So here's the problem:
In A-master I've made a menu in a 320 breakpoint.
I haven't linked any hyperlinks to the menu yet.
When I go to my contact's page it looks fine.
I return to my A-master page and click the menu, then I put a hyperlink to my contact page.
Now I return back to my contact's page and the menu link has been scaled over the 320 size.
Why does it scale after inserting the hyperlink? It looks very bad.
Is this your issue?
MASTER:
PAGE:
You did some, maybe unwanted, setting in your "Active State"
Uwe
I think we should see the .muse, just reduced to your issue with the menu.
There´s no need to add a breakpoint at 320 BTW. Maybe this solves your issue.
You just have to use the minimum width of 320.
Best Regards,
Uwe
I don't understand your answer, sorry.
English isn't my first language.
I took a video about the problem, since it's hard to explain:
As I told you, a breakpoint at 320 px is not necessary and may be the cause of your error.
My answer was more meant to be a question, then …?
Best Regards,
Uwe
Ok. I did delete the 320 px breakpoint but the problem persists.
So, let´s follow the next step, I guess, .
Uwe
Alright. How should I share the file? Dropbox?
Dropbox is not the worst solution for this .
Also CC would be comfortable if you follow this:
Please Provide a .muse File to Help Us Fixing Your Issue!
Waiting … Neo…
Best Regards,
Uwe
Sorry this took so long, but here's a link to the file:
I cannot see a file or a folder to be downloadable.
Uwe
That's weird. Does this one work? I did everything according to Günter Heißenbüttel 's instructions.
Yes, you`r right, sorry.
Got it. The appearance has changed and we have to click to the "floppy disk icon" to get files.
I look out.
Uwe
Is this your issue?
MASTER:
PAGE:
Uwe
Change this here:
This is you Normal" state.
This is your Active" state:
Best Regards,
Uwe
Wow it was that simple. Thank you very much!!
Welcome. The weekend got saved, I hope .
Uwe
Oh yes, indeed!
Read this carefully: https://forums.adobe.com/docs/DOC-8652 Because nobody wants to inspect a 20 page Muse file with tons of elements and images, which aren't relevant for the issue you are describing.
