Hey Guys,
Total Noob to all this scripting stuff, but I'm loving it so far!
I've got a problem where, I'm using the following to try and add a camera to my comp:
var myComp = app.project.activeItem;
var myLayers = myComp.layers;
app.beginUndoGroup("New Cam");
myLayers.addCamera("cam", [0,0]);
myLayers.addNull();
myComp.layer(1).name = "CAM_NULL";
myComp.layer(2).parent = myComp.layer(1);
app.endUndoGroup();
The problem I'm having is that when I just add a camera and a null using the UI, they are set up all centred nice and the other layers in my scene don't change. But, when I use my script, it seems like all of the layers in my comp shift to the right and down. I'm noticing this is because when I add the camera using the script, the Point of Interest and Position values for the camera go from (0,0,0) to (-960, -540, 0) when they get parented to the CAM_NULL. 😕
Anyhow, any input as to why this might be happening?
Hi Atekker
No worries, it's a simple fix.
It didn't run because I assigned my composition to a variable "comp" and you assigned it to "myComp".
To fix that you need to fix two lines of your code:
myCam.property("ADBE Transform Group").property("ADBE Position").setValue([comp.width/2, comp.height/2,negZoom]); //if you run the script from Extend Script before fixing, you will see at bottom left "comp is undfined". This is your clue that the variable does not exist. In this line replace comp with myCom
...Copy link to clipboard
You need to adjust the camera after adding it to your comp.
//Assign it to a variable first
var myCam = myLayers.addCamera("cam", [0,0]);
//Then get the zoom value for you camera and invert it
var negZoom = -myCam.property("ADBE Camera Options Group").property("ADBE Camera Zoom").value;
// set your camera position
//set your camera point of interest
myCam.property("ADBE Transform Group").property("ADBE Anchor Point").setValue([comp.width/2, comp.height/2,0]);
then add null and parent it. Should be all good then.
Let me know it works.
Cheers
Henrique
Hey Henrique,
Thanks for getting back to me so quick!
I modified my code to read as follows:
var myCam = myLayers.addCamera("Cam", [0,0]);
myComp.layers.addNull();
myComp.layer(2).parent = myComp.layers.byName("CAM_NULL");
app.endUndoGroup();
...but it seems to just stall after it adds the Camera layer. I don't get any error pop ups and the undo function works as intended, but there doesn't seem to be any changes to the camera properties and the addNull doesn't happen at all.
I thought there might be some issue with one of the properties being "Point of Interest" instead of "Anchor Point", but it doesn't work if I make that change either.
Weird.
Hi Atekker
myCam.property("ADBE Transform Group").property("ADBE Position").setValue([comp.width/2, comp.height/2,negZoom]); //if you run the script from Extend Script before fixing, you will see at bottom left "comp is undfined". This is your clue that the variable does not exist. In this line replace comp with myComp.
myCam.property("ADBE Transform Group").property("ADBE Anchor Point").setValue([comp.width/2, comp.height/2,0]); //same here
Then it should be all good.
Let me know if it works now.
Cheers
Henrique
That did it! Thanks so much Henrique! I really appreciate your help!
Alex
