Expand my Community achievements bar.
SOLVED
Log levels
Avatar
Level 2
Hey guys,
I'm new on AEM
So, I have a question. Which is the default log level for any instance? I'm not sure but I think that's INFO log, Am I right?
Thanks for sharing!
1 Accepted Solution
Avatar
Correct answer by
Level 7
Yeah, thats correct. Global configuration has the log level set in "INFO"
Then there are individual loggers at package level, which are configured with different logging levels. Once such example is:
You can check these configurations in Felix console(/system/console/configMgr) under the config names as there in the  screenshots above.
Hope this helps..
View solution in original post
Avatar
Correct answer by
Level 7
Hope this helps..
Avatar
Level 10
Yes you are right. The default log level is "INFO" log and you can set log level or creating your custom loggers to debug the issues.
Ratna.
Avatar
Level 2
Thanks, yes, this really helped.
Avatar
Level 2
Hey Ratna,
I would like to thank you for sharing.
Have a good one!!
