Expand my Community achievements bar.
SOLVED
Making CSS changes with Custom Code Editor
Avatar
Level 1
I'm wanting to use the custom code editor to edit simple css on the page (in this case, the background image).
An example is below:
.example {
    overflow: hidden;
    position: relative;
    background: #fceee3 url(/assets/img/example.jpg) no-repeat left bottom / cover;
    min-height: 905px;
When I edit the css directly within the inspector, it works as expected. When I use the same information in Target, it doesn't work.
This has happened whenever I select any element or any change.
Am I using this tool completely wrong?
1 Accepted Solution
Avatar
Correct answer by
Employee
Hi hayley1989,
Not sure if you've managed to fix the issue, but in case you are still facing the same issue, you may want to palce the CSS code within the style tag within the Custom Code section.  E.g.,
<style>
.example {
     overflow: hidden !important;
     position: relative !important;
     background: #fceee3 url(/assets/img/example.jpg) no-repeat left bottom / cover !important;
     min-height: 905px !important;
</style>
View solution in original post
Avatar
Employee Advisor
Hi Hayley,
CSS can sometimes be a little tricky because of its cascading effect. So a change to your CSS from Target might be getting overridden by other CSS on the page sometimes. I've found 2 useful ways to overcome this:
  1. Get more specific with your CSS selector. Instead of just using the class (.example) try something like: div.content > div.example.
  2. Try using the "!important" identifier on your CSS statements. It will look like this:
Avatar
Level 1
Thanks so much for your advice. Unfortunately even if I make the changes in inspector, and copy over the exact specific selector, code and changes over to Target, the changes still don't show in Target - even when I add important.
Avatar
Employee Advisor
If you want to share the URL I'm happy to try prototyping it to see if there is something else that will work? You can direct message the URL to me if you prefer.
Avatar
Correct answer by
Employee
Hi hayley1989,
<style>
.example {
</style>
