3 Replies Latest reply on Aug 13, 2008 11:24 PM by sudheer.com
    Skip row in datagrid
    geiryt
      Is it possible to skip a row in a datagrid that uses an ArrayCollection as dataprovider ?
      I want to check if an arraycollection item contains X and if so then don't draw it.
      I use the same arraycollection in multiple datagrids and its only one of them I don't want to draw the specific item.
        • 1. Re: Skip row in datagrid
          Level 7
          "geiryt" <webforumsuser@macromedia.com> wrote in message
          news:g7v61v$q8h$1@forums.macromedia.com...
          > dataprovider ?
          > draw it.
          > them
          Use a different ArrayCollection and the same source but a different
          filterFunction
          • 2. Re: Skip row in datagrid
            sudheer.com
            Use the following steps to skip row.
            step 1) copay that arraycolletion into another array or arraycolletion.
            step 2) use for loop and check condition . if the condition is true arrayid.pop(index) user this methed
            step3) set that array or arraycollection to datagride
            may be it should work otherwise send me mail your problem
            • 3. Re: Skip row in datagrid
              sudheer.com Level 1
              step3) set that array or arraycollection as dataprovider to datagride
