.
      I just started getting this error when trying to upload my app via Application Loader.
      Dear developer,
      We have discovered one or more issues with your recent delivery for "HC And - På hospitalet". To process your delivery, the following issues must be corrected:
      Invalid Bundle - A nested bundle doesn't have the right platforms listed in CFBundleSupportedPlatforms Info.plist key.
      Regards,
      The App Store team
      It seems the issue only occures when I use special letters in the App name. The problem is, I strictly need the name of the app to be correct, using the special sign. More precisely: å
      Does anyone have any solutions?
      Regards,
      Damian
        • 1. Re: Invalid Bundle when uploading iOS apps
          if you're publishing for both iphone and ipad, you need to add devices 1 and 2 to your iphone tag (in your manifest):
            <InfoAdditions><![CDATA[
            <key>UIDeviceFamily</key>
            <array>
              <string>1</string>
              <string>2</string>
            </array>
          ]]></InfoAdditions>
          • 2. Re: Invalid Bundle when uploading iOS apps
            Colin Holgate MVP & Adobe Community Professional
            As this is the Adobe Animate forum you're hopefully using Adobe Animate, and you can set which devices are to be used in the General tab of the iOS Settings.
            Given that any setting should be valid, something else may be going wrong. You could drag the -app.xml file onto a browser, and if there is anything wrong there would be an error that suggests what part is wrong.
