2 Replies Latest reply on Aug 8, 2008 7:45 PM by Newsgroup_User
    Fatal Link Error
    nash99 Level 1
      I have a dataGrid.mxml file --
      In this mxml I have a datagrid with Itemrenderers in 16 columns. I created a mxml file for the button component(buttonRenderer.mxml) .
      Now the datagrid's dataprovider is an arrayCollection from the as File (dataGridDataProvider.as)
      The issue is I need to change the label on the button dynamocally (this button is a item renderer component) , the data provider (labelArray) for the label to be changed comes from the array I declared in the dataGridDataProvider.as .
      The problem is now I am trying to get the label array from the dataGridDataProvider.as which is the same for the datagrid .
      When I try to access this array to provide it as a data provider for the label ____ I get the error
      FATAL LINK ERROR
      can any body please address the problem
      please reply me if u need any more info.
        • 1. Re: Fatal Link Error
          Michael Borbor Level 4
          This is an item renderer, if you place it inside a datagrid, Flex uses the special property data to pass any info to an item renderer.
          <mx:VBox xmlns:mx=" http://www.adobe.com/2006/mxml">
          <mx:HBox>
          <mx:TextInput text="{data.headertext}" />
          </mx:HBox>
          </mx:VBox>
          Hope this could help.
          • 2. Re: Fatal Link Error
            Level 7
            "mab_bond" <webforumsuser@macromedia.com> wrote in message
            news:g7iilr$nao$1@forums.macromedia.com...
            > <mx:HBox>
            > </mx:HBox>
            > </mx:VBox>
            Additionally, you can use a labelFunction if the exact wording isn't
            contained in any field.
            HTH;
            Amy
