5 Replies Latest reply on Sep 16, 2017 9:40 AM by rob day
    wedding editing with RAW
    tomsavvy Level 1
      Hi
      Working through a batch of wedding edits, I've managed to achieve (at most!) the more subtle tones of a picture, but i'd like to try and produce something that is a little more darker that most wedding photographers are able to achieve. it maybe in RAW editing its toggling vibrance and the black/white sliders, but I'm not sure.
      I'd like to get from this (original image):
      to this:
      or this for outdoors:
      Any tips/advice/methods would be much appreciated.
      Thankyou
        • 1. Re: wedding editing with RAW
          D Fosse Adobe Community Professional & MVP
          I get that you didn't like the answer you got when you recently posted the exact same question - but it was in fact the correct answer. Here's an enlarged histogram from #3 showing why there is muted highlights:
          As for #1, this is just a classic situation of too much contrast in the scene. To keep the window from blowing out, the foreground is severely underexposed by the camera. In a situation like this you would normally use fill flash to bring up the foreground.
          • 2. Re: wedding editing with RAW
            tomsavvy Level 1
            No I think it was the correct answer. I just felt there were other tweaks involved that I couldn't quite get my head around
            Thanks again
            • 3. Re: wedding editing with RAW
              Here's a typical high-key image with a full 0-255 range:
              One single "Levels" adjustment layer, working each channel individually and mostly the output sliders, no other adjustments whatsoever, can turn it into this:
              • 4. Re: wedding editing with RAW
                davescm Adobe Community Professional
                To add to D.Fosse's correct reply, and given your question was about camera raw, you also have the same output sliders by RGB channel in camera raw as you do in a curves adjustment layer
                You could also soften it slightly by reducing the clarity slider in ACR to a negative value
                Dave
                • 5. Re: wedding editing with RAW
                  You can also lock down the middle of the range so you are only affecting quarter tones and highlights. You can do most of the adjustment with the RGB curve and then adjust the other channels to tint as needed:
