21 Replies Latest reply on Sep 19, 2017 9:28 AM by lan.mine
    Ideas to group same color path items without a selection
    lan.mine Level 1
      I am looking for a way to group same color path items within a layer. Below is the script I have found to group the same selected color. But I would like to take this script one step further where it won't require slecting the path item. I have an idea of how to script it but it would be great if I can get some guidance from the experts.
      Method 1) Loop through to select a Path Item one by one and skip Group Items if exist.
      Method 2) Delete unwanted swatches, load used swatches, select path items with same swatch and group.
      Which method do you recommend that is less complex for an entry level scriptor? Also, my major weakness are creating loops so any help in that area is greatly appreciated. Thank you.
      function selSameColor (){
      if(app.activeDocument.selection.length == 0){alert('Select a pathItem.'); return};
      if(app.activeDocument.selection.length > 1){alert('Select just one pathItem.'); return};
      var selFillColor = function(){
      var groupColor =  app.activeDocument.groupItems.add();
      if(app.activeDocument.selection[0].typename == 'PathItem'){
      var colorSel = new CMYKColor;
      colorSel.cyan = app.activeDocument.selection[0].fillColor.cyan;
      colorSel.magenta = app.activeDocument.selection[0].fillColor.magenta;
      colorSel.yellow = app.activeDocument.selection[0].fillColor.yellow;
      colorSel.black = app.activeDocument.selection[0].fillColor.black;
      }else{alert('This is not a pathitem.'); return};
      var itemsLength = app.activeDocument.pageItems.length;
      var items = app.activeDocument.pageItems;
      for (i = 0; i < itemsLength; i++){
      if(items[i].typename == 'PathItem'){
      if(items[i].fillColor.cyan == colorSel.cyan && items[i].fillColor.magenta == colorSel.magenta && items[i].fillColor.yellow == colorSel.yellow && items[i].fillColor.black == colorSel.black){
      items[i].moveToBeginning(groupColor);
      }else if(items[i].strokeColor.cyan == colorSel.cyan && items[i].strokeColor.magenta == colorSel.magenta && items[i].strokeColor.yellow == colorSel.yellow && items[i].strokeColor.black == colorSel.black){
      if(groupColor.pageItems.length > 0){groupColor.selected = true};
      selFillColor ();
      selSameColor ();
        • 1. Re: Ideas to group same color path items without a selection
          Silly-V Adobe Community Professional
          Sometimes, a selection is a good way to get a reference to the items you want, without having to loop through them- which causes script slowness. In a file of unknown size, such as when people can use hundreds of items, it becomes prohibitive to run loops.
          What can be (sometimes) done is a narrowing down of the loop you have to create, by using a selection command such as app.executeMenuCommand("Find Fill Color menu item"); to have all your items selected, then loop through selection to pull out specific items, or use an app.executeMenuCommand("group"); to group them all in the same time.
          • 2. Re: Ideas to group same color path items without a selection
            lan.mine Level 1
            Wow so these two lines of code replaced everything above.
            I am having trouble writing a loop. I am guessing that I will need to write a loop that counts the number of active swatches. And from them have it loop one by one applying the app.executeMenuCommand? Or am I over thinking this?
            • 3. Re: Ideas to group same color path items without a selection
              Here is a test I just did:
              Swatches are selected first manually
              Document has a bunch of paths, not nested in any way.
              Run this script:
              #target illustrator
              function test(){
                var doc = app.activeDocument;
                var swatches = doc.swatches.getSelected();
                var thisSwatch;
                for(var i=0; i<swatches.length; i++){
                  thisSwatch = swatches[i];
                  doc.defaultFillColor = thisSwatch.color;
                  doc.selection = null;
              test();
              The result, they are grouped!
              Note that nesting will seriously mess with such an effort because Illustrator via script will get the same error as a user who tries to group items which are in different groups.
              • 4. Re: Ideas to group same color path items without a selection
                lan.mine Level 1
                Thank you Silly-V! This helps me learn a bit more about scripting. I wanted to see if there is a way to prevent having to select the color swatches. I have created an action to delete unused swatches. Now I can do one of the two methods.
                1) Create an action to add used swatches, select all swatches and run your script.
                But I've heard this might not be possible since there isnt a command to select all used swatches.
                So I was thinking I might need to go more of the 2nd method of:
                • Select all objects
                • New Color Group
                • Select New Color Group
                • Run test();
                I am going to work on the method 2 but wanted to see if this is the best method. Is there a better method that I haven't thought of yet?
                • 5. Re: Ideas to group same color path items without a selection
                  Yes you got it, if you use a Make new Color Group action, you can play it after selecting the art items. This will make the new color group with just the colors in your selection (instantly) and the new color group will be automatically selected. Then, running this script works. Furthermore you can incorporate the action into the script too (app.doScript(actionName, setName);), so that all you have to do before pressing the Run button which does everything, is to just select the art needed. Afterwards, your script can remove the new color group as the last step.
                  • 6. Re: Ideas to group same color path items without a selection
                    lan.mine Level 1
                    var swatchGroup = doc.SwatchGroups.getByName ('Art');
                    for(var i=0; i<SwatchGroups.length;i++){
                        var currentSwatch = Swatch[i];
                        currentSwatch.selected = true;
                    Thanks Silly-V! I am now running into the issue of selecting the group swatch by name. It don't have to be by name but I figure it would be quicker if I narrow down the search within the code. This is what I have so far. For some reason I keep getting the error "undefined is not an object".
                    • 7. Re: Ideas to group same color path items without a selection
                      If you used an action to create the swatch group, they should already be selected. Otherwise, you will be nonplussed to find out that you can't actually select swatches in the swatches panel with scripting. Well, you can select one shape on your artboard and your swatch will become automatically selected, but that's not the whole lot of them. However that's really not your issue - you just want to (looking by your snippet) get a swatch group with a name and go through the swatches inside.
                      You can do so like this:
                      var swatchGroup = doc.swatchGroups.getByName("Art");
                      var swatches = swatchGroup.getAllSwatches();
                      var currentSwatch;
                         currentSwatch =  swatches[i];
                         $.writeln(currentSwatch.name);
                      Also make sure that your code is in proper case- javascript here is case-sensitive, so your script is confused by "doc.SwatchGroups" because there is no such thing.
                      • 8. Re: Ideas to group same color path items without a selection
                        lan.mine Level 1
                        I did some testing and you are correct. When I run the action to create the Group Colors, the group is preselected. But the script breaks when it runs the test(); portion. I suspect this is due to selecting all objects to create the group colors and it requires you to deselect the objects for the script to group object by colors.
                        So I figured in order for the function test(); to run without errors, I will have to null selections and try to grab the group swatches by name. Here is the combined script so far. I am also troubleshooting as to why I recieve an error of doc is undefined on line 9.
                        #target illustrator
                        app.doScript('Add Colors', 'Custom Art Actions') //*** Select All > New Color Group
                        groupColors()
                        app.doScript('Delete Unused Swatches', 'Custom Art Actions') //*** Select All Unused > Delete Color Group
                        function groupColors(){
                            var currentSwatch;
                                test();
                        function test(){
                            var thisSwatch;
                        Thanks again for your help on this.
                        • 9. Re: Ideas to group same color path items without a selection
                          it is undefined, because there's not a var doc = app.activeDocument line that it can find happening before the  variable doc is used.
                          • 10. Re: Ideas to group same color path items without a selection
                            lan.mine Level 1
                            Ohhhh got it! Here is the updated version of the script. Running into an issue with the groupColors function. Looks like it is either not recognizing the swatch group Art and selecting all colors from the group.
                            #target illustrator
                            groupColors()
                                var colorSwatches = swatchGroup.getAllSwatches();
                                var currentSwatch;
                                for(var i=0; i<colorSwatches.length; i++){
                                    currentSwatch =  colorSwatches[i];
                                    test();
                            function test(){
                                var thisSwatch;
                            • 11. Re: Ideas to group same color path items without a selection
                              Since you are on a quest for knowledge, I will advise to keep updating with following edits:
                              1. don't use the function test(), just take the parts you need from it.
                              2. A script can't select a swatch, nor do you need it to be selected, you just pull the .color of it
                              • 12. Re: Ideas to group same color path items without a selection
                                lan.mine Level 1
                                I managed to use parts of the funtion test(); script. I am startng to understand this a bit more. However I am a bit confused as to the outcome of this script. I think it might be the due to line 15. I am a bit stuck at this point.
                                #target illustrator
                                groupColors()
                                    var thisSwatch;
                                        thisSwatch = doc.swatches[i];
                                • 13. Re: Ideas to group same color path items without a selection
                                  Maybe add a deselect all, after your new color group is created. This leaves your swatch group still selected.
                                  You can also add a deselection via script with doc.selection = null.
                                  • 14. Re: Ideas to group same color path items without a selection
                                    lan.mine Level 1
                                    After adding the doc.selection = null, the function groupColors(); won't run. I have adjusted the script to further test below. Looks like I still have some work to do for the function but I am unsure what more I can do to get it to work
                                    #target illustrator
                                    /*app.doScript('Add Colors', 'Custom Art Actions') //*** Select All > New Color Group
                                    groupColors()
                                    app.doScript('Delete Unused Swatches', 'Custom Art Actions') //*** Select All Unused > Delete Color Group */
                                        var thisSwatch;
                                    groupColors()
                                    • 15. Re: Ideas to group same color path items without a selection
                                      Hey, when you add the new swatch group with your action, is it actually naming it "Art" ?
                                      • 17. Re: Ideas to group same color path items without a selection
                                        You may have, but did Illustrator?
                                        • 19. Re: Ideas to group same color path items without a selection
                                          Well when I made an action which creates a new color group, typed in "Art", then deleted this new group and re-played the action, it didn't name it "Art" after all. But, I did the action play without dialogs option on.
                                          • 20. Re: Ideas to group same color path items without a selection
                                            Oh, found your mistake!
                                            1.     for(var i=0; i<colorSwatches.length; i++){
                                            2.         thisSwatch = doc.swatches[i];
                                            you are going through colorSwatches, but are referencing doc.swatches!
                                            • 21. Re: Ideas to group same color path items without a selection
                                              lan.mine Level 1
                                              Yes!!! That is exactly what it was. Thank you so much for your help on this. Below is the final script.
                                              #target illustrator
                                              groupColors()
                                                  var thisSwatch;
                                                      thisSwatch = colorSwatches[i];
                                              //groupColors()
