I want to create a PDCollection.
In sdk 9.0 i use as fallow
PDDoc newDoc = PDDocCreate();
PDCollection pdCollect = PDDocCreatePDCollection(newDoc);
it's ok
but when i use sdk > 9.0
PDDocCreatePDCollection will return error.
it's come an error : error Parameters
Hmm. It's hard to believe, but Adobe seem to have messed this up.
In the Acrobat 9 SDK we find in PDProcs.h a selection of routine definitions
NPROC(void, PDFileAttachmentSetFieldText, (PDFileAttachment attachment, ASAtom fieldID, ASText text))
NPROC(ASBool, PDFileAttachmentGetFieldText, (PDFileAttachment attachment, ASAtom fieldID, ASText text))
NPROC(void, PDFileAttachmentSetFieldNumber, (PDFileAttachment attachment, ASAtom fieldID, float number))
NPROC(ASBool, PDFileAttachmentGetFieldNumber, (PDF
...Copy link to clipboard
Should work exactly the same way.
Are you using DURING/HANDLER blocks to check for errors? Did you do a PDCollectionIsValid() to check the result?
PDCollectionIsValid checks if a PDCollection is valid. but i call PDDocCreatePDCollection has failed
my code is like this.
when i compile with sdk 9.0 it's work ok. but if use sdk x or >x it's will come this error
DURING
HANDLER
// exception handling
char errorMsg[256];
ASGetErrorString (ASGetExceptionErrorCode(), errorMsg, 256);
// if(aspItem!=NULL) ASFileSysReleasePath(fileSys, aspItem);
// if(theFolder!=NULL) ASFileSysReleasePath(fileSys, theFolder);
// display an error message.
if(ASBoolToBool(bEcho)==true) {//
AVAlertNote (errorMsg);
END_HANDLER
other code..
errorMsg just display Parameters is error
Are you using the same version of Acrobat to match the SDK when you move to a higher version of the SDK? Otherwise which version of Acrobat are you using? Is this Mac or PC?
yeah, thanks
i use the same version Acrobat to match the SDK will be ok.
but how to compile one plus-ins for all version Acrobats
or i need to make plus-ins for one by one?
Please give more details of exact versions. Which version of Acrobat and which version of the SDK together fail? Which ones work? It's not enough to talk only of SDK version.
if i compile puls-ins with sdk XI,it works ok on Acrobat version>9.0 all.
but it will be failed in 9.0.
if i comlile it with sdk 9.0,it works failed on version >9.0. it will be only support Acrobat 9.0
When you move between SDKs are you also replacing PIMain.c in your code to match each SDK?
NPROC(ASBool, PDFileAttachmentGetFieldNumber, (PDFileAttachment attachment, ASAtom fieldID, float *number))
In a later SDK we find
NPROC(void, PDFileAttachmentSetFieldStyledText, (PDFileAttachment attachment, ASAtom fieldID, ASConstText text))
NPROC(ASBool, PDFileAttachmentGetFieldStyledText, (PDFileAttachment attachment, ASAtom fieldID, ASText text))
NPROC(void, PDFileAttachmentSetFieldStyle, (PDFileAttachment attachment, ASAtom fieldID, ASConstCab styles))
NPROC(ASBool, PDFileAttachmentGetFieldStyle, (PDFileAttachment attachment, ASAtom fieldID, ASCab styles))
This is absolutely against how the header files must be maintained. Because later in the same header file we find the definition of PDDocCreatePDCollection. Why does it matter? Because each NPROC adds 1 to the current HFT entry. This means that if we use any routine after this point in PDProcs we will be calling the wrong code, with all sorts of bad consequences.
The easy way to resolve this is to build two plug-ins. Building one plug-in is not actually impossible, but is going to need very low level and detailed understanding of how HFTs work. I wouldn't like to do it (though I would if I had to).
Thanks,You mean if we call a proc ,the Arcobat just call it as Index not by name.
So we if call PDDocCreatePDCollection with different sdk in same Acrobat it will don't have same result?
I 'm building two plug-ins...
No,I'm replace the all sdk file .
i check it again.
the plus-ins compile it with sdk >9.0 ,the PDDocCreatePDCollection will be work ok in version >9.0 Acrobat
so it's obvious sdk 9.0 & >9.0 has some difference .
thanks
SDKs are not backwards compatible. Something compiled with SDK 11 should not even load in Acrobat 10 or 9. But they should be forwards compatible except across architecture changes. (Such as Acrobat DC on Mac which needs the DC headers).
So, something compiled with SDK 9 should work in Acrobat 10,11, and on Windows DC. It doesn't?
Acrobat calls all plugin methods by a number, that is correct. (details: study "HFT"). The number comes from the header files and has to match the number used inside that version of Acrobat.
Adobe have been very, very careful to make sure the numbers never change. This is quite simple: new methods are always added to the end of the list. Unfortunately, it seems someone at Adobe was working in the header files and didn't know the rules. It affects all the methods in PDProcs.h which appear in the SDK 9 starting with PDFileAttachmentGetFieldText. This is not many methods and you may be the first to discover it. There is nothing that can be done to fix the mistake.
Thank you so much.
I have learn more from this
So is there someone who can now record this as a bug at Adobe and get this fixed. Leonard - are you onto this one?
Michael, to make sure that Leonard sees this, you need to make a formal "mention" (start with the @ character and then start to type a forum user name, and then pick from the list. Sometimes you have to type the full name): lrosenth​ - this way he will get a notification.
Karl Karl Heinz Kremer​, thanks for the heads up.
There was one bad version which has the problem you describe – but AFAIK, if you use the last dot releases of each version 9.x, 10.x, along with the correct SDK, everything is fine.
However, as noted earlier in the thread – SDKs are only forward compatible not backwards.
