2 Replies Latest reply on Aug 13, 2008 12:34 PM by Developer504
    Sort order in Charts
    Developer504 Level 1
      I noticed an odd thing in Flex. When I import data into my charts from XML files, it seems to reverse the order of the records.
      So for example, if I have the records:
      <projects>
      <job prName="Project A" hours="6705.50"/>
      <job prName="Project B" hours="3370.00"/>
      <job prName="Project C" hours="1223.50"/>
      </projects>
      It displays these in my barChart in the order C,B,A.
      Is there a simple way to reverse that order or do I have to put the data into an xmlListCollection and make a function to do it?
      M.
        • 1. Re: Sort order in Charts
          Level 7
          "Developer504" <webforumsuser@macromedia.com> wrote in message
          news:g7v9nf$te$1@forums.macromedia.com...
          > <projects>
          > </projects>
          > into
          This is what I use:
          private function reverseData():void{
          var reverseSort:Sort= new Sort();
          reverseSort.compareFunction=reverseSortCompare;
          _data.sort=reverseSort;
          _data.refresh();
          private function reverseSortCompare(a:XML, b:XML, fields:Array=null):int{
          if (a==null && b==null) return 0;
          var aIndex:int = a.childIndex();
          var bIndex:int = b.childIndex();
          if (aIndex==bIndex) return 0;
          if (bIndex>aIndex) return 1;
          if (aIndex>bIndex) return -1;
          //default
          return 0;
          Where _data is the XMLListCollection that is being used as a dataProvider.
          HTH;
          • 2. Re: Sort order in Charts
            Thanks Amy. I have a similar function using an XMLListCollection on another Chart already in my code, it seemed like a lot of code to do such a simple thing but I guess I'll do this. Any idea why Flex reverses the order?
