• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Lightroom export not using the settings
New Here ,
Sep 14, 2017 Sep 14, 2017
I have unchecked the box that says to rename the files on export, but it still renames the files per the box that is greyed out!  I then updated to the latest version to see if that would fix it, but no luck.  I had a heads-up that there might be a problem the other day too because I needed to export at 85% quality, but it kept exporting at 100%.  Finally, I just opened the files in Photoshop and exported from there to get the size I needed.  Can anyone help with this?  Exporting one file from PS is fine, but an album of photos....  much easier in LR.... if it works.  Thanks!
Views
542
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
I'm skeptical that a human viewing the results could determine this is what is happening. How did you determine this?
Aha! Quality and file size are not directly related to one another. What are your exact requirements?
Votes
Translate
Translate
Report
Report
New Here ,
You can check the properties of the file to see all kinds of information.  My exact requirements are that the exported file have the attributes applied to it that are indicated in my export settings.  When I uncheck the box that says "rename file to xyz_filename", but all of the files are saved as xyz_filename, then clearly LR is not applying the settings that I have selected.
Votes
Translate
Translate
Report
Report
LEGEND ,
I don't see any relationship between file naming and quality of the export. Your problem description is extremely confusing.
You have not explained the reasoning that leads you to make this statement.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Could you please post a screen shot of your settings? Could you also state your OS an Lr version?
My experience shows, that Lr respects the settings of the export screen. I, however, sometimes choose the wrong presets.
ABAMBO | Hard- and Software Engineer | Photographer
Votes
Translate
Translate
Report
Report
