• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RegEx help
Explorer ,
Aug 07, 2008 Aug 07, 2008
I need to convert this:
<a href=" http://www.cnn.com"><img src=" http://some.domain.net/images/test1.gif" width="143" height="107" hspace="3" vspace="3" border="0" id="Content1"></a>
to this:
*Content1*
Basically, use the value of the ID attribute and encapsulate with asterisks.
The kicker is that the href and img src can be anything, the values posted here are just placeholders.
TIA
TOPICS
Advanced techniques
Views
482
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
> to this:
> *Content1*
Is it the "the value of the ID attribute and encapsulate with asterisks" or
"the value of the ID attribute OF THE <img> tag which is within a <a> tag,
and encapsulate with asterisks"?
Because those are two different things.
NB: a work in progress for the latter is:
^<a[^>]+?><img[^>]*?id="([^"]+?)"[^>]*?></a>$
That makes some assumptions about your requirements.
Adam
Votes
Translate
Translate
Report
Report
Explorer ,
Adam,
Fair enough, the value of the ID attribute of the <img> tag which is within a <a> tag needs to be wrapped with asterisks. I've tried your sample code but nothing gets replaced; the full HTML code comes back. Here's my code:
<cfsavecontent variable="strText">
<img src=" http://some.domain.net/images/test1.gif" width="143" height="107" hspace="3" vspace="3" border="0" id="HTMLContent1">
</a>
</cfsavecontent>
<cfoutput>
#REReplaceNoCase(strText,'^<a[^>]+?><img[^>]*?id="([^"]+?)"[^>]*?></a>$',"","ALL")#
<br /><br />
<xmp>#REReplaceNoCase(strText,'^<a[^>]+?><img[^>]*?id="([^"]+?)"[^>]*?></a>$',"","ALL")#</xmp>
</cfoutput>
Votes
Translate
Translate
Report
Report
Engaged ,
Try this
Votes
Translate
Translate
Report
Report
Explorer ,
Simon - This seems to work like a charm. I will try a few other variations and mark your post as the answer if testing looks good. THANK YOU!!
Votes
Translate
Translate
Report
Report
Engaged ,
No worries, Adam's code was correct for what you originally posted. It didn't cater for the line breaks in your code that is all.
Votes
Translate
Translate
Report
Report
Explorer ,
Ugh. I just found that the ID attribute of the img src may or may not be wrapped in double quotes. So, it's possible for it to look like this:
OR
<IMG id=*HTMLContent1* height=107 hspace=3 src=" http://some.domain.net/images/test1.gif" width=143 vspace=3 border=0>
The reg ex works with the first scenario but not the second. Also, please notice how the order in which the ID attribute is coded in the second case is different from the first case. Not sure if this makes a difference. Can someone shed some light?
Thanks again
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Rather than just expecting the answers - which will teach you nowt - why
doing you read up on regexes and try to DIY.
You could at least have a crack at it, come back to us with your attempt.
Adam
Votes
Translate
Translate
Report
Report
Resources
Documentation
