I needed an new OS and now I am trying to install my software again. I know it is old, but I do not have the money to buy new stuff, so it has to do. I try to install from my DVD (Creative Suite 4 - design standard) and get this error: the installation database is corrupted.
I then downloaded from Adobe's site and try to install which gave me the same message. So it seems there is a problem with the installation database, but I have no clue.
You may also refer below link :
Error: "Installer database is corrupt..." when you install Adobe Creative Suite 4 or point product
The problem is most likely the difference in the ages of the software and the machine - if you need the software you need the an OS that can work with it. You haven't mentioned anything about which OS this involves. If it happens to be a Mac...
Solved: It was a caps.db file in:
C:\Program Files (x86)\Common Files\Adobe\Backup
C:\Program Files\Adobe\Adobe Premiere Elements 12
I renamed both and everything is up and running
