16 Replies Latest reply on Nov 2, 2017 3:32 AM by AnandSri
    Acrobat DC keep crashing, when i try to edit some comments on my PDF document
    jossminte
      I'm working on a PDF document of 44 pages, edit from INDESIGN, which mix text & images.
      My client send me back the PDF document with comments on bubbles.
      I was editing the comments on bubbles, and once i reach the second half of the document, it keep crashing after i edit new comments (especially when i want to go to the next page, using the mouse's wheel).
      How to fix that issue ? Is it a bug of the software ? Is there any fix ?
      Thanks for your help !
      here is a screenshot of the message, after crashing :
        • 1. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
          AnandSri Adobe Employee (Admin)
          Hi Jossminte,
          As per the description above, the Acrobat Pro DC is crashing when you try to edit any comment in a PDF, Is that correct?
          Please check for any pending updates for Acrobat Pro DC from Help>Check for updates.
          You may also try to repair the installation files of Acrobat Pro DC from Help>Repair Installation.
          If this does not help, please check with any other PDF file.
          Is it a Mac or Windows machine?
          Check the dot version of Acrobat Pro DC installed, launch Acrobat>navigate to Help menu>select About Adobe Acrobat Pro DC.
          You may refer to the following links: For Windows: Resolve Acrobat DC intermittent crashes on Windows
          For Mac: Acrobat Pro keeps crashing every 8-10 seconds on Mac Lion (Installation & updates)
          Keep us posted with the results.
          Regards,
          Anand Sri.
          • 2. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
            adamg25083311
            I'm having the same problem as well. I try to edit a pdf for my job and no matter what action I'm taking (meaning that i could just be editing it or trying to get to a page i need to edit) and it crashes. Sometimes it crashes quicker and sometimes it takes a few more seconds, but I never have it open for more than 2 minutes before it crashes on me. I'm on Mac version 10.13. Here's the problem report:
            Process:               AdobeAcrobat [969]
            Path:                  /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
            Identifier:            com.adobe.Acrobat.Pro
            Version:               17.012.20098 (17.012.20098)
            Code Type:             X86-64 (Native)
            Parent Process:        ??? [1]
            Responsible:           AdobeAcrobat [969]
            User ID:               501
            Date/Time:             2017-10-09 07:41:47.127 -0500
            OS Version:            Mac OS X 10.13 (17A405)
            Report Version:        12
            Anonymous UUID:        69167E50-5752-9828-1A88-899FB7928393
            Time Awake Since Boot: 2400 seconds
            System Integrity Protection: enabled
            Crashed Thread:        0  Dispatch queue: com.apple.main-thread
            Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
            Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000055242100
            Exception Note:        EXC_CORPSE_NOTIFY
            Termination Signal:    Segmentation fault: 11
            Termination Reason:    Namespace SIGNAL, Code 0xb
            Terminating Process:   exc handler [0]
            VM Regions Near 0x55242100:
                __TEXT                 000000010327f000-0000000103280000 [    4K] r-x/rwx SM=COW  /  [/*/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat]
            Application Specific Information:
            objc_msgSend() selector name: acroOSXFSGetPlatformPath:
            Performing @selector(executeNSMenuItem:) from sender AVCocoaMenuItem 0x6040004b6a40
            Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
            0   libobjc.A.dylib               0x00007fff66e06ea9 objc_msgSend + 41
            1   com.adobe.Acrobat.framework   0x00000001032a58cd 0x10328a000 + 112845
            2   com.adobe.Acrobat.framework   0x00000001035861ef 0x10328a000 + 3129839
            3   com.adobe.Acrobat.framework   0x00000001035a898f 0x10328a000 + 3271055
            4   com.adobe.Acrobat.framework   0x00000001035a5865 0x10328a000 + 3258469
            5   com.adobe.Acrobat.framework   0x00000001035a4d6f 0x10328a000 + 3255663
            6   com.adobe.Acrobat.framework   0x0000000103551798 0x10328a000 + 2914200
            7   com.adobe.Acrobat.framework   0x0000000103551585 0x10328a000 + 2913669
            8   com.adobe.Acrobat.framework   0x00000001035a4646 0x10328a000 + 3253830
            9   com.apple.AE                   0x00007fff41563e20 aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 1788
            10  com.apple.AE                   0x00007fff415636c7 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 41
            11  com.apple.AE                   0x00007fff415635b5 aeProcessAppleEvent + 383
            12  com.apple.HIToolbox           0x00007fff3f7cef60 AEProcessAppleEvent + 55
            13  com.apple.AppKit               0x00007fff3dabccb6 _DPSNextEvent + 2788
            14  com.apple.AppKit               0x00007fff3e251d98 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044
            15  com.apple.AppKit               0x00007fff3dceefcb -[NSApplication _doModalLoop:peek:] + 476
            16  com.apple.AppKit               0x00007fff3ded3c83 __35-[NSApplication runModalForWindow:]_block_invoke_2 + 64
            17  com.apple.AppKit               0x00007fff3ded3c30 __35-[NSApplication runModalForWindow:]_block_invoke + 75
            18  com.apple.AppKit               0x00007fff3e38106c _NSTryRunModal + 100
            19  com.apple.AppKit               0x00007fff3dceca5d -[NSApplication runModalForWindow:] + 133
            20  com.apple.AppKit               0x00007fff3dec1e93 __19-[NSAlert runModal]_block_invoke_2 + 158
            21  com.apple.AppKit               0x00007fff3dec1de2 __19-[NSAlert runModal]_block_invoke + 75
            22  com.apple.AppKit               0x00007fff3e38106c _NSTryRunModal + 100
            23  com.apple.AppKit               0x00007fff3dd61659 -[NSAlert runModal] + 124
            24  com.adobe.Acrobat.framework   0x000000010355b182 0x10328a000 + 2953602
            25  com.adobe.Acrobat.framework   0x0000000103a149d9 0x10328a000 + 7907801
            26  com.adobe.Acrobat.framework   0x0000000103a147ae 0x10328a000 + 7907246
            27  com.adobe.Acrobat.framework   0x000000010355bf5c 0x10328a000 + 2957148
            28  com.adobe.Acrobat.framework   0x0000000103a14f89 0x10328a000 + 7909257
            29  com.adobe.Acrobat.framework   0x0000000103a1f37e 0x10328a000 + 7951230
            30  com.adobe.Acrobat.framework   0x0000000103878a62 0x10328a000 + 6220386
            31  com.adobe.Acrobat.framework   0x0000000103d8ce4f 0x10328a000 + 11546191
            32  com.adobe.Acrobat.framework   0x00000001035668e1 0x10328a000 + 3000545
            33  com.apple.AppKit               0x00007fff3e2539a6 -[NSApplication(NSResponder) sendAction:to:from:] + 312
            34  com.apple.AppKit               0x00007fff3dce935f -[NSMenuItem _corePerformAction] + 323
            35  com.apple.AppKit               0x00007fff3dce90e7 -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 114
            36  com.apple.AppKit               0x00007fff3dd6ecba -[NSMenu performActionForItemAtIndex:] + 133
            37  com.apple.AppKit               0x00007fff3dd6ec25 -[NSMenu _internalPerformActionForItemAtIndex:] + 94
            38  com.apple.AppKit               0x00007fff3dd6ea55 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 106
            39  com.apple.AppKit               0x00007fff3dc354c2 NSSLMMenuEventHandler + 882
            40  com.apple.HIToolbox           0x00007fff3f798284 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1541
            41  com.apple.HIToolbox           0x00007fff3f7975cd SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 374
            42  com.apple.HIToolbox           0x00007fff3f7ac8d1 SendEventToEventTarget + 39
            43  com.apple.HIToolbox           0x00007fff3f7f5e09 SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411
            44  com.apple.HIToolbox           0x00007fff3f81ed3e SendMenuCommandWithContextAndModifiers + 49
            45  com.apple.HIToolbox           0x00007fff3f81ecfa SendMenuItemSelectedEvent + 188
            46  com.apple.HIToolbox           0x00007fff3f81ebd4 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
            47  com.apple.HIToolbox           0x00007fff3f93721c PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1662
            48  com.apple.HIToolbox           0x00007fff3f936697 _HandlePopUpMenuSelection8(OpaqueMenuRef*, OpaqueEventRef*, unsigned int, Point, unsigned short, unsigned int, unsigned int, Rect const*, unsigned short, Rect const*, Rect const*, __CFDictionary const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 409
            49  com.apple.HIToolbox           0x00007fff3f7fee3c _HandlePopUpMenuSelectionWithDictionary + 268
            50  com.apple.AppKit               0x00007fff3dd657ea _NSSLMPopUpCarbonMenu3 + 5632
            51  com.apple.AppKit               0x00007fff3de690ec -[NSCarbonMenuImpl _popUpContextMenu:withEvent:forView:withFont:] + 215
            52  com.apple.AppKit               0x00007fff3de68f54 -[NSMenu _popUpContextMenu:withEvent:forView:withFont:] + 201
            53  com.adobe.Acrobat.framework   0x0000000103566d49 0x10328a000 + 3001673
            54  com.adobe.Acrobat.framework   0x00000001035689f9 0x10328a000 + 3009017
            55  com.adobe.Acrobat.framework   0x0000000103b8e00d 0x10328a000 + 9453581
            56  com.adobe.Acrobat.framework   0x00000001038b34bc 0x10328a000 + 6460604
            57  com.adobe.Acrobat.framework   0x00000001038b4f6a 0x10328a000 + 6467434
            58  com.adobe.Acrobat.framework   0x0000000103a80c92 0x10328a000 + 8350866
            59  com.adobe.Acrobat.framework   0x0000000103a80b1e 0x10328a000 + 8350494
            60  com.adobe.Acrobat.framework   0x0000000103c6fb57 0x10328a000 + 10378071
            61  com.adobe.Acrobat.framework   0x0000000103c6c01d 0x10328a000 + 10362909
            62  com.apple.AppKit               0x00007fff3e3f01a5 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 5040
            63  com.apple.AppKit               0x00007fff3e3ee9d8 -[NSWindow(NSEventRouting) sendEvent:] + 497
            64  com.apple.AppKit               0x00007fff3e2501ef -[NSApplication(NSEvent) sendEvent:] + 2751
            65  com.apple.AppKit               0x00007fff3dab1835 -[NSApplication run] + 812
            66  com.adobe.Acrobat.framework   0x00000001032929dd 0x10328a000 + 35293
            67  com.adobe.Acrobat.framework   0x00000001032911fe RunAcrobat + 246
            68  com.adobe.Acrobat.Pro         0x000000010327ff47 main + 86
            69  libdyld.dylib                 0x00007fff67a03145 start + 1
            Thread 1:: Dispatch queue: NSOperationQueue 0x60800042f5e0 (QOS: UNSPECIFIED)
            0   libsystem_kernel.dylib         0x00007fff67b531d2 __semwait_signal + 10
            1   libsystem_c.dylib             0x00007fff67ace774 nanosleep + 199
            2   com.apple.Foundation           0x00007fff425faa37 +[NSThread sleepForTimeInterval:] + 156
            3   com.adobe.Acrobat.framework   0x00000001042f5416 0x10328a000 + 17216534
            4   com.apple.Foundation           0x00007fff42565dc2 -[__NSOperationInternal _start:] + 778
            5   com.apple.Foundation           0x00007fff42561deb __NSOQSchedule_f + 369
            6   libdispatch.dylib             0x00007fff679c9f64 _dispatch_client_callout + 8
            7   libdispatch.dylib             0x00007fff679dd091 _dispatch_continuation_pop + 472
            8   libdispatch.dylib             0x00007fff679d48e0 _dispatch_async_redirect_invoke + 703
            9   libdispatch.dylib             0x00007fff679cbb56 _dispatch_root_queue_drain + 515
            10  libdispatch.dylib             0x00007fff679cb902 _dispatch_worker_thread3 + 101
            11  libsystem_pthread.dylib       0x00007fff67c8d1ca _pthread_wqthread + 1387
            12  libsystem_pthread.dylib       0x00007fff67c8cc4d start_wqthread + 13
            Thread 2:
            0   libsystem_kernel.dylib         0x00007fff67b52e7e __psynch_cvwait + 10
            1   libsystem_pthread.dylib       0x00007fff67c8e662 _pthread_cond_wait + 732
            2   com.adobe.AGM                 0x0000000105ab7f30 0x105aab000 + 53040
            3   com.adobe.AGM                 0x0000000105ab7e6d 0x105aab000 + 52845
            4   com.adobe.AGM                 0x0000000105e455e5 0x105aab000 + 3778021
            5   libsystem_pthread.dylib       0x00007fff67c8d6c1 _pthread_body + 340
            6   libsystem_pthread.dylib       0x00007fff67c8d56d _pthread_start + 377
            7   libsystem_pthread.dylib       0x00007fff67c8cc5d thread_start + 13
            Thread 3:
            Thread 4:
            Thread 5:: com.apple.NSEventThread
            0   libsystem_kernel.dylib         0x00007fff67b49e76 mach_msg_trap + 10
            1   libsystem_kernel.dylib         0x00007fff67b49390 mach_msg + 60
            2   com.apple.CoreFoundation       0x00007fff404a1475 __CFRunLoopServiceMachPort + 341
            3   com.apple.CoreFoundation       0x00007fff404a07c7 __CFRunLoopRun + 1783
            4   com.apple.CoreFoundation       0x00007fff4049fe43 CFRunLoopRunSpecific + 483
            5   com.apple.AppKit               0x00007fff3dbfa1f1 _NSEventThread + 184
            6   libsystem_pthread.dylib       0x00007fff67c8d6c1 _pthread_body + 340
            7   libsystem_pthread.dylib       0x00007fff67c8d56d _pthread_start + 377
            8   libsystem_pthread.dylib       0x00007fff67c8cc5d thread_start + 13
            Thread 6:
            0   com.adobe.Acrobat.framework   0x00000001037c5d16 0x10328a000 + 5487894
            1   com.adobe.Acrobat.framework   0x00000001037c6d3e 0x10328a000 + 5492030
            2   com.adobe.Acrobat.framework   0x00000001037bb4f5 0x10328a000 + 5444853
            3   com.adobe.Acrobat.framework   0x00000001037c779a 0x10328a000 + 5494682
            4   com.adobe.Acrobat.framework   0x00000001037f0fda 0x10328a000 + 5664730
            5   com.adobe.Acrobat.framework   0x0000000103404631 0x10328a000 + 1549873
            6   com.adobe.Acrobat.framework   0x0000000103330a40 0x10328a000 + 682560
            7   com.adobe.Acrobat.framework   0x00000001033308ff 0x10328a000 + 682239
            8   com.adobe.Acrobat.framework   0x00000001032a43d0 0x10328a000 + 107472
            9   com.adobe.Acrobat.framework   0x0000000103404262 0x10328a000 + 1548898
            10  com.adobe.Acrobat.framework   0x000000010480b152 0x10328a000 + 22548818
            11  com.adobe.Acrobat.framework   0x000000010340094a 0x10328a000 + 1534282
            12  com.adobe.Acrobat.framework   0x000000010340054b 0x10328a000 + 1533259
            13  com.adobe.AGM                 0x0000000105afb44f 0x105aab000 + 328783
            14  com.adobe.AGM                 0x0000000105afb258 0x105aab000 + 328280
            15  com.adobe.AGM                 0x0000000105d01768 0x105aab000 + 2451304
            16  com.adobe.AGM                 0x0000000105ad13e2 0x105aab000 + 156642
            17  com.adobe.AGM                 0x0000000105acf916 0x105aab000 + 149782
            18  com.adobe.AGM                 0x0000000105aca3b1 0x105aab000 + 127921
            19  com.adobe.AGM                 0x0000000105ac88d0 0x105aab000 + 121040
            20  com.adobe.AGM                 0x0000000105ac7d6f 0x105aab000 + 118127
            21  com.adobe.AGM                 0x0000000105af5ff1 0x105aab000 + 307185
            22  com.adobe.AGM                 0x0000000105af5588 0x105aab000 + 304520
            23  com.adobe.AGM                 0x0000000105af5350 0x105aab000 + 303952
            24  com.adobe.Acrobat.framework   0x00000001033fd29c 0x10328a000 + 1520284
            25  com.adobe.Acrobat.framework   0x00000001033fcdcc 0x10328a000 + 1519052
            26  com.adobe.Acrobat.framework   0x0000000104c2ec93 0x10328a000 + 26889363
            27  com.adobe.Acrobat.framework   0x0000000104c2e7bc 0x10328a000 + 26888124
            28  com.adobe.Acrobat.framework   0x0000000104c2c807 0x10328a000 + 26880007
            29  libsystem_pthread.dylib       0x00007fff67c8d6c1 _pthread_body + 340
            30  libsystem_pthread.dylib       0x00007fff67c8d56d _pthread_start + 377
            31  libsystem_pthread.dylib       0x00007fff67c8cc5d thread_start + 13
            Thread 7:
            2   com.adobe.Acrobat.framework   0x00000001036f3b5b 0x10328a000 + 4627291
            3   com.adobe.Acrobat.framework   0x00000001036e45b1 0x10328a000 + 4564401
            4   com.adobe.Acrobat.framework   0x00000001043a9d0f 0x10328a000 + 17956111
            5   com.adobe.Acrobat.framework   0x00000001036e0062 0x10328a000 + 4546658
            6   com.adobe.Acrobat.framework   0x00000001036ee594 0x10328a000 + 4605332
            7   libsystem_pthread.dylib       0x00007fff67c8d6c1 _pthread_body + 340
            8   libsystem_pthread.dylib       0x00007fff67c8d56d _pthread_start + 377
            9   libsystem_pthread.dylib       0x00007fff67c8cc5d thread_start + 13
            Thread 8:
            0   libsystem_kernel.dylib         0x00007fff67b5403a kevent + 10
            1   com.adobe.Acrobat.framework   0x0000000104c39c54 0x10328a000 + 26934356
            2   com.adobe.Acrobat.framework   0x0000000104b68bec 0x10328a000 + 26078188
            3   libsystem_pthread.dylib       0x00007fff67c8d6c1 _pthread_body + 340
            4   libsystem_pthread.dylib       0x00007fff67c8d56d _pthread_start + 377
            5   libsystem_pthread.dylib       0x00007fff67c8cc5d thread_start + 13
            Thread 9:
            0   libsystem_kernel.dylib         0x00007fff67b54592 read + 10
            1   com.adobe.Acrobat.framework   0x00000001036e2957 0x10328a000 + 4557143
            2   com.adobe.Acrobat.framework   0x00000001036e0d1e 0x10328a000 + 4549918
            3   com.adobe.Acrobat.framework   0x00000001036ead46 0x10328a000 + 4590918
            4   com.adobe.Acrobat.framework   0x00000001036e0062 0x10328a000 + 4546658
            5   com.adobe.Acrobat.framework   0x00000001036ee594 0x10328a000 + 4605332
            Thread 10:
            5   com.adobe.AcrobatPlugin.EFS   0x0000000109ff393f 0x109fda000 + 104767
            6   com.apple.Foundation           0x00007fff4255a6d8 __NSThread__start__ + 1197
            Thread 11:: com.apple.NSURLConnectionLoader
            5   com.apple.CFNetwork           0x00007fff3f419432 +[NSURLConnection(Loader) _resourceLoadLoop:] + 357
            Thread 12:
            0   libsystem_kernel.dylib         0x00007fff67b53142 __select + 10
            1   com.adobe.AcrobatPlugin.Comments 0x000000011699d4c8 0x11660e000 + 3732680
            2   com.adobe.AcrobatPlugin.Comments 0x000000011699d995 0x11660e000 + 3733909
            3   com.adobe.AcrobatPlugin.Comments 0x000000011699dd7b 0x11660e000 + 3734907
            4   com.adobe.AcrobatPlugin.Comments 0x000000011691daf1 0x11660e000 + 3209969
            5   com.adobe.AcrobatPlugin.Comments 0x0000000116b2f65d 0x11660e000 + 5379677
            Thread 13:: Dispatch queue: com.apple.root.user-interactive-qos
            5   com.apple.Foundation           0x00007fff4254c3f6 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
            6   com.apple.AppKit               0x00007fff3dbeed6d -[NSAnimation(NSInternal) _runBlocking] + 403
            7   com.apple.AppKit               0x00007fff3dbeeb1c __42-[NSAnimation(NSInternal) _runInNewThread]_block_invoke + 102
            8   libdispatch.dylib             0x00007fff679d17a2 _dispatch_call_block_and_release + 12
            9   libdispatch.dylib             0x00007fff679c9f64 _dispatch_client_callout + 8
            10  libdispatch.dylib             0x00007fff679cbcd9 _dispatch_root_queue_drain + 902
            11  libdispatch.dylib             0x00007fff679cb902 _dispatch_worker_thread3 + 101
            12  libsystem_pthread.dylib       0x00007fff67c8d1ca _pthread_wqthread + 1387
            13  libsystem_pthread.dylib       0x00007fff67c8cc4d start_wqthread + 13
            Thread 14:
            0   libsystem_kernel.dylib         0x00007fff67b536da __workq_kernreturn + 10
            1   libsystem_pthread.dylib       0x00007fff67c8d26f _pthread_wqthread + 1552
            Thread 15:: Dispatch queue: NSCGSDisableUpdates
            2   com.apple.SkyLight             0x00007fff61a743d9 CGSUpdateManager::enable_updates_common() + 565
            3   com.apple.SkyLight             0x00007fff61a18c98 CGSUpdateManager::enable_update(unsigned long long) + 320
            4   libdispatch.dylib             0x00007fff679d17a2 _dispatch_call_block_and_release + 12
            5   libdispatch.dylib             0x00007fff679c9f64 _dispatch_client_callout + 8
            6   libdispatch.dylib             0x00007fff679de42b _dispatch_queue_serial_drain + 635
            7   libdispatch.dylib             0x00007fff679d130e _dispatch_queue_invoke + 373
            8   libdispatch.dylib             0x00007fff679df117 _dispatch_root_queue_drain_deferred_wlh + 332
            9   libdispatch.dylib             0x00007fff679e2ef0 _dispatch_workloop_worker_thread + 880
            10  libsystem_pthread.dylib       0x00007fff67c8d033 _pthread_wqthread + 980
            11  libsystem_pthread.dylib       0x00007fff67c8cc4d start_wqthread + 13
            Thread 16:
            Thread 17:
            0   libsystem_pthread.dylib       0x00007fff67c8cc40 start_wqthread + 0
            1   ???                           0x4058504320000000 0 + 4636544065607827456
            Thread 18:: BackgroundThread
            2   com.macromedia.FlashPlayer-10.6.plugin 0x000000012309107b 0x122c00000 + 4788347
            3   com.macromedia.FlashPlayer-10.6.plugin 0x0000000122c1986e 0x122c00000 + 104558
            4   com.macromedia.FlashPlayer-10.6.plugin 0x0000000123090dec 0x122c00000 + 4787692
            5   com.macromedia.FlashPlayer-10.6.plugin 0x0000000123090e52 0x122c00000 + 4787794
            6   com.macromedia.FlashPlayer-10.6.plugin 0x0000000123090b68 0x122c00000 + 4787048
            Thread 19:: BackgroundThread
            Thread 20:: BackgroundThread
            Thread 21:: BackgroundThread
            Thread 22:: ScriptTimeout
            2   com.macromedia.FlashPlayer-10.6.plugin 0x000000012309103e 0x122c00000 + 4788286
            3   com.macromedia.FlashPlayer-10.6.plugin 0x0000000122e5be36 0x122c00000 + 2473526
            Thread 23:: CoreLoop
            3   com.macromedia.FlashPlayer-10.6.plugin 0x0000000122ffdda1 0x122c00000 + 4185505
            Thread 24:
            0   libsystem_kernel.dylib         0x00007fff67b49eb2 semaphore_wait_trap + 10
            1   com.adobe.AIDE                 0x00000001064cb972 CTThreading::OSSemaphore::Wait() + 16
            2   com.adobe.AIDE                 0x00000001064caa1a CTThreading::ThreadSafeQueue::Dequeue() + 22
            3   com.adobe.AIDE                 0x00000001064caf64 CTThreading::WorkerThread::Start() + 38
            4   com.adobe.AIDE                 0x00000001064ca76a CTThreading::PthreadStart(void*) + 14
            Thread 25:
            Thread 26:
            0   com.adobe.Acrobat.framework   0x000000010380c144 0x10328a000 + 5775684
            1   com.adobe.Acrobat.framework   0x00000001037c2430 0x10328a000 + 5473328
            2   com.adobe.Acrobat.framework   0x00000001037c6042 0x10328a000 + 5488706
            3   com.adobe.Acrobat.framework   0x00000001038117c6 0x10328a000 + 5797830
            4   com.adobe.AIDE                 0x00000001064ca42c CTThreading::GenericWorker::DoGenericWorkerTask(void*) + 42
            5   com.adobe.AIDE                 0x00000001064caf50 CTThreading::WorkerThread::Start() + 18
            6   com.adobe.AIDE                 0x00000001064ca76a CTThreading::PthreadStart(void*) + 14
            Thread 27:
            Thread 28:
            2   com.adobe.Acrobat.framework   0x0000000104c2ed78 0x10328a000 + 26889592
            3   com.adobe.Acrobat.framework   0x0000000104c2e7bc 0x10328a000 + 26888124
            4   com.adobe.Acrobat.framework   0x0000000104c2c807 0x10328a000 + 26880007
            Thread 0 crashed with X86 Thread State (64-bit):
              rax: 0x000060c00025bd20  rbx: 0x0000608000415c60  rcx: 0x0000000000000008  rdx: 0x0000000000000695
              rdi: 0x0000608000415c60  rsi: 0x00000001055262d3  rbp: 0x00007ffeec97d5e0  rsp: 0x00007ffeec97d5a8
               r8: 0x0000000000000000   r9: 0x000060c00025bd20  r10: 0x00000001057ad980  r11: 0x0000000055242100
              r12: 0x0000000000000695  r13: 0x00007fff66e06e80  r14: 0x000060c00025bd20  r15: 0x00007ffeec97d620
              rip: 0x00007fff66e06ea9  rfl: 0x0000000000010206  cr2: 0x0000000055242100
            Logical CPU:     2
            Error Code:      0x00000004
            Trap Number:     14
            Binary Images:
                   0x10327f000 -        0x10327ffff +com.adobe.Acrobat.Pro (17.012.20098 - 17.012.20098) <C8E55D09-69DB-3088-BBCD-BC349D00F1A8> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
                   0x10328a000 -        0x1055c4fff +com.adobe.Acrobat.framework (17.012.20098 - 17.012.20098) <371FBFF1-8FDF-35D7-A755-86262A6894ED> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
                   0x10594a000 -        0x105a8fff7 +com.adobe.ACE (AdobeACE 2.20.02.38462 - 2.20.02.38462) <2A4A6267-20BC-325C-931C-E227220B7650> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                   0x105aab000 -        0x105ff3ff7 +com.adobe.AGM (AdobeAGM 4.30.71.1 - 4.30.71.1) <1AE8FCD6-DF0B-3AC2-BA65-4A1715E42219> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                   0x1060a2000 -        0x1060beffb +com.adobe.BIB (AdobeBIB 1.2.03.38462 - 1.2.03.38462) <63152A89-179C-3DE0-94B8-2ED83DA0CC8C> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                   0x1060ca000 -        0x1063bbff7 +com.adobe.CoolType (AdobeCoolType 5.14.05.38664 - 5.14.05.38664) <27B67E54-C758-3E3F-9D84-0CEBB822F603> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                   0x106407000 -        0x10653dfff +com.adobe.AIDE (1.5.0 - 1.5.0.34124) <CE69D37F-2D03-3B1D-8E63-C04CCC3FC37A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                   0x1065b0000 -        0x1065b3fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporte r
                   0x107b1d000 -        0x107b1fff3  com.apple.textencoding.unicode (4.0 - 4.0) <B2304E3E-5ECA-30E0-8387-AFB1AE0B659D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                   0x107cb8000 -        0x107cbdfff  com.apple.URLMount.CIFSPlugin (7.2 - 7.1) <54F632FE-52B4-3EB8-B344-A2F87A6BEBB5> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb
                   0x107cce000 -        0x107cd2fff  com.apple.audio.AppleHDAHALPlugIn (280.12 - 280.12) <9ACA0127-E687-3885-9475-1D5E4DD83168> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                   0x107dc2000 -        0x107e0c98f  dyld (519.2.1) <002B0442-3D59-3159-BA10-1C0A77859C6A> /usr/lib/dyld
                   0x109c7f000 -        0x109d24fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 15 - 84.159810) <618E11AC-EC35-3215-B2A2-328781C36438> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                   0x109dfd000 -        0x109f3bfff +com.adobe.headlights.LogSessionFramework (7.4.1.11.44704) <3FB068A4-9343-3185-870E-F922267BFA19> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/LogSession.framework/LogSession
                   0x109fda000 -        0x109ffcff7 +com.adobe.AcrobatPlugin.EFS (17.012.20093 - 17.012.20093) <1F3096A1-AEE9-3F71-AE0A-9178CA5B2CF8> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EFS.acroplugin/Contents/MacOS/EFS
                   0x10afe6000 -        0x10b0eeff7 +com.adobe.amtlib (10.0.0.208 - 10.0.0.208) <DBC068C5-C6D3-3CD7-B157-8AA329981277> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/amtlib.framework/amtlib
                   0x10b108000 -        0x10b129fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.9.0.38656 - 3.9.0.38656) <EF4FC8BF-B277-3F25-9599-B7BE4D8485CC> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8Shared Expat
                   0x10b14e000 -        0x10b1bbfff +com.adobe.AcroSQLite (AcroSQLite - 1.0.0) <FEEA52B6-BF5D-3E45-B99A-05FA2321B856> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite
                   0x1144fb000 -        0x114646fe7 +IMSLib.dylib (10.0.0.22 - 10.0.0.22) <980F9F58-3C1B-31CC-8E92-226CACCE74C1> /Applications/Utilities/Adobe Application Manager/*/IMSLib.dylib
                   0x114b29000 -        0x114b38ff3 +com.adobe.AcrobatPlugin.ReadOutLoud (17.012.20093 - 17.012.20093) <F5101807-53F6-3119-BAA4-6923CD5DE136> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/ReadOutLoud.acroplugin/Contents/MacOS/ReadOutLoud
                   0x114c12000 -        0x114c36ff7 +com.adobe.AcrobatPlugin.Updater (17.012.20093 - 17.012.20093) <06C442B2-C757-3D6F-9700-B56A61C0F1D4> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Updater.acroplugin/Contents/MacOS/Updater
                   0x114c84000 -        0x114c88fff +AcrobatUpdateHelperLib.dylib (1) <A8384547-A9BA-3F85-BCA4-4DDE1BD48369> /Library/Application Support/Adobe/*/AcrobatUpdateHelperLib.dylib
                   0x114d1d000 -        0x115066ff7 +com.adobe.AcrobatPlugin.EScript (17.012.20093 - 17.012.20093) <EE005D55-600D-3258-A0D9-F8FE48BD329A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EScript.acroplugin/Contents/MacOS/EScript
                   0x115355000 -        0x115387ff7 +com.adobe.pip (7.4.1.11.44704) <E684FABD-A1CD-329F-80BE-AF6C2FEB415F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                   0x11660e000 -        0x116d6afff +com.adobe.AcrobatPlugin.Comments (17.012.20093 - 17.012.20093) <F93A438A-2DE1-34BF-B5E9-4A7618FDE279> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Comments.acroplugin/Contents/MacOS/Comments
                   0x117291000 -        0x1172d4fff +com.adobe.AcrobatPlugin.WebLink (17.012.20093 - 17.012.20093) <89A89B48-1F8F-37D7-AD0D-82039AB00389> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/WebLink.acroplugin/Contents/MacOS/WebLink
                   0x11da8a000 -        0x11dac8ff7 +libcryptocme.dylib (0) <FBB5731B-265B-32EB-A2A2-78FD28833E45> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libcryptocme.dylib
                   0x11dae0000 -        0x11db3eff7 +libccme_base.dylib (0) <59589393-1392-3DAA-8F3F-8840826C9420> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_base.dylib
                   0x11db68000 -        0x11db9efff +libccme_asym.dylib (0) <F7C87F5D-DCB5-3C46-BDB6-5CD936125F18> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_asym.dylib
                   0x11dbb9000 -        0x11dc7cff7 +libccme_ecc_accel_fips.dylib (0) <ECA407E7-BD54-34A6-B85B-E99EEE6A9F45> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_ecc_accel_fips.dylib
                   0x11dc82000 -        0x11dcebff7 +libccme_ecc.dylib (0) <DA65C6FE-D7F5-305E-BF42-CA3AD7B6C554> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_ecc.dylib
                   0x11dd21000 -        0x11dd7aff7 +libccme_base_non_fips.dylib (0) <FF0F0C06-3F5D-3BA4-9CFB-E90702E171F1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Support/CryptoRSALibs/libccme_base_non_fips.dylib
                   0x11def4000 -        0x11df11fff +com.adobe.PDFSettings (AdobePDFSettings 1.03.0 - 1.3) <7FDF9E77-A5D3-36B1-8372-9B3E3156C138> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/FrameWorks/AdobePDFSettings.framework/AdobePDFSettings
                   0x11df79000 -        0x11df99ffb +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <1B410608-9714-3731-ADA8-F1BC67CE2A37> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                   0x11dfef000 -        0x11e04dff7 +com.adobe.AcrobatPlugin.Accessibility (17.012.20093 - 17.012.20093) <D8B8B13C-4A99-37A6-B4C8-294BA1ED6B72> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Accessibility.acroplugin/Contents/MacOS/Accessibility
                   0x11e05f000 -        0x11ee8dff7 +com.adobe.AcrobatPlugin.AcroForm (17.012.20098 - 17.012.20098) <8F00728F-E95C-348A-988B-724A1254EC7E> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/AcroForm.acroplugin/Contents/MacOS/AcroForm
                   0x11f315000 -        0x11f355ff3 +com.adobe.AcrobatPlugin.Catalog (17.012.20093 - 17.012.20093) <A204A547-FDA5-3FE6-824F-F1F9D290D01A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Catalog.acroplugin/Contents/MacOS/Catalog
                   0x11f35e000 -        0x11f4cdff7 +com.adobe.AcrobatPlugin.DigSig (17.012.20093 - 17.012.20093) <1E3239EB-1155-3225-B98E-F6C91A835DA9> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/DigSig.acroplugin/Contents/MacOS/DigSig
                   0x11f4e6000 -        0x11f735ff7 +com.adobe.AcrobatPlugin.HTML2PDF (17.012.20093 - 17.012.20093) <015FC5AA-95FC-37A5-A3FA-F425004D45E4> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/HTML2PDF.acroplugin/Contents/MacOS/HTML2PDF
                   0x11f76f000 -        0x11f94ffff +com.adobe.AcrobatPlugin.Multimedia (17.012.20093 - 17.012.20093) <C20EFE41-B1C4-3B61-A4EC-4ACC9A3B5055> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Multimedia.acroplugin/Contents/MacOS/Multimedia
                   0x11f977000 -        0x12031bff7 +com.adobe.AcrobatPlugin.PPKLite (17.012.20093 - 17.012.20093) <6614076F-C6EE-3DD6-88D2-F3A30093510F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/PPKLite.acroplugin/Contents/MacOS/PPKLite
                   0x1203ad000 -        0x12041cff7 +com.adobe.AcrobatPlugin.Search (17.012.20093 - 17.012.20093) <34B75F91-D7A5-38C3-A6EB-4020697E12CD> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Search.acroplugin/Contents/MacOS/Search
                   0x120427000 -        0x12061abd3 +com.adobe.AcrobatPlugin.SendMail (17.012.20093 - 17.012.20093) <FAE55402-6E8F-3437-89E0-C97A0E4E2F1F> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/SendMail.acroplugin/Contents/MacOS/SendMail
                   0x120657000 -        0x1206b0ff7 +com.adobe.AcrobatPlugin.Spelling (17.012.20093 - 17.012.20093) <FBD76637-5523-3D98-A237-8B8D218268F1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Spelling.acroplugin/Contents/MacOS/Spelling
                   0x1206bb000 -        0x121400fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                   0x121414000 -        0x121517ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
                   0x121562000 -        0x1215deff7 +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <4D65F948-FC77-3DCB-8370-995E98502B48> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                   0x1215f6000 -        0x121ceeff7 +com.adobe.AcrobatPlugin.TouchUp (17.012.20098 - 17.012.20098) <BB228203-D620-3C31-BA37-55FFFD28EFA9> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/TouchUp.acroplugin/Contents/MacOS/TouchUp
                   0x121de4000 -        0x121edaff7 +com.lextek.onix (3.16.2.5 - 3.16.2.5) <2046F9B8-054F-3E19-AEDB-39425D893D4A> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Onix.framework/Onix
                   0x122c00000 -        0x1244d8e4f +com.macromedia.FlashPlayer-10.6.plugin (27.0.0.130 - 27.0.0.130) <304DC7A0-E78A-31FD-B7AD-F5F5EE13CC6C> /Library/Internet Plug-Ins/Flash Player.plugin/Contents/PlugIns/FlashPlayer-10.6.plugin/Contents/MacOS/FlashPlayer-10.6
                0x7fff38e50000 -     0x7fff38e6cffb  libJapaneseConverter.dylib (70) <3CEF6160-E84C-3512-9252-88181B28C8C5> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                0x7fff38ed2000 -     0x7fff3921fff7  com.apple.RawCamera.bundle (8.00 - 1017) <D3303D4B-A3CE-30C0-9612-5E73FFE8A2C0> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                0x7fff3ad80000 -     0x7fff3b6d7fff  com.apple.GeForceGLDriver (10.24.28 - 10.2.4) <9F11029C-6FEF-3691-99C0-0E640D129385> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
                0x7fff3b6d8000 -     0x7fff3bd92ff7  libclh.dylib (10.24.28) <40F91B76-3ADE-39FF-9B34-F23E70B4B50B> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
                0x7fff3bd93000 -     0x7fff3bf2fff7  com.apple.GeForceMTLDriver (10.24.28 - 10.2.4) <D6CDE36D-034E-3583-B022-A0400A1FE55C> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
                0x7fff3c6ae000 -     0x7fff3c6b2ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <2C807327-4E3E-3153-A943-A2264DFCF41C> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                0x7fff3c6b3000 -     0x7fff3c888ff3  com.apple.avfoundation (2.0 - 1334) <9080A91E-6634-3BC7-BFA3-ED58736B0B25> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                0x7fff3c889000 -     0x7fff3c940ff7  com.apple.audio.AVFAudio (1.0 - ???) <0AF373D0-B01B-31BC-85E0-FA09AEB79803> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                0x7fff3ca50000 -     0x7fff3ca50fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <04FC5A30-0382-3FEB-BE8B-E14E9FF4EBD5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                0x7fff3ca51000 -     0x7fff3ca67fe3  libCGInterfaces.dylib (417) <27E09D39-51B5-3297-BE33-0DB1736B833A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                0x7fff3ca68000 -     0x7fff3cf66fc3  com.apple.vImage (8.1 - ???) <310976EE-E12D-39D7-8F58-6EE924E08576> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                0x7fff3cf67000 -     0x7fff3d0c1fcb  libBLAS.dylib (1211) <10BFDBE2-C8FB-39E3-A204-BC6420663E57> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                0x7fff3d0c2000 -     0x7fff3d0effef  libBNNS.dylib (32) <9CA15DC6-004A-32FD-BFCA-F5D488012C43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                0x7fff3d0f0000 -     0x7fff3d4b0ff7  libLAPACK.dylib (1211) <4560987F-B203-366F-B2CA-3291BCFB511A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                0x7fff3d4b1000 -     0x7fff3d4c6ff7  libLinearAlgebra.dylib (1211) <3ECB936A-1D5A-3BEE-A9A2-248EF132CE3F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                0x7fff3d4c7000 -     0x7fff3d4ccff3  libQuadrature.dylib (3) <3D6BF66A-55B2-3692-BAC7-DEB0C676ED29> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
                0x7fff3d4cd000 -     0x7fff3d52bfff  libSparse.dylib (79.1.1) <7AD0F8A8-FD36-36FE-B83D-58648EBD0027> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparse.dylib
                0x7fff3d52c000 -     0x7fff3d53ffff  libSparseBLAS.dylib (1211) <547C43FB-0243-340A-9B9B-AE8E5A5653BA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                0x7fff3d540000 -     0x7fff3d6dffd7  libvDSP.dylib (622) <8513CE23-5854-31B3-9CDE-25AE9978409B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                0x7fff3d6e0000 -     0x7fff3d790feb  libvMisc.dylib (622) <40CF36D9-8EDE-332B-BB4E-CD9D7BCBEEF5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                0x7fff3d791000 -     0x7fff3d791fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <97572EBF-43F0-314F-AB29-4281E4A3CD41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                0x7fff3d792000 -     0x7fff3d7e9fff  com.apple.Accounts (113 - 113) <C0FFCA63-0C87-3EB8-A02E-F81006532CE9> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
                0x7fff3d7ea000 -     0x7fff3da7affb  com.apple.AddressBook.framework (11.0 - 1805) <7607CB01-DB67-3604-8F38-0BA0623A44A7> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                0x7fff3da7b000 -     0x7fff3e8d6ff3  com.apple.AppKit (6.9 - 1561.0.100) <791A7190-E21D-3513-9BB0-F2721814A9CD> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                0x7fff3e928000 -     0x7fff3e928fff  com.apple.ApplicationServices (48 - 50) <FB589B1C-2A76-3F1E-A258-3E12338E8BFC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                0x7fff3e929000 -     0x7fff3e98ffff  com.apple.ApplicationServices.ATS (377 - 445) <2303339C-5E2A-37DB-B2B0-E4E5DA9121E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                0x7fff3ea28000 -     0x7fff3eb4aff7  libFontParser.dylib (222.1) <611B6E36-289C-33C9-BF77-B9D13F481F33> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                0x7fff3eb4b000 -     0x7fff3eb95ff7  libFontRegistry.dylib (221) <A22F82C0-B4FE-3DB5-B968-79B28257DF2F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                0x7fff3ec3a000 -     0x7fff3ec6dff7  libTrueTypeScaler.dylib (222.1) <60C263D2-7388-3640-A243-F819798C1B0B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                0x7fff3ecd7000 -     0x7fff3ecdbff3  com.apple.ColorSyncLegacy (4.13.0 - 1) <7C8AD42D-5A89-3BA6-B55D-374D9267E939> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncL egacy.framework/Versions/A/ColorSyncLegacy
                0x7fff3ed7b000 -     0x7fff3edcdff7  com.apple.HIServices (1.22 - 622) <2E83CD6F-ED98-3C29-BD0A-8525E38AB5DB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                0x7fff3edce000 -     0x7fff3eddcfff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <71A9C815-AC55-3E36-A618-F6778F5119AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                0x7fff3eddd000 -     0x7fff3ee29fff  com.apple.print.framework.PrintCore (13 - 503) <BC23C22A-7691-3BD4-8013-BAAE3A44763C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                0x7fff3ee2a000 -     0x7fff3ee64fff  com.apple.QD (3.12 - 403) <38D8106A-4FFA-3FE9-9999-714CADD7EE9C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                0x7fff3ee65000 -     0x7fff3ee71fff  com.apple.speech.synthesis.framework (7.0.14 - 7.0.14) <C8AACF93-9FF5-32FE-A448-E174702509FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                0x7fff3ee72000 -     0x7fff3f0fbfff  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <D451B82D-A397-38F0-87CE-D67DB3123365> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                0x7fff3f0fd000 -     0x7fff3f0fdfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <29B5E5A8-51D1-3528-866E-C4D3B78F80A0> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                0x7fff3f413000 -     0x7fff3f776fff  com.apple.CFNetwork (887 - 887) <D7DDB735-A244-3A06-A432-135E9E368B51> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                0x7fff3f78b000 -     0x7fff3f78bfff  com.apple.Carbon (158 - 158) <C34E5FF0-4FDA-35F1-85C2-FDAC4EDE8331> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                0x7fff3f78c000 -     0x7fff3f78fffb  com.apple.CommonPanels (1.2.6 - 98) <39C8EBA3-EEB2-335B-8A88-D6C64BAA112F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                0x7fff3f790000 -     0x7fff3fa94ff7  com.apple.HIToolbox (2.1.1 - 909.1) <39EA833C-2FAD-33B9-BB99-7BDCBCE4B08A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                0x7fff3fa95000 -     0x7fff3fa98ffb  com.apple.help (1.3.8 - 64) <18D02016-119A-33E8-AEB0-E9466BA4AD56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                0x7fff3fa99000 -     0x7fff3fa9efff  com.apple.ImageCapture (9.0 - 9.0) <2DE590E5-DF0E-3962-A2BE-06EBC79B3D72> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                0x7fff3fa9f000 -     0x7fff3fb34ffb  com.apple.ink.framework (10.9 - 220) <D8AECAE3-9FD2-32E3-B659-026F33650BB2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                0x7fff3fb35000 -     0x7fff3fb4fff7  com.apple.openscripting (1.7 - 174) <1CF64DD1-144D-3702-A728-1F476E1A00ED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                0x7fff3fb70000 -     0x7fff3fb71fff  com.apple.print.framework.Print (12 - 267) <E4CBAAFC-9045-38AC-9F93-8C931DDED9D8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                0x7fff3fb72000 -     0x7fff3fb74ff7  com.apple.securityhi (9.0 - 55006) <E7668200-B4CB-3612-96B8-D57E94077787> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                0x7fff3fb75000 -     0x7fff3fb7bfff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1F10ED1F-12C7-39AC-88A0-43A1338F9316> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                0x7fff3fc87000 -     0x7fff3fc87fff  com.apple.Cocoa (6.11 - 22) <3614E923-D790-370A-95EC-42124C76796E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                0x7fff3fc95000 -     0x7fff3fd4eff7  com.apple.ColorSync (4.13.0 - 544) <E959C37C-099B-3DD8-AB3B-67F0625939F7> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
                0x7fff3fed9000 -     0x7fff3ff6cff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <505A5EFB-6BCD-3E94-936F-1722C67F608E> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                0x7fff3ffd3000 -     0x7fff3fffcffb  com.apple.CoreBluetooth (1.0 - 1) <942F88A5-AD68-3359-90D5-6F1A3311C51A> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                0x7fff3fffd000 -     0x7fff4034efeb  com.apple.CoreData (120 - 847.1) <9B5E7B0B-1957-3D56-99CA-6422123D300C> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                0x7fff4034f000 -     0x7fff4041afff  com.apple.CoreDisplay (1.0 - 79.7) <BADA099E-BE1F-3F98-9053-722FB0ECBFBA> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
                0x7fff4041b000 -     0x7fff408bafff  com.apple.CoreFoundation (6.9 - 1443.13) <2881430B-73E5-32C1-B62D-7CEB68A616F5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                0x7fff408bc000 -     0x7fff40ec8fef  com.apple.CoreGraphics (2.0 - 1125.1.1) <425F5F16-3EAF-3B74-BC6B-A0A5FCE6AFF1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                0x7fff40eca000 -     0x7fff411bfff7  com.apple.CoreImage (13.0.0 - 573) <7949E071-A3C0-30BB-B21D-79992CBE82DA> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                0x7fff4142e000 -     0x7fff41509ffb  com.apple.CoreMedia (1.0 - 2074.3) <A11F305C-75BB-33E2-95F8-9B83B6C8A574> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                0x7fff4150a000 -     0x7fff41558fff  com.apple.CoreMediaIO (803.0 - 4976) <F25F26B6-0DA6-3573-B8DC-4911F01519F6> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                0x7fff41559000 -     0x7fff41559fff  com.apple.CoreServices (822.9 - 822.9) <0FF1E8AB-F09A-363F-8839-10D5BBE8F2F4> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                0x7fff4155a000 -     0x7fff415ceff7  com.apple.AE (733 - 733) <09481487-37C2-359E-9E9A-7393B7C8643B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                0x7fff415cf000 -     0x7fff418a6ff7  com.apple.CoreServices.CarbonCore (1178.2 - 1178.2) <A1FE74F8-953B-371E-A8AC-E87B30FB79C6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                0x7fff418a7000 -     0x7fff418dbff7  com.apple.DictionaryServices (1.2 - 284) <3FCEE280-8DD0-37C9-BFD4-7BA87AAFC8EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                0x7fff418dc000 -     0x7fff418e4ff3  com.apple.CoreServices.FSEvents (1239 - 1239) <7BBC5CB7-DBC8-316B-99B0-781827159A2F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                0x7fff418e5000 -     0x7fff41a9cfff  com.apple.LaunchServices (822.9 - 822.9) <E181C2C2-7283-3653-8E19-DA69EBE529E7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                0x7fff41a9d000 -     0x7fff41b4cff3  com.apple.Metadata (10.7.0 - 1191) <32C57F7B-DAC3-3F12-8DEA-1CB5A062DC02> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                0x7fff41b4d000 -     0x7fff41baaff7  com.apple.CoreServices.OSServices (822.9 - 822.9) <C91ABD5F-1FE3-3108-AB5E-BF90D56D1F55> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                0x7fff41bab000 -     0x7fff41c19fff  com.apple.SearchKit (1.4.0 - 1.4.0) <14053F88-2C76-35CA-9FC1-2A9BC0B63F88> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                0x7fff41c1a000 -     0x7fff41c3effb  com.apple.coreservices.SharedFileList (71.2 - 71.2) <41713411-2729-39F9-951A-DE39A00495F0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                0x7fff41c3f000 -     0x7fff41c9aff7  com.apple.CoreSpotlight (1.0 - 229) <83BB5E52-4F0B-3E1F-B105-45191C05F7C9> /System/Library/Frameworks/CoreSpotlight.framework/Versions/A/CoreSpotlight
                0x7fff41ed8000 -     0x7fff42025fff  com.apple.CoreText (352.0 - 578.3) <8A8D96F6-1FBE-320F-A60B-37F63FE20D89> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                0x7fff42026000 -     0x7fff42060fff  com.apple.CoreVideo (1.8 - 278.0) <9C66B618-8582-3731-A0F1-36FDD730FB07> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                0x7fff42061000 -     0x7fff420ebffb  com.apple.framework.CoreWLAN (13.0 - 1335) <D9A8EA05-FE12-322E-8761-F05A68DA8B3B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                0x7fff42278000 -     0x7fff42283ff7  com.apple.DirectoryService.Framework (10.13 - 207) <CC596F1F-16FB-3C22-8D21-E69B6BAA64B4> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                0x7fff42365000 -     0x7fff4236afff  com.apple.DiskArbitration (2.7 - 2.7) <44836CE9-A9ED-3017-972A-7A0A3D6B472B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                0x7fff4252b000 -     0x7fff428eefff  com.apple.Foundation (6.9 - 1443.14) <360EB3B4-CD31-380E-8E77-4954559F97F8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                0x7fff4295e000 -     0x7fff4298eff7  com.apple.GSS (4.0 - 2.0) <EA4ADB9D-FB33-3D20-BE11-7F833988FDD9> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                0x7fff42a9f000 -     0x7fff42ba2ffb  com.apple.Bluetooth (6.0.0 - 6.0.0f7) <6C809D0F-049E-3CDB-AB86-54BD3809D79C> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                0x7fff42c02000 -     0x7fff42c9dfff  com.apple.framework.IOKit (2.0.2 - 1445.1.3) <06331786-CF08-3225-B27B-80754BA0ECB6> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                0x7fff42c9f000 -     0x7fff42ca5ffb  com.apple.IOSurface (209 - 209) <507843CC-3C5D-3548-B86D-4564123F3993> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                0x7fff42ca6000 -     0x7fff42cf9ff7  com.apple.ImageCaptureCore (7.0 - 7.0) <08AD8B51-AF58-348A-9988-61AABDF987D6> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                0x7fff42cfa000 -     0x7fff42e6cfff  com.apple.ImageIO.framework (3.3.0 - 1694) <836F3C70-F8C1-3736-823F-B3A04C0083B0> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                0x7fff42e6d000 -     0x7fff42e71ffb  libGIF.dylib (1694) <D2E653D4-00E1-34C4-B0A4-2D4DD667F236> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                0x7fff42e72000 -     0x7fff42f59fff  libJP2.dylib (1694) <5C071A03-A7F6-33D6-98B7-EACD0D28F72E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                0x7fff42f5a000 -     0x7fff42f7dff7  libJPEG.dylib (1694) <3CB66E19-AD25-3C50-A0A8-48B6C6A1187E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                0x7fff43259000 -     0x7fff4327ffeb  libPng.dylib (1694) <B81D1334-160D-397C-ACAE-D36BEB14B615> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                0x7fff43280000 -     0x7fff43282ffb  libRadiance.dylib (1694) <E3E525DA-1601-3942-8E6D-43CE368E9D1E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                0x7fff43283000 -     0x7fff432d0fff  libTIFF.dylib (1694) <99AA8DE9-04F1-3FBB-995F-6CD2F56AC295> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                0x7fff4348a000 -     0x7fff43feffff  com.apple.JavaScriptCore (13604 - 13604.1.38.1.6) <5C66D28E-F1EE-3A31-A298-3F77DC292126> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                0x7fff44007000 -     0x7fff44020ff7  com.apple.Kerberos (3.0 - 1) <CAF075C0-4C24-3ACE-9AE6-77BEFDEA3622> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                0x7fff44021000 -     0x7fff44056fff  com.apple.LDAPFramework (2.4.28 - 194.5) <8419BDB5-12DF-3BC9-871D-7A270E080249> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                0x7fff442d2000 -     0x7fff442d9fff  com.apple.MediaAccessibility (1.0 - 114) <D72C593A-AC32-3419-AB86-6B07217EBFD5> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                0x7fff44365000 -     0x7fff44961ff7  com.apple.MediaToolbox (1.0 - 2074.3) <1D00A19E-D592-3CC0-A6CC-16E540950070> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                0x7fff44963000 -     0x7fff449e2ff7  com.apple.Metal (123.3.5 - 123.3.5) <ED65B003-6CE3-3EC7-9E0F-E7F2FA8DC63B> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                0x7fff449fd000 -     0x7fff44a12fff  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <D3685A4F-533C-39A6-80B6-7CCA49234329> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework /Versions/A/MPSCore
                0x7fff44a13000 -     0x7fff44a7dfef  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <50B454D2-5D46-394E-B089-AC3242FEA9A2> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framewor k/Versions/A/MPSImage
                0x7fff44a7e000 -     0x7fff44a9dfff  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <0D5F11B0-476D-34EB-8CD0-491BEDA5E4F2> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framewo rk/Versions/A/MPSMatrix
                0x7fff44a9e000 -     0x7fff44b14ff7  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <A4E950B8-380B-3561-8EA4-5C07C3F43816> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork. framework/Versions/A/MPSNeuralNetwork
                0x7fff44b15000 -     0x7fff44b15ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <02E0B95E-1F7C-317A-AF09-149E01D2D641> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceS haders
                0x7fff45b20000 -     0x7fff45b2cffb  com.apple.NetFS (6.0 - 4.0) <81B22AE7-7094-30F2-BF41-84CA05EDB95B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                0x7fff48983000 -     0x7fff4898bfef  libcldcpuengine.dylib (2.8.7) <DD781325-D94E-3AD7-8D6C-817FB3068917> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                0x7fff4898c000 -     0x7fff489d9ffb  com.apple.opencl (2.8.11 - 2.8.11) <8A7F27CA-DD5A-38F0-BE6F-01ECCB05C5A3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                0x7fff489da000 -     0x7fff489f6ffb  com.apple.CFOpenDirectory (10.13 - 207) <582A03AA-A51C-3DAE-AC03-FA1CEE0C5896> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                0x7fff489f7000 -     0x7fff48a02fff  com.apple.OpenDirectory (10.13 - 207) <AAECC5AB-F4ED-38CB-8A7D-7736D97F980A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                0x7fff49b81000 -     0x7fff49b83fff  libCVMSPluginSupport.dylib (16.0.3) <5F651C63-E9B9-3794-B541-71B4B6157DD7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                0x7fff49b84000 -     0x7fff49b87ff7  libCoreFSCache.dylib (160.9) <FF64C4CC-F262-3176-B06A-632C47CD636B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                0x7fff49b88000 -     0x7fff49b8cfff  libCoreVMClient.dylib (160.9) <390D5A60-55BB-3D7B-928B-52BFCA05FD07> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                0x7fff49b8d000 -     0x7fff49b95fff  libGFXShared.dylib (16.0.3) <F0AAA768-B2EB-336B-877C-3F817E78E766> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                0x7fff49b96000 -     0x7fff49ba1fff  libGL.dylib (16.0.3) <6EB2A446-73D8-30B6-97DA-31CB1C42BA27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                0x7fff49ba2000 -     0x7fff49bddfe7  libGLImage.dylib (16.0.3) <A8B1C0BD-6DE9-3C3C-8DDB-AC72DA87BA90> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                0x7fff49bde000 -     0x7fff49d4afff  libGLProgrammability.dylib (16.0.3) <D4D53DAC-F45B-34AD-AAD0-815D0F53D157> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                0x7fff49d4b000 -     0x7fff49d89ffb  libGLU.dylib (16.0.3) <4F964A5D-BC47-368B-88F7-76DA28C2D8AE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                0x7fff4a701000 -     0x7fff4a70fffb  com.apple.opengl (16.0.3 - 16.0.3) <8B17A8DE-89F5-3E2E-897E-315003386475> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                0x7fff4a710000 -     0x7fff4a8a7ffb  GLEngine (16.0.3) <331925D2-4E17-3BA4-8577-C215CE658ACA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
                0x7fff4a8a8000 -     0x7fff4a8d0ffb  GLRendererFloat (16.0.3) <858E25C4-4B7B-317E-897A-C3B66A47BD80> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
                0x7fff4aa87000 -     0x7fff4abd3fff  com.apple.QTKit (7.7.3 - 3014) <CF2818E6-E215-3C24-A2AC-1B5F8AD7E398> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                0x7fff4abd4000 -     0x7fff4ae39fff  com.apple.imageKit (3.0 - 1038) <A5FCC298-F523-3999-8BC1-A076FF9BA506> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                0x7fff4ae3a000 -     0x7fff4af32fff  com.apple.PDFKit (1.0 - 662.1.5) <ACC40859-6B78-39EB-8D29-E9C6763344C6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                0x7fff4af33000 -     0x7fff4b445ff7  com.apple.QuartzComposer (5.1 - 364) <D99600D5-C066-3D49-8641-369A69300D16> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                0x7fff4b446000 -     0x7fff4b469fff  com.apple.quartzfilters (1.10.0 - 1.10.0) <8CBE10F3-828F-373C-B92A-A5289CBCF77A> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                0x7fff4b46a000 -     0x7fff4b561fff  com.apple.QuickLookUIFramework (5.0 - 743.3) <464A71CB-B356-3E9F-91A7-4179095E6F64> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                0x7fff4b562000 -     0x7fff4b562fff  com.apple.quartzframework (1.5 - 21) <3F3BE91F-A032-3E92-ACEA-E2DFEC999E93> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                0x7fff4b563000 -     0x7fff4b7a7fff  com.apple.QuartzCore (1.11 - 574.1.4) <D7CFDB66-4913-33AE-98BB-83F2F3EE26DB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                0x7fff4b7a8000 -     0x7fff4b7fffff  com.apple.QuickLookFramework (5.0 - 743.3) <DB4CAFA3-4F4F-3802-A1CA-197BC4C55F15> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                0x7fff4b9c4000 -     0x7fff4b9dafff  com.apple.SafariServices.framework (13604 - 13604.1.38.1.6) <2CCE692D-BB88-30BF-B819-13E7D34F178B> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
                0x7fff4bfc4000 -     0x7fff4bfdbfff  com.apple.ScriptingBridge (1.3.3 - 70) <44B47809-18BF-3522-B6A0-7C14AA4BE979> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
                0x7fff4bfdc000 -     0x7fff4c2f6fff  com.apple.security (7.0 - 58286.1.33) <210FF9A7-CD6E-3FFB-9935-45A3FEEB89A1> /System/Library/Frameworks/Security.framework/Versions/A/Security
                0x7fff4c2f7000 -     0x7fff4c380ff7  com.apple.securityfoundation (6.0 - 55185.1.1) <917915A4-7A79-3C42-9695-CFD0D9830778> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                0x7fff4c381000 -     0x7fff4c3aefff  com.apple.securityinterface (10.0 - 55109.1.1) <5BAAC4F5-9909-3D93-AAC8-EDF9A65ADB63> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                0x7fff4c3af000 -     0x7fff4c3b2ffb  com.apple.xpc.ServiceManagement (1.0 - 1) <3763B3EF-0573-36A6-9647-8EBB139B9CAC> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                0x7fff4c756000 -     0x7fff4c7c6ffb  com.apple.SystemConfiguration (1.17 - 1.17) <77EB81C7-7017-3777-BCB7-8DD078ABE25D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                0x7fff4c97b000 -     0x7fff4ccf3fff  com.apple.VideoToolbox (1.0 - 2074.3) <BD5A9A0B-4260-3F4C-A030-5F8F9D51B481> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                0x7fff4cf95000 -     0x7fff4d4aeff3  libwebrtc.dylib (7604.1.38.1.6) <90B931F0-49B0-39C4-A46D-98CDC8FD19C7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/Frameworks/libwebrtc.dylib
                0x7fff4d4af000 -     0x7fff4e93dfff  com.apple.WebCore (13604 - 13604.1.38.1.6) <5C6E88AC-7182-344B-85B9-CC24931ECCBB> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                0x7fff4e93e000 -     0x7fff4eb2ffff  com.apple.WebKitLegacy (13604 - 13604.1.38.1.6) <AECB7486-5259-3732-A4FF-0A6942ECA644> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                0x7fff4eb30000 -     0x7fff4ef1ffff  com.apple.WebKit (13604 - 13604.1.38.1.6) <C91F1396-BBC1-3DB8-87B8-3E47853F115B> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                0x7fff4f38a000 -     0x7fff4f414fef  com.apple.APFS (1.0 - 1) <BF3E8416-3064-34E2-90BE-C92CC98B38A7> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
                0x7fff4fff5000 -     0x7fff5001dfff  com.apple.framework.Apple80211 (13.0 - 1335) <0E4FD4E0-D582-3983-A6C8-18D1EA27FBC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                0x7fff5001f000 -     0x7fff5002efef  com.apple.AppleFSCompression (96.1.1 - 1.0) <B24CC74D-7B69-3313-9DC1-8E8B3E9EEBA2> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                0x7fff50168000 -     0x7fff501b0fff  com.apple.AppleJPEG (1.0 - 1) <DCAB2588-8879-3A64-87EA-EAA770BA1ADB> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                0x7fff501c3000 -     0x7fff501e1ff7  com.apple.aps.framework (4.0 - 4.0) <A1BA3B04-8E53-3479-AA0C-B4404BF53982> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                0x7fff501e2000 -     0x7fff501eaff3  com.apple.AppleSRP (5.0 - 1) <4CEC34CF-63E3-3023-B61B-F8D133698534> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                0x7fff501eb000 -     0x7fff50213fff  com.apple.applesauce (1.0 - ???) <32FF4851-2F68-35BA-835F-91856A20C323> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
                0x7fff502dc000 -     0x7fff502dfff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <A6795AC1-D528-3A2F-9C43-14EBFC57B7D6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                0x7fff502e0000 -     0x7fff50330ff7  com.apple.AppleVAFramework (5.0.39 - 5.0.39) <754413E6-FFD1-3CE4-9932-2977AD675319> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                0x7fff509d2000 -     0x7fff509d9ff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <7F54A7A8-3667-3071-9DE6-2D915C63F70C> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/Backgroun dTaskManagement
                0x7fff509da000 -     0x7fff50a61ff7  com.apple.backup.framework (1.9 - 1.9) <3C2E6CB6-3A16-309D-B1E2-ED3930CEE91E> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                0x7fff50ad5000 -     0x7fff50b11fff  com.apple.bom (14.0 - 194.2) <ED2FFB9D-4DA4-322B-89C0-102D790649CD> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                0x7fff51107000 -     0x7fff51134fff  com.apple.CalendarAgentLink (8.0 - 250) <37D477DA-9DC9-340F-927E-D16CB4EC72D8> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLin k
                0x7fff517f9000 -     0x7fff51848ff3  com.apple.ChunkingLibrary (186 - 186) <1009BA1B-B479-36B1-9A07-752DD204BBA6> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                0x7fff5184f000 -     0x7fff518defff  com.apple.CloudDocs (1.0 - 559) <7E2A74CA-EA11-316D-8FD1-2FD8D31E91AF> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                0x7fff523b7000 -     0x7fff523c0ffb  com.apple.CommonAuth (4.0 - 2.0) <F9A7C82E-197F-382E-B854-3DCE83FD6DA3> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                0x7fff523d5000 -     0x7fff523e9ff7  com.apple.commonutilities (8.0 - 900) <9285EF18-980C-3CF0-856E-C5D3A5276F7D> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
                0x7fff5256b000 -     0x7fff525cbffb  com.apple.AddressBook.ContactsFoundation (8.0 - ???) <9B05C7D3-BB29-356C-935F-8D2C435B4F36> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
                0x7fff525cc000 -     0x7fff525eefff  com.apple.contacts.ContactsPersistence (1.0 - 2326) <AFEBD9C8-11BB-38DD-9474-94990F194220> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
                0x7fff5264e000 -     0x7fff52a2efff  com.apple.CoreAUC (249.0.0 - 249.0.0) <7F406271-A215-3C75-BDAA-B9611BA2822E> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                0x7fff52a2f000 -     0x7fff52a5fff7  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <D0879D8F-488A-3D46-BC50-AD7B0642C0E8> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                0x7fff52c57000 -     0x7fff52c60ff7  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <0A87A91C-A2CF-3BB1-9038-7F610111BC30> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                0x7fff52dc4000 -     0x7fff52dd4ff7  com.apple.CoreEmoji (1.0 - 69) <3945FA6E-D060-3F9F-B392-4228E6630F67> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
                0x7fff5368f000 -     0x7fff536a5ff7  com.apple.CoreMediaAuthoring (2.2 - 956) <A5003E93-68B3-3A0E-8252-454CC4CFEC4D> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                0x7fff537e7000 -     0x7fff53843fff  com.apple.CoreNLP (1.0 - 129) <4D51E55E-2D8D-3C35-B2D1-FCBCCF2B77E5> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
                0x7fff539cc000 -     0x7fff539d1ff7  com.apple.CoreOptimization (1.0 - 1) <785B622B-8F7D-3B4D-83AF-EB98CB79FFF6> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
                0x7fff539d2000 -     0x7fff53a6eff7  com.apple.CorePDF (4.0 - 414) <259556DC-97EB-335D-90F0-D0E42FB4AA95> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                0x7fff53b06000 -     0x7fff53b0eff7  com.apple.CorePhoneNumbers (1.0 - 1) <88C31D1D-6611-345F-BF8B-635EC10DB2E5> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
                0x7fff53b0f000 -     0x7fff53b6bfff  com.apple.CorePrediction (1.0 - 1) <B1E687BA-4E62-321B-8C87-D37C540A5A68> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
                0x7fff53c97000 -     0x7fff53cc8ff3  com.apple.CoreServicesInternal (309 - 309) <CB3D74CC-1568-3E66-8015-2A3D11BCAF21> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                0x7fff53fed000 -     0x7fff5407efff  com.apple.CoreSymbolication (63075) <22359913-3FAE-3FE3-9F88-F3521169FB4E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                0x7fff54101000 -     0x7fff54235fd7  com.apple.coreui (2.1 - 489) <8DAE0B7F-186E-333F-8B8E-941DB03BF2FC> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                0x7fff54236000 -     0x7fff5432fffb  com.apple.CoreUtils (5.2 - 520.68) <7F80020B-0208-38A7-B333-EC1463FF1AA4> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                0x7fff54384000 -     0x7fff543e8fff  com.apple.framework.CoreWiFi (13.0 - 1335) <AEF55AE3-983E-31D0-A578-61284964339C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                0x7fff543e9000 -     0x7fff543f8ff7  com.apple.CrashReporterSupport (10.13 - 1) <842680F4-0BFB-386A-A32D-E9ED39DCE790> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                0x7fff543f9000 -     0x7fff54468fff  com.apple.DCERPC (2.0 - 63) <1A67096F-3EDC-3537-A9A1-4E54E3E77EF1> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC
                0x7fff54475000 -     0x7fff54484ff7  com.apple.framework.DFRFoundation (1.0 - 189.1) <C7DE4082-6AC1-3971-AAC7-979E33C9D0F1> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
                0x7fff54487000 -     0x7fff5448bffb  com.apple.DSExternalDisplay (3.1 - 380) <BEC07C7C-F3AC-3CF3-B13E-3EBFD6224C0D> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDispla y
                0x7fff544d0000 -     0x7fff54511ff3  com.apple.datadetectors (5.0 - 375) <89B1F001-E7A2-347F-BCE1-2B7957A1D3D2> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                0x7fff54512000 -     0x7fff54588ff7  com.apple.datadetectorscore (7.0 - 590) <48B788AF-7927-341E-94EE-119561245659> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                0x7fff545d6000 -     0x7fff54616ff7  com.apple.DebugSymbols (141 - 141) <99562E28-0E56-3F6F-93A1-EF997A5E1F87> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                0x7fff54617000 -     0x7fff54741ff7  com.apple.desktopservices (1.12 - 1.12) <C6BBDC1D-106A-324A-9325-FCB62F38E7FB> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                0x7fff5479e000 -     0x7fff5479fff7  com.apple.diagnosticlogcollection (10.0 - 1000) <FB2D070B-AA55-38C1-96BB-FF8C7BD22CA0> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/Diagnostic LogCollection
                0x7fff5497b000 -     0x7fff54986ff7  com.apple.DisplayServicesFW (3.1 - 380) <FB1FBB24-7FD5-3B57-8D3C-39F953F8A9BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                0x7fff55151000 -     0x7fff55169fff  com.apple.Engram (1.0 - 1) <5533EDB6-3395-305B-A17C-2A22214BE564> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
                0x7fff55494000 -     0x7fff558c2fff  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <80C97AD7-D5C2-311A-B268-4AA60CAD6CED> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                0x7fff558f0000 -     0x7fff55976ffb  com.apple.FileProvider (111.1 - 111.1) <57DC140C-1F60-3351-BA67-6A0C07B4CF58> /System/Library/PrivateFrameworks/FileProvider.framework/Versions/A/FileProvider
                0x7fff5751e000 -     0x7fff5751efff  libmetal_timestamp.dylib (802.1.35) <73D8B306-6321-30DB-8522-819344E19AF8> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3802/Libraries/libmetal_ timestamp.dylib
                0x7fff58b7e000 -     0x7fff58b89ff7  libGPUSupportMercury.dylib (16.0.3) <7C3F6819-4E0A-34A1-A11B-059C51BE0699> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
                0x7fff58f26000 -     0x7fff58f4bff3  com.apple.GenerationalStorage (2.0 - 281) <8BAB613F-84AA-3001-8D14-F1E1BBB7FBF5> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                0x7fff598c2000 -     0x7fff598d1fff  com.apple.GraphVisualizer (1.0 - 5) <0A93C5DE-0D28-312E-8764-6B0FB805ED91> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
                0x7fff59949000 -     0x7fff599bdfff  com.apple.Heimdal (4.0 - 2.0) <600A9BD5-3DD2-3F7C-B40E-8485026FE936> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                0x7fff599be000 -     0x7fff599ebfff  com.apple.HelpData (2.3 - 154) <81CDA3EF-246A-3AE5-8705-6F3057FC06F7> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                0x7fff59a56000 -     0x7fff59b68ff3  com.apple.ids (10.0 - 1000) <C8E10EB7-D298-36C2-A67E-C362DCFC00E8> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
                0x7fff59b69000 -     0x7fff59c45fff  com.apple.idsfoundation (10.0 - 1000) <833CA186-0312-33A0-93A3-A7C0839EFBC0> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
                0x7fff5a148000 -     0x7fff5a1adfff  com.apple.imfoundation (10.0 - 1000) <18D21CE9-961E-3DA4-A6E2-C814CB15036D> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
                0x7fff5a25d000 -     0x7fff5a264ffb  com.apple.IOAccelerator (373 - 373) <22F55498-DF4D-3262-B527-0277E8C6BAA5> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                0x7fff5a268000 -     0x7fff5a27eff7  com.apple.IOPresentment (1.0 - 32.1) <8F468709-520F-360D-AD51-0E13298B8DC0> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
                0x7fff5a63d000 -     0x7fff5a662ffb  com.apple.IconServices (97.3 - 97.3) <9FB00A91-C46B-3CF1-973A-FDDABCEA088D> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                0x7fff5a769000 -     0x7fff5a76cff3  com.apple.InternationalSupport (1.0 - 1) <0EA71B0F-1B0D-3072-8945-1FD9041A80BD> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/International Support
                0x7fff5a7da000 -     0x7fff5a7eaffb  com.apple.IntlPreferences (2.0 - 227) <500CB7B9-7BDF-39E6-B355-28E100B28793> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
                0x7fff5a885000 -     0x7fff5a892fff  com.apple.KerberosHelper (4.0 - 1.0) <06271ABF-0798-3947-86F7-6FAF863BC56C> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
                0x7fff5a8f3000 -     0x7fff5a9e8ff7  com.apple.LanguageModeling (1.0 - 159) <FADD52FC-9B63-3976-9AB1-40230918F84F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                0x7fff5a9e9000 -     0x7fff5aa2bff7  com.apple.Lexicon-framework (1.0 - 33) <CEF5A399-DFD3-347D-8EEE-8F01038B9900> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
                0x7fff5aa2f000 -     0x7fff5aa36ff7  com.apple.LinguisticData (1.0 - 238) <3DB10488-85F6-3A70-87CF-A2D1B1ABC016> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
                0x7fff5ab6c000 -     0x7fff5ab89ff3  com.apple.LookupFramework (1.2 - 237) <FC452756-F465-387B-9219-84B65A0BCB57> /System/Library/PrivateFrameworks/Lookup.framework/Versions/A/Lookup
                0x7fff5b244000 -     0x7fff5b247fff  com.apple.Mangrove (1.0 - 1) <562BB18E-815A-37D1-A373-B46C7853BA94> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                0x7fff5b2cf000 -     0x7fff5b2d1ff7  com.apple.marco (10.0 - 1000) <88A5D4DB-0A6F-33AA-991E-ED29504040E8> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
                0x7fff5b60f000 -     0x7fff5b676ff7  com.apple.gpusw.MetalTools (1.0 - 1) <32E08129-AC43-315C-8A14-3CD7BE507850> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
                0x7fff5b67e000 -     0x7fff5b692ff3  com.apple.MobileAssets (1.0 - 437.1.11) <AF26C530-C18C-32BC-881E-CAFAE4CEF8EE> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
                0x7fff5b7e8000 -     0x7fff5b7ffffb  com.apple.MobileKeyBag (2.0 - 1.0) <7405128E-E7B0-3EFB-BA65-EA50564E3BCD> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
                0x7fff5b88b000 -     0x7fff5b8b3ff7  com.apple.MultitouchSupport.framework (1004.1 - 1004.1) <69BF94F5-9301-3755-98A1-A981DB03C395> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                0x7fff5b8b4000 -     0x7fff5b8bcffb  com.apple.multiverse (1.0 - 27) <0AF7A4FF-5337-39B8-B507-2ABC7A080235> /System/Library/PrivateFrameworks/MultiverseSupport.framework/Versions/A/MultiverseSuppor t
                0x7fff5bb17000 -     0x7fff5bb22fff  com.apple.NetAuth (6.2 - 6.2) <5C6F492A-28EF-3A0E-B573-6F3D60CFF0C7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                0x7fff5bb2f000 -     0x7fff5bbfcff7  com.apple.Network (1.0 - 1) <35C610C2-A2CB-3894-828B-819C16F55372> /System/Library/PrivateFrameworks/Network.framework/Versions/A/Network
                0x7fff5d2da000 -     0x7fff5d31affb  com.apple.PerformanceAnalysis (1.183 - 183) <520FEF4A-4C60-31FA-8BA0-528294BC41ED> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                0x7fff5d390000 -     0x7fff5d390ff7  com.apple.PhoneNumbers (1.0 - 1) <ECC7CCB3-4903-3677-B0C9-E64F036C64EC> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                0x7fff5ed70000 -     0x7fff5ed95fff  com.apple.pluginkit.framework (1.0 - 1) <5563493F-9BE6-3B11-9261-C330FF14CA16> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
                0x7fff5f0d9000 -     0x7fff5f0f7fff  com.apple.ProtocolBuffer (1 - 259) <D047A3FE-C7A8-3CAA-9891-6232BA88C247> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                0x7fff5f264000 -     0x7fff5f279ff3  com.apple.QuickLookThumbnailing (1.0 - 1) <0771325B-BBAD-3865-B2A3-BE7089641C52> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
                0x7fff5f2bd000 -     0x7fff5f2c6ff3  com.apple.xpc.RemoteServiceDiscovery (1.0 - 1205.1.10) <488A5851-FDEF-3F70-AEBC-BDCF4E58188A> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServi ceDiscovery
                0x7fff5f2c7000 -     0x7fff5f2eaffb  com.apple.RemoteViewServices (2.0 - 125) <AEDBCE8C-88B7-315A-9F81-3E068F0D3EDC> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                0x7fff5f2eb000 -     0x7fff5f2fcff3  com.apple.xpc.RemoteXPC (1.0 - 1205.1.10) <AB4045A3-9A24-39AE-8907-47699B8F36F4> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
                0x7fff5f798000 -     0x7fff5f7b0ff7  com.apple.SMBClient (3.2 - 3.2) <443F0031-7E25-3467-8B25-9BB6B34DCF18> /System/Library/PrivateFrameworks/SMBClient.framework/Versions/A/SMBClient
                0x7fff60beb000 -     0x7fff60ce4ff7  com.apple.Sharing (910.7 - 910.7) <465C0170-A544-3713-AB5A-894756E6C13E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                0x7fff60ce5000 -     0x7fff60d04ff3  com.apple.shortcut (2.16 - 98) <B8A517F6-B872-3A71-B096-709A0CC6656F> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                0x7fff60d0e000 -     0x7fff60d0ffff  com.apple.performance.SignpostNotification (1.0 - 1) <5C953AF5-746A-3049-A2BC-901D6C7B583F> /System/Library/PrivateFrameworks/SignpostNotification.framework/Versions/A/SignpostNotif ication
                0x7fff61a08000 -     0x7fff61c9ffff  com.apple.SkyLight (1.600.0 - 312) <9BF6B34C-532F-3F84-9B47-C9121FFF0A01> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
                0x7fff6244c000 -     0x7fff62459ff7  com.apple.SpeechRecognitionCore (4.0.13 - 4.0.13) <AC026FB9-78F8-31F9-BB80-619D5378DB70> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                0x7fff6250a000 -     0x7fff62745ff3  com.apple.spotlight.index (10.7.0 - 1191) <7F436FF6-135E-322E-9834-44CF7ED1699A> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
                0x7fff628ee000 -     0x7fff62914ff3  com.apple.StreamingZip (1.0 - 1) <3D46509E-3EB7-3EC8-828D-19BF3C8670BD> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
                0x7fff62fe5000 -     0x7fff63069fe7  com.apple.Symbolication (9.0 - 63079.1) <177BC9CA-E6AE-3B40-806F-0080C0CDFF29> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                0x7fff6307a000 -     0x7fff63081fff  com.apple.SymptomDiagnosticReporter (1.0 - 820.1.4) <29851256-D036-3CF9-9558-D7694D04704F> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomD iagnosticReporter
                0x7fff63554000 -     0x7fff6355bff7  com.apple.TCC (1.0 - 1) <1774542A-1E70-3E22-9698-372200D27249> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                0x7fff63761000 -     0x7fff63822ff7  com.apple.TextureIO (3.4 - 3.4) <7C93B388-7171-3B3D-BD23-0A8280059260> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
                0x7fff63873000 -     0x7fff6388effb  com.apple.ToneKit (1.0 - 1) <A0242052-983B-3726-B5BD-D2E672CEFE2F> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
                0x7fff6388f000 -     0x7fff638b6fff  com.apple.ToneLibrary (1.0 - 1) <7EEABD7F-D0CB-327E-A772-ACF406B9C8F2> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
                0x7fff638c6000 -     0x7fff638c7fff  com.apple.TrustEvaluationAgent (2.0 - 31) <39F533B2-211E-3635-AF47-23F27749FF4A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                0x7fff638cd000 -     0x7fff63a7cff7  com.apple.UIFoundation (1.0 - 543) <A393DE4F-0885-3C7C-9933-F3AF8D58B93F> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                0x7fff6473c000 -     0x7fff6480bfff  com.apple.ViewBridge (341.1 - 341.1) <53A2272D-E834-3A48-829B-D71E05B9E714> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                0x7fff64f70000 -     0x7fff64fd0fff  com.apple.xquery (1.3.1 - 30) <D18B188E-9D92-3644-9612-6ECB2D9C908F> /System/Library/PrivateFrameworks/XQuery.framework/Versions/A/XQuery
                0x7fff65199000 -     0x7fff6519bffb  com.apple.loginsupport (1.0 - 1) <5E2C4AA7-066D-3FDB-B0E1-4CDAF287392C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                0x7fff651dc000 -     0x7fff65209fff  com.apple.contacts.vCard (1.0 - 2326) <38202649-B1F2-3F6D-B2AC-5EC76C9FAB52> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
                0x7fff652ff000 -     0x7fff65332fff  libclosured.dylib (519.2.1) <31A6AC03-8F51-367E-9E00-FF0F1AD10F6F> /usr/lib/closure/libclosured.dylib
                0x7fff653d1000 -     0x7fff6540aff7  libCRFSuite.dylib (41) <AB2DA745-F22C-30CF-81D4-35DD716463B8> /usr/lib/libCRFSuite.dylib
                0x7fff6540b000 -     0x7fff65416fff  libChineseTokenizer.dylib (28) <D30A7DB6-058F-3286-9583-60C9EEB77A6E> /usr/lib/libChineseTokenizer.dylib
                0x7fff654a8000 -     0x7fff654a9ff3  libDiagnosticMessagesClient.dylib (104) <9712E980-76EE-3A89-AEA6-DF4BAF5C0574> /usr/lib/libDiagnosticMessagesClient.dylib
                0x7fff654e0000 -     0x7fff656aaff3  libFosl_dynamic.dylib (17.7) <B2476843-7FA7-3E62-B79F-2B15FE557E63> /usr/lib/libFosl_dynamic.dylib
                0x7fff656e2000 -     0x7fff656e2fff  libOpenScriptingUtil.dylib (174) <203D2C39-61BB-3713-A502-2D17B04A42AC> /usr/lib/libOpenScriptingUtil.dylib
                0x7fff6580b000 -     0x7fff6580fffb  libScreenReader.dylib (562.1) <107BB2E9-A973-322E-8BDA-5E4DA4061A77> /usr/lib/libScreenReader.dylib
                0x7fff65810000 -     0x7fff65811ff3  libSystem.B.dylib (1252) <BBBE6ABC-FD84-30A3-B699-95F1D6EFB334> /usr/lib/libSystem.B.dylib
                0x7fff65890000 -     0x7fff65891fff  libThaiTokenizer.dylib (2.2) <04AC7CD4-BD9A-3B1D-8CEB-9E2030B6B667> /usr/lib/libThaiTokenizer.dylib
                0x7fff658a4000 -     0x7fff658a4fff  libapple_crypto.dylib (109.1.6) <1C66C4B7-7E7C-36BC-858E-6661016C971A> /usr/lib/libapple_crypto.dylib
                0x7fff658a5000 -     0x7fff658bbff7  libapple_nghttp2.dylib (1.24) <01402BC4-4822-3676-9C80-50D83F816424> /usr/lib/libapple_nghttp2.dylib
                0x7fff658bc000 -     0x7fff658e6ff3  libarchive.2.dylib (54) <8FC28DD8-E315-3C3E-95FE-D1D2CBE49888> /usr/lib/libarchive.2.dylib
                0x7fff658e7000 -     0x7fff65968fdf  libate.dylib (1.13.1) <178ACDAD-DE7E-346C-A613-1CBF7929AC07> /usr/lib/libate.dylib
                0x7fff6596c000 -     0x7fff6596cff3  libauto.dylib (187) <A05C7900-F8C7-3E75-8D3F-909B40C19717> /usr/lib/libauto.dylib
                0x7fff6596d000 -     0x7fff65a1cffb  libboringssl.dylib (109.1.6) <BF41A380-8FD1-3043-BF93-171EBAEE395F> /usr/lib/libboringssl.dylib
                0x7fff65a1d000 -     0x7fff65a2dff3  libbsm.0.dylib (39) <770B341F-3BB7-3123-B53C-F2D58868A963> /usr/lib/libbsm.0.dylib
                0x7fff65a2e000 -     0x7fff65a3bffb  libbz2.1.0.dylib (38) <0A5086BB-4724-3C14-979D-5AD4F26B5B45> /usr/lib/libbz2.1.0.dylib
                0x7fff65a3c000 -     0x7fff65a92fff  libc++.1.dylib (400.9) <FCF5E1F6-2B04-3545-8004-F3AB32FED172> /usr/lib/libc++.1.dylib
                0x7fff65a93000 -     0x7fff65ab7ff7  libc++abi.dylib (400.7) <217656D5-BC40-37FF-B322-91CB2AAD4F34> /usr/lib/libc++abi.dylib
                0x7fff65ab9000 -     0x7fff65ac9fff  libcmph.dylib (6) <A5509EE8-7E00-3224-8814-015B077A3CF5> /usr/lib/libcmph.dylib
                0x7fff65aca000 -     0x7fff65ae0fff  libcompression.dylib (47) <E64D4416-DFBF-314B-BBB9-BED23C3A251C> /usr/lib/libcompression.dylib
                0x7fff65d86000 -     0x7fff65d9eff7  libcoretls.dylib (155) <DFE2454F-2FE3-3B2B-A22B-422947C34C69> /usr/lib/libcoretls.dylib
                0x7fff65d9f000 -     0x7fff65da0ffb  libcoretls_cfhelpers.dylib (155) <D3F4B882-40C1-3CD4-927B-0E0ED6031D0B> /usr/lib/libcoretls_cfhelpers.dylib
                0x7fff65e56000 -     0x7fff65f38ff3  libcrypto.0.9.8.dylib (76) <DC7EA115-9135-3ED9-9A57-3C5588E74592> /usr/lib/libcrypto.0.9.8.dylib
                0x7fff65f39000 -     0x7fff660c9fff  libcrypto.35.dylib (22) <067CFC21-249D-392D-ADE1-785100BF0F83> /usr/lib/libcrypto.35.dylib
                0x7fff66270000 -     0x7fff662c6ff3  libcups.2.dylib (462) <E19FD002-6672-3EE3-B632-34876074270F> /usr/lib/libcups.2.dylib
                0x7fff66348000 -     0x7fff6634fff3  libdscsym.dylib (183) <B0DD51C0-0628-38B1-8863-635C4AEBB16E> /usr/lib/libdscsym.dylib
                0x7fff66404000 -     0x7fff66404fff  libenergytrace.dylib (16) <A92AB8B8-B986-3CE6-980D-D55090FEF387> /usr/lib/libenergytrace.dylib
                0x7fff6642c000 -     0x7fff6642dfff  libffi.dylib (18.1) <02011073-8CB7-362F-BC52-43B4E83687B0> /usr/lib/libffi.dylib
                0x7fff66436000 -     0x7fff6643aff7  libgermantok.dylib (17) <379C5DC6-BEDB-378D-B09C-A63D297EAA6D> /usr/lib/libgermantok.dylib
                0x7fff6643b000 -     0x7fff66440ffb  libheimdal-asn1.dylib (520) <D968FE68-7770-3AEA-BFEB-3F7F4CB10DDC> /usr/lib/libheimdal-asn1.dylib
                0x7fff6646c000 -     0x7fff6655dff7  libiconv.2.dylib (51) <0772997F-4109-38A1-91ED-0F3F16AE99E5> /usr/lib/libiconv.2.dylib
                0x7fff6655e000 -     0x7fff66784ffb  libicucore.A.dylib (59117.0.1) <EC29683E-E9DE-3100-8F75-D1FEBB82AAB2> /usr/lib/libicucore.A.dylib
                0x7fff667d1000 -     0x7fff667d2fff  liblangid.dylib (128) <39C39393-0D05-301D-93B2-F224FC4949AA> /usr/lib/liblangid.dylib
                0x7fff667d3000 -     0x7fff667ecffb  liblzma.5.dylib (10) <3D419A50-961F-37D2-8A01-3DC7AB7B8D18> /usr/lib/liblzma.5.dylib
                0x7fff667ed000 -     0x7fff66803ff7  libmarisa.dylib (9) <D6D2D55D-1D2E-3442-B152-B18803C0ABB4> /usr/lib/libmarisa.dylib
                0x7fff66804000 -     0x7fff668b3fff  libmecab.1.0.0.dylib (779.1) <134BD345-6F0F-32A3-A2BA-AE219D9848E6> /usr/lib/libmecab.1.0.0.dylib
                0x7fff668b4000 -     0x7fff66adcfff  libmecabra.dylib (779.1) <C1A7BAE5-2E7A-396D-A3A2-00484CAA9B40> /usr/lib/libmecabra.dylib
                0x7fff66cb4000 -     0x7fff66d8aff7  libnetwork.dylib (1229.1.5) <6134BC02-EC6F-342F-8FCE-673798505400> /usr/lib/libnetwork.dylib
                0x7fff66e00000 -     0x7fff671ee7e7  libobjc.A.dylib (723) <93A92316-DE1E-378C-8891-99720B50D075> /usr/lib/libobjc.A.dylib
                0x7fff67201000 -     0x7fff67205fff  libpam.2.dylib (22) <7B4D2CE2-1438-387A-9802-5CEEFBF26F86> /usr/lib/libpam.2.dylib
                0x7fff67208000 -     0x7fff6723cfff  libpcap.A.dylib (79) <D400B242-A56A-39CD-9445-740460F1A62F> /usr/lib/libpcap.A.dylib
                0x7fff6723d000 -     0x7fff6727afff  libpcre.0.dylib (9) <ABAD6F81-41C0-3AD2-B104-0753A925A205> /usr/lib/libpcre.0.dylib
                0x7fff672bc000 -     0x7fff672d8ffb  libresolv.9.dylib (65) <E8F3415B-4472-3202-8901-41FD87981DB2> /usr/lib/libresolv.9.dylib
                0x7fff67313000 -     0x7fff67325fff  libsasl2.2.dylib (211) <D9E281A2-D7BA-32CD-8B96-54972B1D9E66> /usr/lib/libsasl2.2.dylib
                0x7fff67326000 -     0x7fff67327ff7  libspindump.dylib (247) <E7A7ECD0-1070-390C-A696-A3305CB9BD87> /usr/lib/libspindump.dylib
                0x7fff67328000 -     0x7fff674bdfef  libsqlite3.dylib (274.1) <075468C1-75CE-318F-9E9B-F62B6A88E1B3> /usr/lib/libsqlite3.dylib
                0x7fff675bf000 -     0x7fff6760dfff  libstdc++.6.0.9.dylib (104.1) <92CC5BBD-2FB2-3864-BF6B-B4B1BFF4C1EE> /usr/lib/libstdc++.6.0.9.dylib
                0x7fff67640000 -     0x7fff67675fff  libtidy.A.dylib (15.18.1) <3E33A53A-53AB-3FD5-BBAB-DFA6A3A90132> /usr/lib/libtidy.A.dylib
                0x7fff6768d000 -     0x7fff676c6ffb  libusrtcp.dylib (1229.1.5) <F3338E88-885C-3203-9D5A-5CA51CEBE567> /usr/lib/libusrtcp.dylib
                0x7fff676c7000 -     0x7fff676caffb  libutil.dylib (51) <58C59F00-031B-3798-B697-A8A4C58E70AA> /usr/lib/libutil.dylib
                0x7fff676cb000 -     0x7fff676d8fff  libxar.1.dylib (400) <0316128D-3B47-3052-995D-97B4FE5491DC> /usr/lib/libxar.1.dylib
                0x7fff676dc000 -     0x7fff677c3fff  libxml2.2.dylib (31.7) <49544596-BCF8-3765-8DC5-DB1A9A90EF92> /usr/lib/libxml2.2.dylib
                0x7fff677c4000 -     0x7fff677ecfff  libxslt.1.dylib (15.10) <66682AF6-C2D5-374C-901F-25A3E72814DC> /usr/lib/libxslt.1.dylib
                0x7fff677ed000 -     0x7fff677ffffb  libz.1.dylib (70) <48C67CFC-940D-3857-8DAD-857774605352> /usr/lib/libz.1.dylib
                0x7fff6789c000 -     0x7fff678a0ff7  libcache.dylib (80) <354F3B7D-404E-3398-9EBF-65CA2CE65211> /usr/lib/system/libcache.dylib
                0x7fff678a1000 -     0x7fff678abff3  libcommonCrypto.dylib (60118.1.1) <6C502A55-3B54-3B48-BA7B-FA39F56C0B1E> /usr/lib/system/libcommonCrypto.dylib
                0x7fff678ac000 -     0x7fff678b3fff  libcompiler_rt.dylib (62) <4487CFBA-A5D7-3282-9E6B-94CAD7BE507E> /usr/lib/system/libcompiler_rt.dylib
                0x7fff678b4000 -     0x7fff678bcfff  libcopyfile.dylib (146) <7E4BD264-5617-339B-AC73-E8D07EF2C51D> /usr/lib/system/libcopyfile.dylib
                0x7fff678bd000 -     0x7fff67941ff7  libcorecrypto.dylib (562) <7974762C-DEF7-3056-9856-9821C27846DB> /usr/lib/system/libcorecrypto.dylib
                0x7fff679c8000 -     0x7fff67a01ff7  libdispatch.dylib (913.1.6) <0DD78497-6A2A-350A-99EF-15BF41EA07DD> /usr/lib/system/libdispatch.dylib
                0x7fff67a02000 -     0x7fff67a1fff7  libdyld.dylib (519.2.1) <2597D818-42D2-3375-BD9D-451D5942A6BA> /usr/lib/system/libdyld.dylib
                0x7fff67a20000 -     0x7fff67a20ffb  libkeymgr.dylib (28) <6D84A96F-C65B-38EC-BDB5-21FD2C97E7B2> /usr/lib/system/libkeymgr.dylib
                0x7fff67a21000 -     0x7fff67a2dff3  libkxld.dylib (4570.1.46) <AE8CE609-ECB8-3D2E-8823-C103A56064DF> /usr/lib/system/libkxld.dylib
                0x7fff67a2e000 -     0x7fff67a2eff7  liblaunch.dylib (1205.1.10) <5AD77A68-BB4D-33AA-AA4F-DF51D0972FD9> /usr/lib/system/liblaunch.dylib
                0x7fff67a2f000 -     0x7fff67a33ffb  libmacho.dylib (900.0.1) <756F2553-07B6-3B42-ACEA-2F0F1A5E8D0F> /usr/lib/system/libmacho.dylib
                0x7fff67a34000 -     0x7fff67a36ff3  libquarantine.dylib (86) <6AC8773F-3817-3D82-99C2-01BABB9C3CBB> /usr/lib/system/libquarantine.dylib
                0x7fff67a37000 -     0x7fff67a38ff3  libremovefile.dylib (45) <912FA211-DD8C-3C92-8424-21B89F8B10FD> /usr/lib/system/libremovefile.dylib
                0x7fff67a39000 -     0x7fff67a50fff  libsystem_asl.dylib (356.1.1) <94972913-9DF0-3C78-847C-43E58919E3DA> /usr/lib/system/libsystem_asl.dylib
                0x7fff67a51000 -     0x7fff67a51fff  libsystem_blocks.dylib (67) <F2493BB5-B1C6-3C4D-9F1F-1B402E0F1DB7> /usr/lib/system/libsystem_blocks.dylib
                0x7fff67a52000 -     0x7fff67adbfff  libsystem_c.dylib (1244.1.7) <2D4C21C0-9938-3552-8DC1-2C1CFAA10D38> /usr/lib/system/libsystem_c.dylib
                0x7fff67adc000 -     0x7fff67adfffb  libsystem_configuration.dylib (963) <D7EFEAE6-22A0-348E-BBBE-44FFD41934FA> /usr/lib/system/libsystem_configuration.dylib
                0x7fff67ae0000 -     0x7fff67ae3ffb  libsystem_coreservices.dylib (51) <21A488D0-2D07-344E-8631-CC8B2A246F35> /usr/lib/system/libsystem_coreservices.dylib
                0x7fff67ae4000 -     0x7fff67ae5fff  libsystem_darwin.dylib (1244.1.7) <552C05CA-D151-3F93-B570-413340BDA9C7> /usr/lib/system/libsystem_darwin.dylib
                0x7fff67ae6000 -     0x7fff67aecff7  libsystem_dnssd.dylib (878.1.1) <6E28973E-A258-36F6-ACFB-259ED5885C7A> /usr/lib/system/libsystem_dnssd.dylib
                0x7fff67aed000 -     0x7fff67b36ff7  libsystem_info.dylib (517) <483BE95B-62EB-3663-ACB3-9915A40C70F5> /usr/lib/system/libsystem_info.dylib
                0x7fff67b37000 -     0x7fff67b5cff7  libsystem_kernel.dylib (4570.1.46) <71BA15CB-3056-3CBD-A5F5-EE61566EEA0C> /usr/lib/system/libsystem_kernel.dylib
                0x7fff67b5d000 -     0x7fff67ba8fcb  libsystem_m.dylib (3146) <ABB1B85F-9FFE-31B8-AD4F-E39A30794A93> /usr/lib/system/libsystem_m.dylib
                0x7fff67ba9000 -     0x7fff67bc8fff  libsystem_malloc.dylib (140.1.1) <9F0745FF-B92F-330D-8812-BB74001D1D33> /usr/lib/system/libsystem_malloc.dylib
                0x7fff67bc9000 -     0x7fff67c6cff3  libsystem_network.dylib (1229.1.5) <A51EB0A4-9AA5-3F84-8E25-DD8EABE0F97E> /usr/lib/system/libsystem_network.dylib
                0x7fff67c6d000 -     0x7fff67c77ffb  libsystem_networkextension.dylib (767.1.4) <E842569D-00BA-3DE7-AD5A-9EF33422CF3E> /usr/lib/system/libsystem_networkextension.dylib
                0x7fff67c78000 -     0x7fff67c81ff3  libsystem_notify.dylib (172) <98EA3D62-7C86-30DE-8261-D020D2F1EFF3> /usr/lib/system/libsystem_notify.dylib
                0x7fff67c82000 -     0x7fff67c89ff7  libsystem_platform.dylib (161) <9F5A67F7-BC65-300F-BD74-07E7732D6372> /usr/lib/system/libsystem_platform.dylib
                0x7fff67c8a000 -     0x7fff67c95ff7  libsystem_pthread.dylib (301.1.6) <6D0B0110-2B44-3D3C-B672-BD08FE46378A> /usr/lib/system/libsystem_pthread.dylib
                0x7fff67c96000 -     0x7fff67c99ffb  libsystem_sandbox.dylib (765.1.8) <EC909728-0365-3710-B00B-0BCFCE03DC71> /usr/lib/system/libsystem_sandbox.dylib
                0x7fff67c9a000 -     0x7fff67c9bff3  libsystem_secinit.dylib (30) <F06ADB8F-9E94-34A7-B3C9-2C22FDD14BAD> /usr/lib/system/libsystem_secinit.dylib
                0x7fff67c9c000 -     0x7fff67ca3ff7  libsystem_symptoms.dylib (820.1.4) <BF0566B2-9475-3B5C-8641-7910F313BA3C> /usr/lib/system/libsystem_symptoms.dylib
                0x7fff67ca4000 -     0x7fff67cb7ff7  libsystem_trace.dylib (829.1.2) <10955EBB-1AC8-3085-9A2D-F3088CA2DF71> /usr/lib/system/libsystem_trace.dylib
                0x7fff67cb9000 -     0x7fff67cbeff7  libunwind.dylib (35.3) <6D4FCD49-D2A9-3233-95C7-A7635CE265F2> /usr/lib/system/libunwind.dylib
                0x7fff67cbf000 -     0x7fff67ceaff7  libxpc.dylib (1205.1.10) <E7C5DB12-6D0E-3D1E-A743-F750DF112F5F> /usr/lib/system/libxpc.dylib
            External Modification Summary:
              Calls made by other processes targeting this process:
                task_for_pid: 1
                thread_create: 0
                thread_set_state: 0
              Calls made by this process:
                task_for_pid: 0
                thread_create: 0
                thread_set_state: 0
              Calls made by all processes on this machine:
                task_for_pid: 1485
                thread_create: 0
                thread_set_state: 0
            VM Region Summary:
            ReadOnly portion of Libraries: Total=585.6M resident=0K(0%) swapped_out_or_unallocated=585.6M(100%)
            Writable regions: Total=540.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=540.8M(100%)
                                            VIRTUAL   REGION
            REGION TYPE                        SIZE    COUNT (non-coalesced)
            ATS (font support)                32.4M        5
            ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
            Accelerate framework               256K        3
            Activity Tracing                   256K        2
            CG backing stores                 4396K        7
            CG image                          1056K       28
            CoreAnimation                      288K       17
            CoreGraphics                         8K        2
            CoreImage                           20K        6
            CoreUI image data                 2180K       29
            CoreUI image file                  612K        9
            Foundation                          20K        3
            Image IO                            68K        3
            Kernel Alloc Once                    8K        2
            MALLOC                           361.5M      379
            MALLOC guard page                   96K       22
            Memory Tag 240                   276.8M      297
            Memory Tag 242                      12K        2
            SQLite page cache                   64K        2
            STACK GUARD                       56.1M       30
            Stack                             23.2M       31
            VM_ALLOCATE                       17.1M       66
            __DATA                            57.9M      407
            __FONT_DATA                          4K        2
            __GLSLBUILTINS                    2588K        2
            __LINKEDIT                       191.8M       52
            __TEXT                           393.8M      380
            __UNICODE                          556K        2
            libnetwork                         128K        3
            mapped file                      255.0M       70
            shared memory                     2968K       25
            TOTAL                              1.6G     1860
            TOTAL, minus reserved VM space     1.6G     1860
            • 3. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
              AnandSri Adobe Employee (Admin)
              Hi Adamg,
              I apologize for the inconvenience caused. As I understand from the description above, the Acrobat Pro DC is crashing in Mac OS 10.13, Is that correct?
              Please try the troubleshooting steps from the following KB doc: Troubleshoot Mac OS 10.x system errors, freezes | Adobe software  Link: https://helpx.adobe.com/x-productkb/global/troubleshoot-system-errors-freezes-mac.html
              You can also try to reset the Acrobat Preferences, to reset preferences refer to How to reset Preference settings in Acrobat. Link: https://forums.adobe.com/thread/1595848
              Hope this helps, and keep us posted with the results.
              Regards,
              Anand Sri.
              • 4. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                adamg25083311 Level 1
                I have tried the troubleshooting page and also tried to reset the preferences. Neither one of the suggestions solutions worked. Also, yes, the Mac OS I'm under is 10.13, just like I stated in the first message.
                • 5. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                  Hi Adamg,
                  If the issue still persists, please enable the root account, and check with Acrobat. Keep us posted wit with results.
                  Regards,
                  Anand Sri.
                  • 6. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                    Is there a way i can share a video of what is going on so you can see exactly what is happening? Now it's to a point where if I click out of acrobat to open a new file or even just clicking on the desktop will crash the whole program.
                    • 7. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                      Hi Adamg,
                      Sorry for the delay in response to your query. You can share the screenshot of the issue through https://forums.adobe.com/docs/DOC-7161
                      Please enable the root account and check with the Acrobat.
                      Keep us posted with the results.
                      Regards,
                      Anand Sri.
                      • 8. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                        I activated the root account and adobe seems to be working under that account. I've uploaded a video screenshot of what is going on. It shows how it crashes when I click out of the program.
                        Shared Files - Acrobat.com
                        • 9. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                          Also, I should note that the single file .pdf's don't crash. It's only when I open a portfolio and open one of the documents in that file.
                          • 10. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                            Hi Adamg,
                            If it's working in the root account, then it seems to be a user profile issue of your operating system. You may try to create a test user profile and work on Acrobat.
                            I will look into a solution asap and will follow up with you.
                            Thanks for your time and patience.
                            Regards,
                            Anand Sri.
                            • 11. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                              illibuck
                              Any update to this?  I have exactly the same issue...
                              • 12. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                                Nope, I tried wiping my hd and it still has an issue. I guess acrobat only works if it's the only program on the mac and nothing else. I also haven't heard back from AnandSri since that last message he sent so i'm still waiting on that too.
                                • 13. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                                  Hello Adamg,
                                  Sorry for the delay in response to your query and apologize for the inconvenience caused as I was occupied with another project.
                                  As I have shared all the possible steps to resolve the issue, but as per your description the issue is not fixed.
                                  Please help me with your contact details i.e. Phone number, Time Zone, the Best time for a callback , Email address in a Private message, The specified item was not found.  Link: https://forums.adobe.com/thread/1184148
                                  So that I can arrange a call back for you from the product team.
                                  NOTE: Please don't share any personal information on the forum page.
                                  Regards,
                                  Anand Sri.
                                  • 14. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                                    Hello Illibuck,
                                    Regards,
                                    Anand Sri.
                                    • 15. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                                      It turns out that the problem I was having was related to the dropbox app I had on the mac. They said it was a known issue and they are working on getting it resolved. Once I closed my dropbox app, acrobat started working fine.
                                      • 16. Re: Acrobat DC keep crashing, when i try to edit some comments on my PDF document
                                        Hello Adamg,
                                        Great! Good to hear that you are able to use the Acrobat, and thank you so much for sharing the workaround related to the Dropbox, give us a shout if you need any assistance with Acrobat/Reader in future.
                                        Regards,
                                        Anand Sri.
