1 Reply Latest reply on Sep 13, 2017 6:23 AM by BKBK
    Optional Parameters..
    AdvanceSoftware_Nireland Level 1
      Hi, I have a simple function that searches for a user (see below).
      using cfscript. cf2016
      QryGetUser =
      Queryexecute("
      SELECT tblUsers.ID,
      1. tblUsers.OrganisaztionID,
      2. tblUsers.Username,
      3. tblUsers.Password,
      4. tblUsers.AccessLevel
      FROM
      tblUsers
      where
      1. tblUsers.Username=?
      [username],{datasource="myds"});
      I want to have the “username” parameter in the WHERE optional.
      So traditionally I have:
      Wrapped the where clause in IF statements to check if a Parameter is
      defined.
      1. e.g.
      Where 1=1
      AND
      If(isdefined(“parameter2”)
      AND field2=parameter2
      So this works just fine but gets a little cumbersome and hard to read,
      however with optional parameters I figure I am going to have to build my SQL
      statement dynamically in any case. I have several parts to this question:
      1 – Is there a cleaner solution apart from building the SQL string
      2 – Would it be bad practice to pass the whole built SQL string as a
      parameter to this function, the entire select statement being built outside of
      the function
      3- Depending on the above answers would it then be an option to simply
      create a function to run any SQL command..
