9 Replies Latest reply on Sep 16, 2017 7:53 AM by JJMack
    jagged lines on pen tool shapes?
    HustleOn
      Hi all,
      I'm trying to create different shapes using the pen tool on 300dpi surface but most of the lines that are not perfectly straight appear jagged or blurry. I thought the pen tool is supposed to create smooth shapes or am I missing something? Is there a way to get these lines crips without appearing jagged, I don't want to blur the edges just want a smooth line.
        • 1. Re: jagged lines on pen tool shapes?
          How smooth a line will be when it is rendered depends on size and resolution.  If you want smooth and sharp you have to edit high resolution image and render them on devices capable of rendering high resolution image like printers and the iPhoneX .  Your display is most likely not up to the task.  And you images resolution is also lower than you want.
          Here is a 1" 500dpi circle is it 1" on your display even on an iPhoneX it would display larger than 1" Display use their dpi resolution. Not the Image's DPI setting.
          • 2. Re: jagged lines on pen tool shapes?
            mglush Adobe Community Professional
            What is your end result of your art--Is this for print or is this for screen display?
            JJ is right--what you are looking at is the monitor's resolution displaying your line. If your artwork is going to be printed, then the printer will interpret the art and give you a smoother line.
            Let us know?
            Michelle
            • 3. Re: jagged lines on pen tool shapes?
              Theresa J Adobe Community Professional
              Looks like you used the pen tool to create a layer mask on a shape layer. The layer mask is made of pixels, which is what you are seeing that looks soft. The higher the pixel count of the document, the sharper the layer mask will look.
              Drawing a shape layer with the pen tool will create a vector which can be infinitely scaled up or down. It will still display on screen at the pixel dimensions of the document, but if you increase the size of your file, the shape will appear sharper.
              You haven't actually drawn a vector shape layer. You have just masked one with pixels.
              • 4. Re: jagged lines on pen tool shapes?
                HustleOn Level 1
                Hi Michelle,
                it is for a website logo, around 500pixel width but looks all jagged and blurry which is not a great sharp look I want for a logo.
                if you look at the lines of the shapes (black,white,red) vs the smooth lines of the font, it makes it look unsharp and jagged.
                • 5. Re: jagged lines on pen tool shapes?
                  HustleOn Level 1
                  is it maybe also an issue with my display? I'm using a notebook with 1366x768 resolution, which probably is responsible for some images to appear with jagged/blurry outlines?
                  • 6. Re: jagged lines on pen tool shapes?
                    Semaphoric Adobe Community Professional
                    What is the size of your notebook screen?
                    • 7. Re: jagged lines on pen tool shapes?
                      It more than size it is mostly about resolution.  To be sharp smooth and crisp you need small high quality pixels and you need many of them.There are displays that have low dpi resolution and displays theat have high DPI resolutions. Displays can not change the size of the pixels they display.  Printers do not print using pixels the paint in pixels using many smaller droplets of ink they can paint in different size pixels.  DPI is pixel size.  Displays are manufactured with one size pixels.  The either have a low resolution or a high resolution or some resolution  in between.     You can have a 5" screen with a low resolution or one with a high resolution. I have display one my pc the has 82DPI, 96Dpr, 100,dpi and 185DPI I have a surface pro 3 with a 216dpi display and and android that has a 359dpi resolution and the new iPhone display's resolution will be something like 458dpi.   The human eye in a young person may be able to resolve down  to that resolution up close and personal.
                      It a physical thing. Pixel density and the quality of those pixels.
                      The 1" circle I posted displays like 8" on one of my displays 4" on an other  and less the 2" on my android even on I iPhoneX it would display over an inch in size. For no display has a pizel size the is 1/500"x1/500" of and inch.  A printer can paint that image 1"x1" The circle will be 1" sharp and smooth in yoy eyes. Yoe will meed a mignifier to see that actual pixels are square. The image is 250,000pixels  1/4MP
                      • 8. Re: jagged lines on pen tool shapes?
                        My though was that a smaller screen would have those 1366x768 in a smaller area, i.e. more pixels per inch
                        • 9. Re: jagged lines on pen tool shapes?
                          Yes the smaller the screen is the sharper the 1336x768 display will  be the circle I posted will fill 1/4 the screens 1MP. No display the is available for purchase will display it 1"x1"
