2 Replies Latest reply on Jul 30, 2008 12:04 PM by Cr99
    Waiting until a method finishes
    Cr99
      I have a method which is making a call to a servlet via HTTPService and filling the results in an ArrayCollection. It then loops through the arrayCollection to test and see if the array contents match against a given ID. However even though the code is sequentially correct, the arraycollection doesn't get filled until after the test for the ID is made! How do I get around this?
      makeHTTPquery(); // returns results but only AFTER the following line
      IDlabel.text = generateID(id);
      private function makeHTTPquery(event:ResultEvent):void {
      IDarray=(event.result.system.data);
      trace("report ID leng", reportIDs.length+"");
      private function generateID(id:String):String {
      //....check IDarray for id
        • 1. Re: Waiting until a method finishes
          Rob Rusher Level 1
          Remember that the execution is going to happen asynchronously, so move the second method call to inside the results handler.
          • 2. Waiting until a method finishes
            Cr99 Level 1
            Oops, I thought it worked, and it does in this case because id happens to be a global variable, but what if I need to have the resultevent function get a value passed to it that is generated on the fly say in actionscript? In otherwords, what if I can't just call generateID in the makeHTTPquery function because id is generated just before or after the makeHTTPquery call?
            IDlabel.text = generateID(id); // <-- can't access id, need it passed as a reference
