Hi. The manual specifies that:
Supporting dynamic outflags can greatly improve performance, preventing After Effects from invalidating your effect's cache as aggressively as it otherwise would.
My problem is the opposite, After Effects often thinks it has valid pixels when it doesn't. For example, I apply my effect and keyframe the % param to 0. I move forward and set a second key to 100%. After Effects still thinks the first frame is cached and valid, even though I just animated my slider. However if I change another slider, it then invalidates the first frame.
I have NON_PARAM_VARY set, so I'm a little confused on how I can make the caching behaviour more aggressive. Any ideas would be appreciated.
that's kind of strange...
is there any other flag set for that param, such as
PF_PUI_STD_CONTROL_ONLY, or PF_ParamFlag_EXCLUDE_FROM_HAVE_INPUTS_CHANGED?
in any case, you can implement PF_OutFlag2_I_MIX_GUID_DEPENDENCIES and
uncache frames as you see fit.
Thanks for the suggestion Shachar, I'd been wondering what PF_OutFlag2_I_MIX_GUID_DEPENDENCIES was for. Turns out the problem was I'd forgotten to set the wide time flag, as I'm checking out values at different times. Silly me.
