3 Replies Latest reply on Sep 17, 2017 12:37 PM by fotoroeder
    Footer and header displaced after first breakpoint (but not in safari)
    baltazarf22194597
      Hi community
      I have big hopes that You can help me out, as i've ran out of ideas and failed to find any answer after many hours of trying.
      So i have a header starting from the top of the page, on the bottom i have footer, both are just solid rectangles full width and a web font. Everything stays at place (or scales) properly until i add a breakpoint. Then after crossing that breakpoint i see no footer, as well as header rectangle and some of my headers text hangs from upper left corner. Some screenshots, first before breakpoint with all in place, second after;
      Zrzut ekranu 2017-09-17 o 16.43.30.png Zrzut ekranu 2017-09-17 o 16.43.43.png
      But this is the case for opera and firefox browsers – in design mode, preview and in safari everything is on place. So it gets me quite confused.
      It doesent matter if its fluid or fixed, happens at both. I have same result with different placement of breakpoint.
      If i remove white rectangle from the header type doesn't get displaced. Footer is missing even if I delete its rectangle.
      Rest of the content behaves normally.
      Any help would be much appreciated.
