I'm trying to apply alpha channels to certain images. I figured out how to apply alpha channels as a clipping path. However, I would like to apply the alpha channel the way you would in the image import options dialog because it looks much better. Below is what I have so far (the part that would apply alpha channels is the only thing not working). Any help would be greatly appreciated!
--ALERTS INFO
set success_dialog to "CLIPPING PATHS APPLIED" & return & "All available Photoshop Clipping Paths have been applied." as string
set error_dialog to "ERROR" & return & "There was an error. Some available Photoshop Clipping Paths may not have been applied." as string
set start_dialog to "CHECKING PATHS" & return & "This script is now applying the Photoshop Clipping Paths." as string
--SETTING INDESIGN PREFERENCES
--Setting measurements to inches
tell application "Adobe InDesign CC 2017"
tell view preferences
set horizontal measurement units to inches
set vertical measurement units to inches
end tell
--LOOPING THROUGH EVERY IMAGE IN THE DOCUMENT
--Notifying the user that the script is starting
display alert start_dialog
--Getting every image in the document
tell active document
set my_images to all graphics
--APPLYING ALPHA CHANNELS TO PEOPLE IMAGES
--Determining if there is an alpha channel
try
repeat with my_image in my_images
set alpha_names to alpha channel path names of contour options of text wrap preferences of my_image
if (alpha_names as string) is not "" then
--Getting the name of the image
set link_name to name of item link of my_image as string
set link_path to file path of item link of my_image as string
--Getting the square inches of the image (larger images would have people in them)
set image_frame to parent of my_image
set x1 to item 1 of geometric bounds of my_image
set y1 to item 2 of geometric bounds of my_image
set x2 to item 3 of geometric bounds of my_image
set y2 to item 4 of geometric bounds of my_image
set image_width to (x2 - x1)
set image_height to (y2 - y1)
set image_square_inches to (image_width * image_height)
set image_frame_id to id of image_frame
--Setting the image to an alpha channel if the image name contains certain people photo keywords or is over a certain size
if link_name contains "Model" or link_name contains "Lifestyle" or link_name contains "Boy" or link_name contains ¬
"Girl" or image_square_inches is greater than 15 then
--(CODE TO ADD ALPHA CHANNEL AS MASK WOULD GO HERE)
place link_path as alias on rectangle id image_frame_id of page 1 with properties {contour options:{contour type:alpha channel, contour path name:(item 1 of alpha_names)}}
-->Trying to place image with properties above since the image import options dialog comes up only when placing the image
--APPLYING CLIPPING PATHS TO PRODUCT IMAGES
--Applying the clipping path if the image has an alpha channel but is not a photo of a person
else
my apply_clipping_paths(my_image) -->Calling apply clipping path function (see bottom of script)
end if
--Applying the clipping path if the image either has no alpha channel
else
end if
end repeat
--DISPLAYING SUCCESS OR ERROR ALERT TO THE USER WHEN DONE
--Displaying success dialog if everything is ok
display alert success_dialog
--Displaying error dialog if something went wrong
on error
display alert error_dialog
end try
end tell
end tell
--FUNCTIONS
--Function to apply Photoshop clipping paths
on apply_clipping_paths(the_image)
set path_names to photoshop path names of clipping path of the_image
if (count of items of path_names) > 0 then
set properties of the_image to {clipping path:{applied path name: (item 1 of path_names), clipping type:photoshop path}}
end if
end tell
end apply_clipping_paths
I think you want to post in the Scripting forum.
end if
end tell
Looks like you want:
set path_names to alpha channel path names of clipping path of the_image
--not photoshop path names
I had tried that, but it adds the alpha channel as a clipping path, which looks kind of rough. By hand, I'm able to go into the image import options when I first import the image and select the alpha channel there, which looks much smoother than applying it as a clipping path. Maybe that's not an option through AppleScript?
I'm traveling so I can test this, but I think you also need the clipping type to be alpha channel when you set the image properties
set path_names to alpha path names of clipping path of the_image
set properties of the_image to {clipping path:{applied path name: (item 1 of path_names), clipping type:alpha channel}}
Moved to InDesign Scripting​
