1 Reply Latest reply on Aug 11, 2008 6:57 AM by robdillon
    Image Fading
    5wes13
      Hi
      Can anyone help me out with image fading.
      I have a flash file with 9 buttons, once a button is clicked eg: button 6, it will go to frame 6 which will fade in an image. Then say on this frame you click button 3, it will go to frame 3 which will fade in another image.
      Now, is there a way of displaying an image from the frame you have just come from, in the new frame?
      For example, say im on frame 6 and then click button 3 and go to frame 3, but i want the image in frame 6 to show up in frame 3.
        • 1. Re: Image Fading
          robdillon Most Valuable Participant
          The simple solution is to have each of the 9 images in each frame and set to be not visible. Then, when you go to any given frame, make that image visible. If image 3 is then visible in frame 3, then it will also be visible in every other frame. The obvious extension of this is that you don't really need 9 frames, only one. Nine buttons, nine images, make the image visible when you click the button.
