2 Replies Latest reply on Oct 2, 2017 10:43 AM by Akash Sharma
    Pen Pressure Not working
    jdavida Level 1
      I am using Adobe Photoshop CS6 64 bit with a Microsoft Surface 3 tablet with the Superadapter Precision Surface Pen Digitizer Stylus. There are no drivers for this stylus.  It is supposed to have 384 levels of pressure sensitivity. If I select the pencil tool and open the brush tip menu, select "Shape Dynamics", and set the Control to "Pen Pressure", a yellow triangle with the '!' appears to the left of the word "Control", indicating it is not allowed. When trying to draw, I can see there is no pressure sensitivity. I know the problem is NOT the tablet, or the stylus, as the pressure sensitivity does work with another app that came preloaded on the tablet, called "Fresh Paint".
      I did try another fix, which did not work, where I saved a file called PSUserConfig.txt with the text in it showing "UseSystemStylus 0" and saved in the [drv]Users->[user]->AppData->Roaming->Adobe->Adobe Photoshop CS6->Adobe Photoshop CS6 Settings. As mentioned, it did not work. Any idea on how to fix this? Thanks.
