Hi Team
Would you please let us know how to remove the XMP raw data from Indesign file. Because my indesign file size is 104 mb there is no image its purely text with 350 pages.
I converted the indesign file to IDML file. and make it has zip format and unstuff the file and checked the meta data has 31 mb in indesign file.
So would you please suggest how to reduce my indesign file size, and how to remove the metadata in indesign file.
Ganesh.R
Hi Stephen
Here is the link
Re: Edit IDML, remove metadata, save, again open in InDesign - can't open
Ganesh.R
21st century. Are you really think that 31Mb+ is a big problem?
If you already do indd-idml-indd converting than I'm don't think so that you can find something else to reduce the file size.
Hi George
31 mb is a metadata file size, Actual indesign file size is 104 mb.
My process is, I am going to link this indesign file(104 mb) to another indesign file. So each and every page linking the indesign file size will become very huge its going upto 4gb.
Do not embed indd, do file-place and your source file won't be increase as you write.
Some metadata can be changed via scripting, but you can also import and export templates. So to clear all of the metadata you could export a blank XMP file and load that into the files you want to clear:
I’d use ExifTool or Adobe Bridge:
Hi
Thanks to all, we fixed this issue using script in indesign
What script? Can you please provide the code or link and mark the most appropriate reply as the correct answer so that others can benefit? Thanks.
Hi Stephen
Here is the link
Ganesh.R
