I have a long document made up of mostly tables. On the last page, the table will not break to the next page. If I try to add a new row below the last row, it disappears below the footer.
Is there a way to fix this?
Thanks.
Does ordinary text below the table flow to or auto-create and flow to the next page?
If not, that suggests a disconnected page problem.
Also check that Table > Row Format (next/prev) is not set so as to cause this problem.
I'd select the frame on the troublesome page and check the flow tag and if auto-connect is enabled. Both are in Graphics > Object Properties after your Control+click to select the frame.
