Expand my Community achievements bar.
Learn about Edge Delivery Services in upcoming GEM session
java.lang.StackOverflowError after starting AEM Quickstart
Avatar
Level 5
Hi Team,
I am getting java.lang.StackOverflowError on the login page after starting AEM Quickstart.
I was able to access AEM Server without any error earlier, I am facing this issue recently.
Please let me know your feedback on the same also I am attaching snapshot for your reference.
with regards,
Richa Chaubey
Avatar
Level 7
Have you upgraded your java version, which version of aem you are using. The above error means your aem is not started at all. Could you please try to run your aem jar from command line. So that we can capture actual error.
Avatar
Employee Advisor
There will be an error message in the error.log file. Please have a look there and provide the file if necessary.
Jörg
Avatar
Level 10
As Joerg suggest - post the log file.
Also - you can always place the QuickStart JAR into a fresh folder to get AEM back.
Avatar
Level 5
Thank you all for your feedback.
I was able to resolve the issue by removing the index folders from the this location:- \crx-quickstart\repository\index. Please let me know if it was the right approach.
As suggested, If I place the jar file in a new directory, altogether new aem instance will be created and I wont be able to use my existing projects.
As suggested, following is the error log generated
13.09.2017 21:11:08.954 *ERROR* [FelixDispatchQueue] com.adobe.granite.socialgraph FrameworkEvent ERROR (org.osgi.framework.ServiceException: Service factory returned null. (Component: com.adobe.granite.security.user.UserPropertiesService (481)))
at org.apache.felix.framework.ServiceRegistrationImpl.getFactoryUnchecked(ServiceRegistrationImpl.java:380)
at org.apache.felix.framework.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:247)
at org.apache.felix.framework.ServiceRegistry.getService(ServiceRegistry.java:344)
at org.apache.felix.framework.Felix.getService(Felix.java:3699)
at org.apache.felix.framework.BundleContextImpl.getService(BundleContextImpl.java:470)
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72)
at org.apache.felix.scr.impl.helper.BindMethod.getServiceObject(BindMethod.java:646)
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2137)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.prebind(DependencyManager.java:1048)
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1457)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:983)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:812)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:774)
at org.apache.felix.framework.ServiceRegistrationImpl.getFactoryUnchecked(ServiceRegistrationImpl.java:347)
at org.apache.sling.adapter.internal.AdapterWebConsolePlugin.addingService(AdapterWebConsolePlugin.java:100)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901)
at org.apache.felix.framework.util.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:991)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:839)
at org.apache.felix.framework.util.EventDispatcher.fireServiceEvent(EventDispatcher.java:546)
at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:4557)
at org.apache.felix.framework.Felix.registerService(Felix.java:3549)
at org.apache.felix.framework.BundleContextImpl.registerService(BundleContextImpl.java:348)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:869)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:857)
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:915)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:715)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:954)
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:915)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:120)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:399)
at org.apache.felix.scr.impl.config.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:676)
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339)
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:360)
at org.apache.felix.scr.impl.Activator.access$000(Activator.java:53)
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:260)
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)
at org.apache.felix.framework.util.EventDispatcher.invokeBundleListenerCallback(EventDispatcher.java:916)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:835)
at org.apache.felix.framework.util.EventDispatcher.fireBundleEvent(EventDispatcher.java:517)
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4541)
at org.apache.felix.framework.Felix.startBundle(Felix.java:2172)
at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1371)
at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308)
at java.lang.Thread.run(Unknown Source)
13.09.2017 21:11:08.961 *INFO* [FelixStartLevel] com.day.cq.cq-compat-commons-auth Service [com.day.cq.compat.commonsauth.impl.SlingAuthenticatorBridge,1182, [org.apache.sling.commons.auth.Authenticator, org.apache.sling.commons.auth.AuthenticationSupport]] ServiceEvent REGISTERED
13.09.2017 21:11:08.962 *INFO* [FelixStartLevel] com.day.cq.cq-compat-commons-auth BundleEvent STARTED
13.09.2017 21:11:08.963 *ERROR* [FelixDispatchQueue] com.adobe.granite.socialgraph FrameworkEvent ERROR (org.osgi.framework.ServiceException: Service factory returned null. (Component: com.adobe.granite.socialgraph.impl.SocialGraphFactoryImpl (491)))
13.09.2017 21:11:08.966 *ERROR* [FelixDispatchQueue] org.apache.sling.adapter FrameworkEvent ERROR (org.osgi.framework.ServiceException: Service factory returned null. (Component: com.adobe.granite.socialgraph.impl.SocialGraphAdapterFactory (490)))
Avatar
Employee Advisor
The stacktrace you posted seems to be caused by an exception in a product bundle; but to investigate further it would require more logs, as I guess that the causing exception is logged before.
Do you see any impact on your system caused by this exception/stacktrace?
Jörg
Avatar
Employee Advisor
smacdonald2008​ You should add, that placing the quickstart into a new directory and starting from there will create a new repository :-)
