3 Replies Latest reply on Aug 8, 2008 2:25 PM by cheftimo
    Flex Data Visualization Trial message
    taraschuk
      Does anyone know how to remove "Flex Data Visualization Trial" message from flex charts? We are using Flex 3.
        • 1. Flex Data Visualization Trial message
          cheftimo Level 2
          This worked for me in Windows XP Pro (if you have another OS, it might be different):
          Navigate to C:\Documents and Settings\All Users\Application Data\Adobe\Flex\ - (Application Data is normally a hidden folder)
          Open license.properties - back it up somewhere, just in case
          If you see the number for a trial or previous version,
          Edit:
          flexbuilder3=yourNewFflexLicenseNumber
          Enter the license number as a continuous string of digits without the hyphens. Save the file
          I hope this works for you too.
          Carlos
          • 2. Re: Flex Data Visualization Trial message
            taraschuk Level 1
            thanks for your response. The serial number appears to be in order, is there anything else that might cause this issue?
            • 3. Re: Flex Data Visualization Trial message
              cheftimo Level 2
              What I said above is the only thing I know to do. When I had the problem, I phoned Adobe Customer Service and they gave me that solution in a couple of minutes. You might try calling them - 888-649-2990, Monday-Friday
              6am-5pm(Pacific time).
              They don't charge for calls about serial numbers.
              Carlos
