Hello! how can i start make applications with Dreamweaver?
Thanks!
Dw no longer support the inclusion of phonegap, and older versions include the out-dated version.
The link i provided in your other post, will take you to the phonegap site where a number of alternative programs are listed in the 'getting started' section.
You may even wish to take a look at vs code which is free, and also supports the use of Cordova -
What sort of application are you wanting to create?
Please keep in mind that Dreamweaver is a glorified text editor that assists in creating web sites.
Ben,
The user is trying to create web applications using Dreamweaver similar to what has been documented here.
Create web applications in Dreamweaver for mobiles
Preran
I'm not trying to disagree with you deliberately Preran, but I think we require more info from the OP.
If they wish to build device specific apps, with more features than jQuery mobile provides, then phonegap would be a better alternative to Dreamweaver.
It is now also possible to create applications that have all the functions, (except access to contacts) of a device specific app, that works within the browser and is accessed as a traditional web site.
It is also possible that the OP wishes to create a site similar to the one I work on, which is also traditionally called an application, because it contains all the functionality and features more often associated with a traditional installable program, (the Adobe programs for example).
The second and third options could be done in Dreamweaver, and I will not go into my usual 'what is missing' complaints, as I only know of one program that contains most, (not all) features required, and is very expensive for what it is.
(lets put it this way, if my employer did not pay for that program, i would not )
Hi Ememiles,
Did any of the answers provided here help you? Do you require more info?
Preran
Does anyone know how to install phonegap for dreamweaver CC 2017 ?
Or do I need to get a better application made for mobile apps ?
thanks
Thanks, I'm going to try this.
