1 Reply Latest reply on Aug 22, 2008 4:21 AM by anirudhs
    Using SecureAMFChannel facing issue
    hstrong
      Hi All,
      I am trying to use the SecureAMFChannel in Adobe AIR,
      I defined my servlet-config.xml properly and also added the custom channel in my code
      var ch1:SecureAMFChannel = new SecureAMFChannel("my-secure-"amf", "https://localhost:8400/applicationname/messagebroker/amfsecure");
      var channelSet:ChannelSet = new ChannelSet();
      channelSet.addChannel(ch1);
      then i set this channel set to my service.
      When i run the application and try to access the remote service method nothing happens and after a min or so exception comes that not able to make the connection.
      I want to let this know in advance that i can use normal AMFChannel and it worked fine for me to access the remote services.
      Only issue I am facing is with SecureAMFChannel.
      Can anybody let me know what is wrong in this case , if you guys want i can post the config files and code. I am just avoiding that so that it should not be a very big mail.
      ~hStrong
