Issue: When opening Adobe or any PDF it opens or flashes on the screen and closes promptly. It does not give any error message.
Things I have tried: Uninstalling and reinstalling more than 4 times. Restarting the computer after every uninstall and fresh install. I have tried deleting/renaming SLCach, SLStore, Cache. Also deleted user preferences. Booted into safe mode and it still does not open.
Any help would be appreciated.
Hi Ssmith,
We apologize for the inconvenience caused.
Please refer to the following threads for troubelshooting steps: Acrobat Reader 11 closes immediately, won't open pdf's , link https://forums.adobe.com/thread/1291468
and Acrobat Pro DC Closing Automatically
Please keep us posted.
Regards,
Anand Sri.
The first link did not work. The second article did not fix the issue either. I am using windows uninstaller to uninstall adobe. I also used the adobe cleaner tool and that DID NOT remove all files. It did uninstall but there were traces of adobe still left. YES I restarted after uninstalling.
Hi Ssmith,
I apologize for the inconvenience caused.
Please try the link: https://forums.adobe.com/thread/1291468 Copy-paste the link in a new browser tab.
Use Adobe Cleaner tool to remove the installed Acrobat DC 2015: Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs , link: http://labs.adobe.com/downloads/acrobatcleaner.html
Restart the computer, and then download and install the Acrobat DC 2015: Download Pro or Standard versions of Acrobat DC, 2017, XI, or X
If you have any security software installed, please disable it temporarily and then try.
If this does not help, please create a new Admin user profile and check.
Keep us posted with the results.
Regards,
Anand Sri.
As I stated. I did use the Adobe Cleaner Tool already that did not work. I then used the above link to download and reinstall still the same issue. As far as the corrected link that path does not exist with this version of Acrobat or windows 10. There is not a reader folder.
I will try creating a new admin account although I don't see how recreating my profile will help this as I will have to start all over.
Hi Ssmith,
To download Reader DC: Adobe - Adobe Acrobat Reader DC Distribution Link: https://get.adobe.com/reader/enterprise/
You may also try these steps:
Regards,
Anand Sri.
Actually, reader is not installed at all on this computer. I will give that a try.
Hi Ssmith,
Thank for the update, keep us posted with the results.
Regards,
Anand Sri.
Unfortunately, that did not work either. I did accept the Eula and Reader does launch and work. Adobe Acrobat DC still just crashes.
Hi Ssmith,
If you have any security software, try to disable it temporarily and check with Acrobat DC. If the issue still persists , please create a new Admin user profile and check with Acrobat.
Regards,
Anand Sri.
Didn't know why the inititiator of the problem didn't respond a long time, but I've got the same problem at the moment.
So it would be great if I could jump in an we will look into this?
Hello Markusa,
Sorry for the trouble, please install the latest update of Acrobat help>check for updates, reboot the machine.
If the issue still persists, please use Acrobat cleaner tool to remove Acrobat from machine Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
Reboot and install Acrobat from Download Pro or Standard versions of Acrobat DC, 2017, XI, or X
Let us know how it goes.
Regards,
Anand Sri.
Hello
I am having the same problem - it just closes down all by itself !!
It has been doing that for a few days - I thought I was doing something unconsciously !!
I in fact, I uninstalled and reinstalled it from scratch last night with afresh download and did a <<Check for updates>> which worked fine.
But tried it again this morning and it still closes automatically!!
My current version is 2015.006.30417
I am also on Windows 10 Pro Version 1709 OS Build 16299.248
We are not the only ones: Re: Acrobat DC closes automatically
Fix is definitely needed ........... !!!!!!!!!!!!!!!!
Hello ... anyone there???
This is EXTREMELY annoying now ...
Hi ... I have sent a letter to Adobe to get their attention ...
To be clear, I bought Adobe a couple of years ago and it worked fine.
My PC crashed a few weeks ago and i had to do a complete wipe of the discs and a fresh Windows installation and all my programs.
Hence Adobe has been downloaded fresh a few weeks ago.
The problem is even happening to downloaded PDF documents - you have to be REALLY quick to save the file to your PC before it closes !!!
Its happening on my machine as well. Something needs to be done to prevent this from happening! There should be some better fix than what has been suggested thus far, since they are NOT working!!!!
Adobe lets go, fix this issue, PLEASE.
I had the same issue after running the tools and reinstalling. I found this post: Adobe Acrobat Pro DC closes automatically after opening and turns out the following folder needed to be deleted: C:\ProgramData\Adobe\SLStore as it had an old V11 lic file in it. Once I deleted the folder and re-opened DC, it worked normally and was able to be activated.
For reference ... I gave up waiting for Adobe fixing whatever they broke (2015 had been working quite happily for years but I figure a version update has a bug) and bought a whole new version 2017 !!
I don't have a folder called SLStore on my machine. I did a web search and found not all have it.
I don't think I need to repay for a full version if I have already paid for it. That seems unfair to me, the consumer.
I do love the ability of this program and what I can do with it, but I'm ready to just drop it and only keep the free reader.
Thanks.
Hello Sunnybeach,
Sorry for the delayed response and inconvenience caused. The record shows that you are subscribed to Acrobat Standard DC subscription.
If you are still facing any issue, I will request you to contact the Acrobat technical support team so that they can schedule a remote session and can assist you further Contact Customer Care
Anand Sri.
After deleting the above mentioned folder...My user was required to once again sign in thus recreating this folder. All appears to be working as expected now....
Hello Jamesm,
Good to hear that the issue got fixed, you users are back on track. Feel free to update this discussion for further assistance.
Anand Sri.
